RAVENEVGA
I heard that if you use a resolution greater than 1920, you can get issues with bottlenecking if you have an i7 12700 and are using a 3080 Ti. Is there any truth to this or a non-issue?
> Windows 11 Pro> Case: Lian Li O11 Dynamic XL> PSU: EVGA SuperNOVA 1000 G5> Mainboard: EVGA Z690 CLASSIFIED (BIOS v1.10 6/21/2022)> CPU: Intel Core i7-12700K> Video Card: EVGA 3080 Ti FTW3 ULTRA> Cooling: Noctua NH-U12A> Physical Memory: Corsair Dominator Platinum RGB DDR5, 32 GB [2x16GB], 5600MhHz> Drives: 980 Pro 1TB [main], 980 Pro 2TB, 990 Pro 2TB> Physical Memory Model#: CMT32GX5M2B5600C36W> Main Monitor: LG UHD 4K 32" [Model:32UN500-W.AUS] > Second Monitor: Samsung C27F591 [Model:LC27F591FDN]
kraade
- Ribbons : 7
Re: Issues with i7 12700K and 3080 Ti having issues with bottlenecking?
2022/06/22 16:28:44
RAVENEVGA I heard that if you use a resolution greater than 1920, you can get issues with bottlenecking if you have an i7 12700 and are using a 3080 Ti. Is there any truth to this or a non-issue?
totally a non- issue. The Higher the resolution the more the card work , you can get CPU bound at lower resolutions , but those are ridiculously high frame rates = no issue
ObscureEmpyre
- Ribbons : 7
2022/06/23 05:46:44
Yep, total nonsense. My wife’s 12700K/3080 Ti performs just as good as my 12900K/3080 Ti at 1440p when it comes to gaming. Of the current Intel gen, I’d bet even a 12400 would do the trick. Who’s spouting this cheese ball nonsense anyway? Just for kicks, here’s a funny video that exactly pertains to this question: https://youtu.be/NbNZxX2MIFM
bdary
- Ribbons : 116
2022/06/23 08:58:59
Every time I see that video no matter what it's pertaining to, I get a good chuckle...
kraade
- Ribbons : 7
2022/06/23 09:12:41
getalife
2022/06/23 11:34:28
How can you have a bottleneck issue on a PCI-E 5.0? You can't even break the barrier of the PCI-E 4.0 with that card? Pretty sure you experiencing more a temp issue, and your graphic card might throttle, if i was you, i will investigate this first!
Simply enthousiasmic about computer since 1992
CraptacularOne
- Ribbons : 222
2022/06/23 11:42:22
getalife How can you have a bottleneck issue on a PCI-E 5.0? You can't even break the barrier of the PCI-E 4.0 with that card? Pretty sure you experiencing more a temp issue, and your graphic card might throttle, if i was you, i will investigate this first!
The generation of the PCIe interface has very little to do with "bottlenecking" as even PCIe 3.0 is more than enough bandwidth for graphics data. What the OP is referring to is the CPU limiting the performance of a video card. As for the topic at hand, sure there will be a little bit of CPU bottlenecking at only 1080p with a RTX 3080 Ti, this will also be the case with even a 12900K when paired with a RTX 3080 Ti. The whole ampere architecture just isn't really geared at lower resolution rendering efficiency in the higher range of cards. This is why they usually do better a higher resolutions where their compute heavy and complex design can really stretch their legs. You'll often see this in benchmarks where something like a RX 6900XT will be faster than competing Nvidia Ampere cards at lower resolutions like 1080p but then fall behind at 4K. TLDR: Don't worry about it, a 12700 + RTX 3080 Ti combo is great for gaming. You get all the P core performance of the 12900K without the mostly useless for gaming E cores.
