theanimedude
Hello everyone! So, i downloaded evga e-leet and it says that my memory is running dual channels. I have 3x 2gb of corsair memory http://www.newegg.com/Pro..._-20-145-220-_-Product i have no idea why it's not running in triple channel. I have it all installed in the green slots. and the e-leet shows all 6gb's. I tried installing it all on the black slots but it will not boot. my motherboard is the 132-BL-e758 with a i7 920 D0.
EVGA X58 SLI i7 920 D0 w/ Vigor Monsoon III LT Corsair XMS3 6gb ddr3 1333 Corsair 750watt PSU GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3
theanimedude
Re:Help! why is my system running Dual channel, not triple????
2011/01/30 21:14:54
oh yea, i have windows 7 64-bit
PvtBlackdog
2011/01/30 21:37:43
What does it tell you in your bios? Or even when the machine is posting?
owcraftsman
- Ribbons : 60
2011/01/31 04:17:43
1st Remove all modules and test each one individually in slot one. If the all work clean the dust bunnies in all dim slots and reinstall. Make sure when inserting you hear the click both sides. 2nd make sure your memory is in the right slot for triple channel that would be slots 1, 3, and 5 see below. Good Luck!
5800X3D | ROG Crosshair VIII Hero w/EK-Q-M-Full | Trident Z Neo 4x8 3600 C16 | EVGA RTX 3090 FTW3 Ultra w/EK-QV2-ABP +150 CC/+1000 MC | LG 34GP83A-B UW-QHD/2-Asus PB278Q | EVGA Supernova 1000 G2 | Corsair 1TB MP600 (OS) & 970 EVO 1TB M.2 (Games) | Custom Phanteks Enthoo Luxe | NexXxoS UT60 1080mm Nova | 2x D5 w/BP-2D5TOPPEX-BK | Win-10-pro 21H2 RIG PICS
EVGA Affiliate Code GMER9XL4N
theanimedude
2011/01/31 08:51:46
yeah i have all 3 ram sticks in the green slots, 1, 3 and 5. and the E-leet says 6gb's right? so i would assume that all 3 sticks are working. for the Bios, where do i go? memory features? I have it set to 1333mhz, 9-9-9-74-24-1t if i remember correctly.
post edited by theanimedude - 2011/01/31 08:56:09
aka_STEVE_b
EGC Admin
- Ribbons : 69
2011/01/31 08:58:45
Just so you guys know ( & have forgotten ? ) the memory is dual-channel = DDR It sounds fine to me,... all DDR memory runs "dual-channel" When you put 6 sticks in, it isn't going to say sexa-channel , just like it is NOT going to say triple-channel....Doesn't matter how many sticks are in, it will always say dual-channel in the spot you are referring to. My bad, in my haste I did not fully read what you were referring to NOR did I even look at your attached pic... I was thinking of Bios boot up post... YES, everyone is right CPUZ (reskin E-LEET) will say dual or triple in the area you were referring to in your picture. Mine also says triple !
post edited by STEVEBABCOCK2002 - 2011/01/31 16:31:57
sgtharry
- Ribbons : 8
2011/01/31 09:08:12
Hmmm, mine says triple in the channel # box. Always has.
markloew
2011/01/31 09:55:38
STEVEBABCOCK2002
DDR = Dual data rate, that has nothing to do with the memory channels. Triple channel referes to the access mode from the system not the data rate internally of the chip. I'm not sure what you aren't getting triple channel out of it though. Mine is running in triple channel and I just have 3 sticks.
smoothie
2011/01/31 10:03:08
Im pretty sure mine says triple channel as well.
theanimedude
2011/01/31 16:25:11
wow, what the hell is wrong with my system! it says right there, 6gb's and i have it all in slots 1,3, and 5. what do you think it is ?windows 7??? i'll post after i have a chance to test each memory module.
Munkypoo7
2011/01/31 16:29:14
Try CPU-Z? I know eleet is based off of it, but just give it a run for giggles. Might just be eleet reporting improperly? My 767 board shows Triple just fine :\
owcraftsman
- Ribbons : 60
2011/01/31 16:35:39
HalloweenWeed
- Ribbons : 37
2011/01/31 17:23:44
Are you OCd (CPU)? This is one of the things you now have to watch as you OC. The i7 mem controller is weak. Also, DO NOT use XMP memory profile. Enter your latencies manually, mem spd "standard," MCH strap either "auto" or "DRAM ratio," and enter your RAM V spec manually. If you did not OC your CPU, i.e. your Bclock (freq) is stock 133, then set mem freq to 2:10; if you OCd your CPU then it must be 2:8 or even lower if you are above 166. We may require your BIOS template to help more: Bios Template for X-58 and Classified by iride4u When filling this out, if you have set "auto" then say so, don't just tell us what the BIOS has chosen. Even better, tell us both like this: "tRFC Setting ( auto / 74 )"
post edited by HalloweenWeed - 2011/01/31 17:36:14
Main (gaming) rig: i7-3930K; Asus Rampage IV Extreme; H100 W/p-p Excaliburs, AS5; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB. See my primary ModsRigs: Adam for the rest, and I have a second (wife's) rig Asus Rampage III Extreme & 960: Eve. Overclocking is useless to me if it is not rock stable.
