Germs666
Ambient temps are 23C. Using an EVGA FE card with the 1080ti Hybrid kit. * Tried Kryonaut thermal paste * Made sure the radiator hoses are running from the bottom of the rad * Have 2 Corsair ML 120's in push pull (getting similar temps with the stock fan) Card still idles at 34-35C and tops out at 56C with fans on max (way too loud) or around 59-60C with fans on medium. Is it just a bad card? I see others with temps near 23C idle and 45-49C max. Not sure what else I can try. I did reuse the 4 spring screws when mounting the cooler. I didn't use the included screws from EVGA but I'm sure the cooler is still making proper contact. Any ideas?
post edited by Germs666 - Friday, May 12, 2017 10:03 PM
sk11vengeance
Re: HELP! 1080ti Hybrid Kit installed still getting near 60C temps.
Friday, May 12, 2017 10:06 PM
How do you have the pump connected? If its to a motherboard fan header it needs to be set to 100% power or whatever the equivalent is in the bios.
Germs666
Friday, May 12, 2017 10:46 PM
Pump is connected to the existing header inside the card. The 3 pin cable is running out of the card but no fan is connected to it since the ML 120 uses a 4 pin and won't fit. CPU and mobo temp 26-28C.
post edited by Germs666 - Friday, May 12, 2017 10:56 PM
sk11vengeance
Friday, May 12, 2017 11:23 PM
Ok so the Corsair fans are connected to the motherboard? I have those fans as well and they take more power so id recommend not using a fan cable splitter for them. If the contact is good from the pump and gpu chip, it sounds like the pump isnt getting enough power or running fast enough. You could try running the pump on a motherboard fan header and setting it to 100% to see if temps improve. If none of that helps its possible you got a bad unit.
Germs666
Saturday, May 13, 2017 0:11 PM
Idk how I could run the pump directly to a mobo header, they don't give you much cable to work with. Something is making my card run 10C hotter and I cannot figure it out. Sucks I spent: 699 for the card 160 for the cooler 16 on thermal paste 56 dollars for 2 fans and my card is struggling to break 2000mhz and stay under 60C. I wish EVGA had told people about the SC Hybrid release and I could've avoided this whole headache. Submit Post
sk11vengeance
Saturday, May 13, 2017 0:22 PM
If you have a fan extension cable that would work obviously but i suggest doing that to rule out the pump mostly. You could try setting the fan speed on the gpu to max since the pump is connected to that, see if it makes a difference. If none of that works you can try and remount the cooler on the gpu. Usually thats the problem, not getting good contact between the cooler and gpu. I have a 1080 ti reference that i used a g12 with corsair h90 and my temps will go down to the mid 40's if i run the fan max but i usually keep it about 50% or so and the gpu is around 48-55c at 99% gpu usage. Ive tested my oc to 2012mhz stable so far, seems like if i apply too much voltage itle crash every time. I have the evga kit being delivered next week cause im not happy with the looks of the install and id feel better if the memory and other stuff was better cooled.
GTXJackBauer
- Ribbons : 48
Saturday, May 13, 2017 0:34 PM
Install it the way its suppose to be installed and don't go plugging the pump else where. Leave it the way it is if you've installed it right. Just make sure there's no air pockets lodged in the pump that can lessen the flow or make loud pump noises. The only thing that can be done is making sure you have good contact with the right amount of TIM. Did check your contact when installing the hybrid on the GPU? You could have put too little or too much TIM. Ambient temps can fluctuate as most 120mm CPU or GPU hybrid kits will hover around 50c-60c at best. Those who get better temps obviously have cooler ambient temps or more rad surface (240/360mm). Don't forget, it's still only a 120mm radiator cooling a powerful GPU. If you want the absolute best delta-temps on water, custom is the way to go.
post edited by GTXJackBauer - Saturday, May 13, 2017 0:36 PM
talkischeap
Germs666 Ambient temps are 23C. Using an EVGA FE card with the 1080ti Hybrid kit. * Tried Kryonaut thermal paste * Made sure the radiator hoses are running from the bottom of the rad * Have 2 Corsair ML 120's in push pull (getting similar temps with the stock fan) Card still idles at 34-35C and tops out at 56C with fans on max (way too loud) or around 59-60C with fans on medium. Is it just a bad card? I see others with temps near 23C idle and 45-49C max. Not sure what else I can try. I did reuse the 4 spring screws when mounting the cooler. I didn't use the included screws from EVGA but I'm sure the cooler is still making proper contact. Any ideas?
