EVGA_Lee
Moderator
- Ribbons : 14
Re: Introducing the EVGA NU Audio Pro Cards - Ascend From Lifelike Audio to 7.1 Heaven
2019/11/20 15:23:57
Fredski I have to say I do not understand what's that NU Audio Pro about. I have Nu Audio and want to upgrade. Using only headphones and only for gaming. Which one should I buy as an upgrade ? Is it one card or two cards?
So: NU Audio Pro 7.1 (712-P1-AN21-KR) = NU Audio Pro (712-P1-AN11-KR) + NU Audio Pro Surround (712-P1-AN10-KR). We will be selling each of those products separately. You would want to wait for the NU Audio Pro to be released by itself.
EVGA_Lee
Moderator
- Ribbons : 14
2019/11/20 15:24:24
CivicMinded I'm guessing the new Pro card did away with the front panel I/O connection? I don't see it mentioned, or I may have missed it?
You are correct. No front panel header.
RMui
2019/11/20 17:18:05
EVGATech_LeeM
jonny80s 2 days before this was released I was searching the internet for an expansion sold EMI shield to put between the graphics card and the audio card.... Will the Pro back plate fit the original card? And will they be available for purchase?
No, the backplate will not fit the original card. A number of differences, plus, they use different I/O brackets to accommodate the backplate.
I had to return my previous card due to coil whine from the graphics card, which I really wanted to keep because the audio reproduction was fantastic. Will this EMI shield on the back plate shield the card from most, if not all, the coil whine?
EVGA_Lee
Moderator
- Ribbons : 14
2019/11/20 17:27:23
RMui
EVGATech_LeeM
The backplate will have an effect of reducing EMS. However, there is no way to guarantee that it will prevent this in all situations. Anyone who's familiar with coil whine in graphics cards and power supplies knows that this can be a very fickle type of issue for some people. I recall your issue, but the most I can advise is to test the Pro card(s) out to see if you remain noise-free. It wouldn't be honest to advise you otherwise.
playboyer
2019/11/20 19:15:58
For two channel get Energy Take Classic speakers and a nice 2 channel mini amp. Currently I have a pair of Energy Take Classics with a 2 channel mini amp and I'm using an rca splitter to connect to a Klipsche Promedia 2.1 subwoofer with the stereo speakers disconnected. Sounds amazing.
- Ribbons : 115
2019/11/20 19:46:34
Yesterday I did an "auto notify". Today at 8:55 am said it was in stock. When I went to the product page it's still on pre-order.
myststars
2019/11/20 22:12:08
There are not two cards actually.The second card cannot function without the first card.The second card adds only multichanel for SPEAKERS only!! If you use ONLY headphones the second card is useless for you.You can buy the Nu Audio Pro over the Nu audio because to further improve your sound quality for headphones.
sp33ls
2019/11/20 23:02:51
I already have a high-end headphone amp, but considering upgrading from my Schiit Multibit and Eitr stack to a better DAC. Fingers crossed I wouldn't run into EMI issues by going to an internal sound card. But, I'd be interested in hearing any thoughts around sound quality differences.
Any ballpark ETA on the Nu Audio Pro standalone release?
golddubby
2019/11/21 00:21:56
Still no coaxial output :(
EvoLunatic
2019/11/21 02:46:50
Lee, has the digital out been affected? I'm currently just using it as a digital output. Paid full retail on this unit so not looking to upgrade anytime soon. Could always gift it at some point :)
gjb813
2019/11/22 12:31:34
Does the software that comes with the card have a voice changer? For example, monster voice,happy voice, male, and female? I have it on my asus essence stx ii and I love it.
EVGA_Lee
Moderator
- Ribbons : 14
2019/11/22 14:40:53
EvoLunatic Lee, has the digital out been affected? I'm currently just using it as a digital output. Paid full retail on this unit so not looking to upgrade anytime soon. Could always gift it at some point :)
The digital out is mostly unchanged from the original NU Audio card. The only thing that would potentially affect the digital out would be the different main power section of the Pro card, which more or less means there shouldn't be much of a difference, with regards to the digital out.
