Issues with proper cable to motherboard cpu
DarkerSneasel
Sunday, May 17, 2020 11:08 PM (permalink)
I've been building my first PC and bought a ROG Crosshair VIII motherboard and am having issues with connecting my power supply to it.
The power supply i got was the EVGA 850GQ but the cpu power cables have a different shape and cannot fit into the motherboard 8 pin slot properly. I bought a cable that does fit it but not of EVGA brand then the components fail to work but without that cable they will work (minus the CPU of course) . I was wondering if there was a solution that I'm not seeing here. I'm attaching a picture of my motherboard female connectors for reference.
Thanks
7 Replies Related Threads
    • Ribbons : 123
    Re: Issues with proper cable to motherboard cpu Sunday, May 17, 2020 11:23 PM (permalink)
    Sorry for the delay - had to release your post from filter
    • Ribbons : 123
    Re: Issues with proper cable to motherboard cpu Sunday, May 17, 2020 11:25 PM (permalink)
    Welcome to the EVGA Forums
    You are a new member & there are limits on what you can post  Ultimate Self-Starter Thread For New Members
    lets see if we can figure this out
    the CPU cables should only fit One way ... PSU end is the 8-pin & the  MB end is the 4-pin +4-pin
    The little latch should align with the bump on the MB socket to lock it on
    Left side of photo 2nd & 3rd cable down
    • Ribbons : 123
    Re: Issues with proper cable to motherboard cpu Sunday, May 17, 2020 11:28 PM (permalink)
    DarkerSneasel
    Re: Issues with proper cable to motherboard cpu Sunday, May 17, 2020 11:44 PM (permalink)
    Yes. That PSU
    sparetimepc
    • Ribbons : 27
    Re: Issues with proper cable to motherboard cpu Sunday, May 17, 2020 11:46 PM (permalink)
    The cpu connectors are universal on motherboards and power supply cables so your evidently not aligning the 2  4+4 connectors together properly or you have them turned upside down.  Looks like your motherboard has a 4 Pin and an 8 Pin connection on it for the cpu so you would put 2 of the 4 pin connectors side by side with the lock tabs pointed up top in the 8 pin connector on the right and then you would also put a single 4 pin connector with the lock tab pointed up in the left side connector.
    post edited by sparetimepc - Sunday, May 17, 2020 11:51 PM
    bob16314
    • Ribbons : 761
    Re: Issues with proper cable to motherboard cpu Monday, May 18, 2020 1:21 AM (permalink)
    • Ribbons : 123
    Re: Issues with proper cable to motherboard cpu Monday, May 18, 2020 1:34 PM (permalink)
