Having an issue with multi monitor on 750 ti
Fennicillin
2017/03/15 09:35:04 (permalink)
My friend loaned me his 750 ti while I deal with an RMA and I can't run both my monitors. I have my main 1440p display running through DVI. When I use the HDMI to my secondary display it black screens my main display. Drivers were reinstalled clean.
3 Replies Related Threads
    Re: Having an issue with multi monitor on 750 ti 2017/03/15 11:30:19 (permalink)
    Sounds like the card is defective.
    wmmills
    • Ribbons : 40
    Re: Having an issue with multi monitor on 750 ti 2017/03/15 11:35:22 (permalink)
    Whats the secondary display make/model? Did you try switching out the hdmi cord for a different one? You reinstalled the drivers after the card swap? The newer drivers don't always work as good as the older drivers that were released during that cards release dates.
    MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW
     New EVGA product? Register it NOW with this link:
    http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII
     Help Our Vets From K-2!
    [link=https://strongholdfreedom
    Fennicillin
    Re: Having an issue with multi monitor on 750 ti 2017/03/15 12:06:27 (permalink)
    I don't really have the time to to dig up old drivers that will probably perform in worse in whatever games I want to play on the offchance I can watch facebook in between deaths.. They worked dual for my friend before he went with my old 970. Secondary is just an ASUS 1080/60hz.