Vlada011
- Ribbons : 11
2019/11/22 23:16:15
PC without dedicate sound card is not PC for me. And sound card should be in level with other components. People pay 3000-4000$ for PC and use SupremeFX sound, no comment. Sound card is 30-40% of reason why I can't switch to Mini ITX PC. If someone think that high end onboard solutions are excellent, I notice difference between mid and high class sound card need to say that best audio solutions are not even close to 80$ worth SBZ. And you don't need to have super expensive 7.1 or 5.1 systems. On any normal speakers you notice difference. Good pair of desktop speakers like A2+ or A5+ or far more then you need to notice extreme difference between mid and high level of sound cards. A lot of people upgrade from GTX1080 to RTX2080...example, or GTX1070 to RTX2070... Why instead they not buy Audioengine A2+ and EVGA Sound card and delay upgrade of GPU one next year. That's investment for 10-15 year in Desktop sound, excellent quality. You don't need to connect PC to Hi-Fi, recivers, DAC, Amplifiers, 5 surround speakers... Simple PCI-E sound card and pair of active desktop speakers.
post edited by Vlada011 - 2019/11/22 23:28:24
- Ribbons : 271
2019/11/23 06:46:50
EvoLunatic I'm currently just using it as a digital output.
Why? Waste of money. The analog stuff, you aren't using, is what you paid extra for. You can get a different digital output, which sounds identical, for $50.
ASRock Z77 ā¢ Intel Core i7 3770K ā¢ EVGA GTX 1080 ā¢ Samsung 850 Pro ā¢ Seasonic PRIME 600W Titanium
DannyW75
2019/11/23 12:33:24
I am currently a Sound Blaster ZXR owner, and I have bought a pre-order for the Nu Audio Pro 7.1 package. I can't wait to get it. I have Burson Audio V6 Vivid Single and Dual opamps in my ZXR card currently. I will be putting all V6 Vivid opamps into the Nu Audio Pro when I get it. If anyone here wants me to put up a review of the card when I get it, I will be glad to do so.
McCracken
2019/12/02 13:25:10
"We took the solid foundation of the NU Audio Card"
I had to stop there. There is still basic problems with the NU card, people here have all sorts of fundemental problems with the product. Just look at the latest post, even after several driver and firmware updates, still problems, crackling audio, issues with teamspeak etc. I really want to pull the trigger on the NU card, but not before the basic stuff is in order. Good luck EVGA
Ravenmaster
- Ribbons : 7
2019/12/09 09:08:05
Seems like a bit of an oversight to not include a HDMI audio socket on the card. Optical and Analog connections don't support Dolby Atmos or DTS:X signal - only high speed HDMI supports them.
Asus ROG Maximus Z790 Dark Hero | Intel Core i9-14900KF | RTX 4090 FE | 2x32GB Corsair Dominator Titanium DDR5 RAM (7200mhz) | 2x Samsung 990 Pro 4TB M.2 NVMe's for main OS and backup) | Windows 11 Pro 64-bit 23H2 |Klipsch 5.1.2 Dolby Atmos speakers + Denon AVR-X2800H Receiver | LG 42" C2 OLED | EVGA ASSOCIATE CODE: JRKV0L1B1GY3ADW
DannyW75
2019/12/09 16:28:10
The main focus with this card is to use it with 2 channel analog, or 5.1/7.1 analog with the daughter card. This way, you are fully utilizing the AKM DAC chips on the card. There really is no need for HDMI on the card. With HDMI, the DACs will not even be used, and you will then be using the DAC in your receiver. Any receiver out there under 1500 bucks will not have DAC chips in it as good as the 4 x AKM 4493 DAC chips used on the Nu Audio Pro. The AKM 4493 is a very high end chip, and you don't find DACs of this level in receivers until you hit the 2000 dollar and above price point. If the receiver has 6/8 channel analog inputs, the sound quality when using analog from this card will be superior to using HDMI, unless it is an ultra high end flagship receiver with an equivalent DAC in it.