theanimedude
2011/01/31 20:27:28
CRAPPPP SO i'm running raid 0 and after i flashed my bios to the newer bios, i ran into some problems! it wont boot up properly. of course i went into the bios and reset it from IDE to RAID again. It gets to the windows 7 logo and then reboots!!! im having windows 7 do that repair right now......see if it fixes it... am i missing something??? hope not.... ****!!!!!
theanimedude
2011/01/31 20:37:29
no luck.... i'm stuck..... why the heck wont it boot like usual??? i redid the bios to how it was in the original settings! all it was is just changing it from IDE to RAID right?? crtrl+i shows that it sees the raid 0 configuration. WHY WONT IT BOOT UP PROPERLY!!!!!!! All i get is to the windows logo screen and the colors freeze and then blue screen for a second and reboots.
[Y]urimaster
- Ribbons : 6
2011/01/31 21:00:42
Mine says triple as well. Something is wrong with the board or the CPU. Probably the CPU since it has the memory controller in it. First I will try changing the cpu. But before that. Reset the bios to defaults or remove the battery.
Case: Cool Master HAF 932 Board: EVGA X58 E758 rev1.1 CPU I7 920 Batch 3938A248 D0; @ 3.8ghz (21X181) bios vcore 1.356v Cooler: Noctua NH-U12 SE2 Push RAM: Viper Xtreme 12GB (3x4GB) running @ 1816 Mhz 9-10-9-27 1t Video Card: MSI Geforce GTX 680 Sound card: Creative X-fi Xtremegamer HD: 4 SATA HD's two of the WD black 640GB in Raid0; PSU: Corsair HX1000w Monitor: Asus VS248H-P 24" Win 7 x64 Ultimate My gaming clan Lowlife Division www.lowlifedivision.net
theanimedude
2011/01/31 21:55:07
dangit, u know i never ever have overclocked my CPU. I got my computer back, had to use my repair disk. Anyway, let me test each memory module.
HalloweenWeed
- Ribbons : 37
2011/02/01 07:55:03
Set HPET to 64 bit You cannot load a previously saved BIOS profile after flashing BIOS. If you did that, you need to reset CMOS and start the BIOS settings from scratch. Regardless you must set all BIOS settings just like you just installed a new mobo. Do you have a sound card installed? If so, did you disable onboard sound? You have a Windows driver loading that is conflicting with something, and it is due to a BIOS setting.
theanimedude
2011/02/01 18:35:47
no sound board installed. I just set the HPET to 64-bit. it was on 32-bit but it still says dual...
HalloweenWeed
- Ribbons : 37
2011/02/01 18:46:32
I had something similar to this happen to me: I was RMAing my EVGA mobo and had Win7-64 installed on my Kingston V-series SSD. So I kept it for the replacement board (exact same model). In the meantime I used an Asus Rampage II extreme mobo, and used a Velociraptor boot drive with it. But when my EVGA RMA board came, and I tried to boot on the Kingston, it did just like yours is doing (not in RAID, but did have RAID 10 data - WD blacks). The RAID did not matter whether or not they were connected. By that time I had found out that drive did not support TRIM, so I bricked it. I just ran Windows7 on the velociraptor instead (it worked without re-install, just had to change a few drivers). I don't know how that could help you, just tellin' my experience.
post edited by HalloweenWeed - 2011/02/01 18:52:52
HalloweenWeed
- Ribbons : 37
2011/02/01 18:50:30
Hey, come to think of it, are you just running RAID 0 or is there another drive? If so try setting the opposite as boot priority!
