AnsweredLED option does not appear on the top of Precision X1
ThatRedMelon
2019/05/14 10:39:05 (permalink)
Hello,
I recently downloaded Precision X1 in order to disable the green LED on my RTX 2060 Founders Edition. I have downloaded and installed the program with LED Sync installation but I get no LED option at the top of my screen. I have attached a photo to explain this to you. How do I get the LED option to show up?
  • Ribbons : 123
Re: LED option does not appear on the top of Precision X1 2019/05/14 11:17:04 (permalink)
Welcome to the Forums
RTX 2060 Founders Edition ---> is that the Nvidia Card ?
Open LED Sync -- any option there to get to it
Your on a Old version .... X1 newest 3.17
Re: LED option does not appear on the top of Precision X1 2019/05/14 11:20:36 (permalink)
For the founders edition you need to use the following tool...
http://international.down...isualizer_v1.3.0.0.exe
ThatRedMelon
Re: LED option does not appear on the top of Precision X1 2019/05/14 11:27:25 (permalink) ☼ Best Answerby Cool GTX 2019/08/15 07:24:51
Thanks for the replies, the newest version doesn't work either but LED Visualiser works, thank you.
Re: LED option does not appear on the top of Precision X1 2019/05/14 11:27:40 (permalink)
  • Ribbons : 282
Re: LED option does not appear on the top of Precision X1 2019/08/14 15:24:26 (permalink)
Updated 04/15/2019 12:31 PM
https://nvidia.custhelp.com/app/answers/detail/a_id/4248/~/led-visualizer-missing-in-geforce-experience-3.0
The NVIDIA LED Visualizer is available as a standalone utility from the following URL:
http://international.download.nvidia.com/GFE/LEDViz/1.3.0.0/LEDVisualizer_v1.3.0.0.exe
Please note: The NVIDIA LED Visualizer utility does not support GeForce RTX 20 series graphics cards.
For GeForce RTX users, we recommend using a software solution from one of our board partners such as EVGA Precision X1.
post edited by bcavnaugh - 2019/08/14 15:28:38
Re: LED option does not appear on the top of Precision X1 2019/08/14 18:13:41 (permalink)
It worked for the op.
  • Ribbons : 282
Re: LED option does not appear on the top of Precision X1 2019/08/15 07:08:12 (permalink)
Yes Some Say So
"The NVIDIA LED Visualizer utility does not support GeForce RTX 20 series graphics cards"
ThatRedMelon
Re: LED option does not appear on the top of Precision X1 2019/08/17 02:09:25 (permalink)
For GeForce RTX users, we recommend using a software solution from one of our board partners such as .
Yes Some Say So
Another method I found to work was downloading an older version of EVGA Precision before the RTX 2060 was supported. I can't remember which version it was but when I did the LED option was available and I could turn the LED off and even make it breath on and off.