DKSang
2019/12/11 04:09:18
Backplate? Not for 19/25 Euros plus shipping to North America...
post edited by DKSang - 2019/12/11 04:14:46
Intel Core i9-10980XE, Asus Strix X299-E Gaming II, 128GB Kingston HyperX DDR4-2400, EVGA GeForce RTX 2080 XC HYBRID GAMING 08G-P4-2184-KR, Asus ROG Swift PG278Q, Corsair HX850i, Corsair H110i AIO, all wrapped in a Corsair Obsidian 600 case.
icy20
2019/12/23 15:02:39
When will be orderable on the EU??? I have sold my Nu audio and waiting for this to come out. The thing is that I will be left with onboard audio until it releases :(
The_Professor
2019/12/24 00:57:27
icy20 When will be orderable on the EU??? I have sold my Nu audio and waiting for this to come out. The thing is that I will be left with onboard audio until it releases :(
Since to normal one, is still not availible in Germany, i dont expact a fast availiblity in Europe for the Pro. The Pro is also still not listed on the german page. But the card can be good as hell and better than the original one, but the software is still not working well. Since they cant provide a perfect update, im not sure, if you should by them
post edited by The_Professor - 2019/12/24 01:00:35
V00D002
2019/12/24 17:06:07
Ordered mine, got it a few days ago and nothing but pure love! Got a winner with yet another EVGA quality hardware!
GAMING MEANS EVGA! š
playboyer
2019/12/30 13:45:38
Anyone know a good 7.1 speaker system?
icy20
2019/12/31 10:55:28
V00D002 Ordered mine, got it a few days ago and nothing but pure love! Got a winner with yet another EVGA quality hardware!
I am guessing US? Why isnt there an option from the US site to send to EU? :(
EVGA_Lee
Moderator
- Ribbons : 14
2020/01/02 14:45:55
playboyer Anyone know a good 7.1 speaker system?
What's your budget?
mr_scary
- Ribbons : 6
2020/01/02 20:36:33
Has anyone tried the 7.1 Tiamat v2 Analog Headset with this card?
DannyW75
2020/01/04 11:27:32
Having 7.1 on a headset is nothing but a gimmick. If you want good positional audio in a headphone, just buy a real headphone. For under 200 US, you can get the Beyerdynamic DT 880 250 Ohm headphones, and it will blow that Razer trash out of the water. The DT 880 is neutral, detailed, and has an excellent soundstage. You can detect exactly where everything is in games. For the 200 bucks price level, you can't beat this headphone. https://www.amazon.com/be...=1578165876&sr=8-1
jmanonezerozero
2020/01/08 19:17:50
I just requested the Nu Audio pro card using their upgrade program: . Looks like a great deal and I am really excited to see these improvements, even though I very much love the original. I noticed that I was only able to get the bundle (pro card and daughter card). Not a big deal for me, maybe someone will come out with real 7.1 headsets that are not total crap (I don't think that's even possible). Currently I'm using the Sennheiser HD 650 paired with the original Nu Audio card. I know these headsets are used for music, however I am also using them for FPS gaming as well. It does not really bug me; I do hear where people/bombs are at on a map. That being said I am now more interested in other headsets to use for gaming only. @DannyW75 had a great recommendation on the DT 880's I am very much considering. I would love to see other (non 7.1) headphone recommendations using this new pro card. I am sure this would be useful for others in the community. Thanks in advance!
DannyW75
2020/01/08 19:27:42
If you already own the HD650, the DT 880 is not an upgrade for you. It is more of a sidegrade. What sound signature are you after ? If you like the warmer sound of the HD650, a perfect upgrade for you is to step up the Beyerdynamic Amiron Home. You would be extremely impressed with this headphone. It is an excellent upgrade from the HD650. The soundstage, imaging, and detail retrieval are far superior on the Amiron Home compared to the HD650. It has a lush, warm, and non-fatiguing sound. I have owned this headphone for about 2 years, and I highly recommend it. Be aware that the headphone has a burn in period, but it is not long. The Amiron Home reaches its final sound after about 50 hours of use. https://www.amazon.com/be...=1578540238&sr=8-1
DannyW75
2020/01/08 19:30:16
You are going to be blown away by the Nu Audio Pro as well. It is the best sound card I have owned to date. I took out all the opamps, and replaced them all with my LME49720HA metal can opamps on adapters. The sound quality of those opamps paired with the excellent AKM 4493 DAC chips on the card is just stellar.