post edited by HalloweenWeed - 2011/02/01 18:53:36
theanimedude
2011/02/01 18:53:09
Mother Board ( EVGA X58 132-BL-e758 ) Drivers ( ????) Bios ( 77) CPU ( i7 920 d0) CPU Cooler ( Vigor monsoon LT III) Memory ( Corsair XMS3 6gb ddr3 1333 ) PSU ( Corsair 750watt) GPU ( GTX260 ) Drivers ( nvidia 3.3.532.01 ) Operating System ( Windows 7 64-bit pro) Frequency Control CPU Clock Ratio ( 20X ) CPU Host Frequency (Mhz) ( 133 ) MCH Strap ( Auto ) CPU Uncore Frequency (Mhz) ( auto} ) CPU Clock Skew ( 0 ps ) Spread Spectrum ( Disabled ) PCIE Frequency (Mhz) ( 100 ) Memory Feature Memory Speed ( Standard ) Memory Control Setting ( Enabled ) Memory Frequency ( 1866Mhz / 2:10 ) Channel Interleave Setting ( 6 Way ) Rank Interleave Setting ( 4 Way ) Memory Low Gap ( 2.5 ) tCL Setting ( 9 ) tRCD Setting ( 9 ) tRP Setting ( 9 ) tRAS Setting ( 24 ) tRFC Setting ( 74 ) Command Rate ( 1t ) TREF: auto, 637 TRRD - auto, 5 TFRAW: auto, 20 TRTD: auto, 5
Voltage Control EVGA VDroop Control ( Without VDroop ) CPU VCore ( auto, 1.26875) CPU VTT Voltage ( auto, +0mv) CPU PLL VCore ( auto, 1.800v) DIMM Voltage ( 1.500v ) <------ CAN THAT BE IT?!?!?!? DIMM DQ Vref ( +0mV ) QPI PLL VCore ( auto, 1.100v ) IOH VCore ( auto, 1.100v) IOH/ICH I/O Voltage ( auto, 1.500v ) ICH VCore ( Auto ) *PWM Frequency ( 800 KHZ ) CPU Feature Intel SpeedStep ( Disabled ) Turbo Mode Function ( Enabled ) CxE Function ( Disabled ) Execute Disable Bit ( Disabled ) Virtualization Technology ( Disabled ) Intel HT Technology ( Enabled ) Active Processor Cores ( All ) QPI Control Settings ( Enabled ) QPI Link Fast Mode ( Enabled ) QPI Frequency Selection ( auto ) OC Recovery ( Disabled ) Turbo Performance ( Disabled ) used with 980X only PnP/PCI PCI Express Maximum Payload Size ( 128 ) Power Management Setup ACPI Suspend Type ( s1) HPET Support ( Enabled ) HPET Mode ( 64-bit )
HalloweenWeed
- Ribbons : 37
2011/02/01 18:56:12
HalloweenWeed
- Ribbons : 37
2011/02/01 18:57:42
Which one of these do you have? TR3X6G1333C9 TR3X6G1333C7
theanimedude
2011/02/01 18:58:02
i just used my windows repair disk and it fixed it. but the only issue is that every time i boot up, i have to choose which OS to run, Windows 7 or Windows 7 recover.
HalloweenWeed
- Ribbons : 37
2011/02/01 19:09:12
Which one of these do you have? TR3X6G1333C9 TR3X6G1333C7 On the start menu, type "msconfig" in "Search", then go to the boot tab. In there you will see more than one line, select the one that don't say: "Windows 7 (C:\Windows) : Current OS" and press "Delete" button and close msconfig. That will fix that.
KMoore4318
Pistoj Doulos Unum Pluribus
- Ribbons : 238
2011/02/01 19:11:31
If your computer is a multiboot configuration, you can still change which Windows operating system opens by default, and how long to display the list of operating systems, by using System in Control Panel. In the left pane, click Advanced system settings. If you're prompted for an administrator password or confirmation, type the password or provide confirmation. Click the Advanced tab, and then, under Startup and Recovery, click Settings. Under System startup, choose a default operating system and the amount of time to display the list of operating systems, click OK, and then click OK again.
Just clink Link to Register > My Affiliate Code:VTJPDC4OMB 1)965 V-8 E761(77) 2)980X AX1200 E760(77) 980 ti 3) E770 (77)2(590) SLI AX1200 4) X299 FTW K, 9980XE 2 2080 supers on AX1200
theanimedude
2011/02/01 21:11:27
wow that was really helpful! gosh i wish i knew all these little nicks and tricks. i have the TR3X6G1333C9 i linked it up there on my 1st post.
HalloweenWeed
- Ribbons : 37
2011/02/01 21:24:20
Then other than 2t your mem settings are good as far as I can tell. But if you can get it to run 1t stable more power to 'ya. Your DIMM V setting is fine. That's odd, you say your CPU Vcore is auto, and BIOS is selecting 1.26875? Mine set much lower on auto. Not an issue though.
post edited by HalloweenWeed - 2011/02/01 21:26:41
HalloweenWeed
- Ribbons : 37
2011/02/01 21:35:06
There are some other things you can do to improve performance: Memory Low Gap ( 1 ) there is no reason to set this higher with your single vid card Maximum Payload Size ( 4096 ) will speed up memory transfers to PCIe a little bit
And: CxE Function ( C5 ) will get you more power savings in sleep mode