getalife
2022/06/23 11:53:15
CraptacularOne
Oh i see, good to know. thx for teaching me about that CPU bottlenecking. i play myself in 2K or 4K since 2016, so i'm very curious why playing in this low resolution with an high end card and last Intel baby product? I haven't bother to buy the 12700K myself and use the I5 12600k instead. NVIDIA GeForce RTX 3090 video card benchmark result - Intel Core i5-12600K Processor,Micro-Star International Co., Ltd. MAG Z690 TOMAHAWK WIFI (MS-7D32) (3dmark.com)
post edited by getalife - 2022/06/23 16:07:34
RAVENEVGA
2022/06/23 20:21:01
Wow....thanks for the great info, guys! :-)
fpandjic16
2022/06/23 21:11:02
If you are playing at 1080p, there will be CPU bottleneck, but still FPS are going to be really high so you don't have to worry about that. Even with 12600k, you should not have issues.
- Ribbons : 135
2022/06/23 21:14:21
I'm within a frame or two at 4K running on my ancient Broadwell-E based on online benchmarks I've perused. Bottlenecking is loosely defined as whatever part of your system is impacting your performance the most at your preferred settings. You'd probably achieve a higher performance delta switching to some form of water cooling vs changing the processor.
RAVENEVGA
2022/06/25 09:24:11
When playing games, I've not had my GPU temp go above 77c.
- Ribbons : 135
2022/06/25 12:33:37
RAVENEVGA When playing games, I've not had my GPU temp go above 77c.
Okay. You're dropping several frequency bins due to temps. Your CPU could also benefit from lower temps and higher frequencies using a loop. It isn't rocket science, simply a comment on what is.
donta1979
Primarch
- Ribbons : 72
2022/06/25 12:43:56
No its not going to bottleneck it maybe a little at 1080p yet the 30 series at least the higher tiers are not design for that lower resolution that is more of a cpu is doing most of the work resolution still. So it's more of an Intel/AMD cpu thing at that resolution.
As for your GPU temps if you want the best possible boost clocks nearly all the time get it colder my 3080 and 3080 12gb FTW3 Ultra's do not hot or break 70c they stay at around 60-65c. One boost to 2025mhz the other around 2070 yet I have seen 2085 only once. Get it colder both with intel 12th gen means higher Turbo clocks on the cpu, and on the gpu it means higher boost clocks. I have noticed the best GPU boost clocks normally happen staying below 60c.
Heatware Retired from AAA Game Industry Jeep Wranglers, English Bulldog Rescue USAF, USANG, US ARMY Combat Veteran My Build Intel Core I9 13900K@6.1ghz, ASUS ROG Ryujin III 360 ARGB, 32gb G.Skill Trident Z5 RGB 7200mhz CL34 DDR5, ASUS Rog Strix Z790-E, ASUS Rog Strix OC 4090, ASUS ROG Wingwall Graphics Card Holder, Seagate limited Edition Cyberpunk 2077 m.2, 2x Samsung 980 m.2 1TB's, 980 & 990 Pro m.2 2TB's, ASUS ROG Hyperion GR701, ASUS ROG Thor 1200W Platinum II, Cablemod RT-Series Pro ModMesh Sleeved 12VHPWR Carbon, ASUS Rog Swift PG35VQ 35", Acer EI342CKR Pbmiippx 34", ROG Harpe Ace Aim Lab Edition mouse, Rog Claymore II keyboard, TCL home entertainment Sound Bar w/Wireless Sub, Steelseries Johnny Silverhand Headset Microsoft Cyberpunk 2077 Xbox controller
kraade
- Ribbons : 7
2022/06/25 13:39:46
I've tested my KPE 3090 in a z390 i9 9900k DDR4 3200 with a 3.0 rider cable and stuck it in a Z690 I9 12900 k DDR4 4800 in a 4.0 slot and it Port Royal'd the same exact score
ObscureEmpyre
- Ribbons : 7
2022/06/25 18:30:16
kraade I've tested my KPE 3090 in a z390 i9 9900k DDR4 3200 with a 3.0 rider cable and stuck it in a Z690 I9 12900 k DDR4 4800 in a 4.0 slot and it Port Royal'd the same exact score
That’s because Port Royal is a raytracing benchmark, and primarily utilizes the GPU. Very little CPU usage for that benchmark specifically.