You see others with temps as in standing next to the case and watching a normal operation under normal conditions? Or you are just reading posts of people posting numbers up and taking them as the end all be all? It all factors into the air you are cooling your radiator with. At max load mine has hit up to 55 depending on time of day. Im sure if i mounted it as a intake it would be cooler as well. If i put my case next to the windows right now when its 50 F outside and ran it as a intake i bet my temps would drop 10 degrees. There's a ton of factors.
Mother Board: EVGA Z97 FTWCPU: i7 4790k 4.8ghz - EVGA CLC 280mm Closed loopGPU: EVGA 1080 Ti Founders Edition HybridRAM: Kingston HyperX Savage 16GB 2400MHz DDR3PSU: EVGA SuperNOVA 1300 G2SSD: Samsung EVO 500gb X2 / Crucial M4 128gb (OS) / PNY 480gb. HDD: WD Black 2TBSoundcard: Soundblaster Z / Beyerdynamics DT990 Pro 250ohmCase: Phanteks Eclipse P400s Tempered GlassDisplays: Acer x34 Predator w/Gsync Dell 27" WQHD 1440p Ultrasharp / Vizio M series 70" 4k TV
GTXJackBauer
- Ribbons : 48
Saturday, May 13, 2017 0:37 PM
talkischeap You see others with temps as in standing next to the case and watching a normal operation under normal conditions? Or you are just reading posts of people posting numbers up and taking them as the end all be all? It all factors into the air you are cooling your radiator with. At max load mine has hit up to 55 depending on time of day. Im sure if i mounted it as a intake it would be cooler as well. If i put my case next to the windows right now when its 50 F outside and ran it as a intake i bet my temps would drop 10 degrees. There's a ton of factors.
Precisely and well said.
- Ribbons : 135
Saturday, May 13, 2017 0:54 PM
You should be seeing around 50C under full load. My ambient temps are ~22C. I have the pump connected to the GPU using the splitter. I have a single Scythe AP -14 running pull (pulling into the case) connected to a motherboard header at 95%. Running furmark for 1/2 hour I peaked at 49C with +150 on the core and +350 on the memory and +66% on the voltage. So, what I'm getting at here is you should be seeing lower temps even at idle. Too clear something up, are you set up so your Hybrid exhausts out of the case or bringing external air in? If you're using it as exhaust, your temps inside your case could be significantly higher which means you're drawing warm air through the Hybrid. There was one recent example where someone using a Noctua air cooler on their CPU was causing this issue because the CPU cooler fan was directing the air flow almost directly into the Hybrid radiator. You still need decent air exchange inside your case. The AIO cannot cool any lower than the ambient temp inside your case if running as exhaust.
yoitsmegabe
Saturday, May 13, 2017 0:59 PM
Germs666 Idk how I could run the pump directly to a mobo header, they don't give you much cable to work with. Something is making my card run 10C hotter and I cannot figure it out. Sucks I spent: 699 for the card 160 for the cooler 16 on thermal paste 56 dollars for 2 fans and my card is struggling to break 2000mhz and stay under 60C. I wish EVGA had told people about the SC Hybrid release and I could've avoided this whole headache.
My card can't hit 2000mhz period. Crashes in overwatch at 1975, I have to play at 1950 and that throttles once temps go above 51c. You're not alone. My temps get to about 53c with the stock fan plugged into the kit's splitter. I'll probably get a better an and plug it into my motherboard like jayztwocents did. edit* hit submit before I was done: That's the gamble with graphics cards man. Some people here have golden chips, some people have average chips, then there's us: the bottom end of average/below average. What sucks isn't being below average, but paying this much and having to eat the poop soup of being below average when someone can buy an off the shelf sc2, save themselves 150 dollars and get better clocks than we did with all that we spent. Just remember it's all part of the game, and the grass is always greener. Right now you wish you would have gotten a SC hybrid, but if you had gotten that, and you couldn't clock over 2000mhz, you'd wish you got a founders with a kit b/c so many other people have posted great numbers with xyz setup. Hang in there, don't let it eat you up, keep learning (hey now you know how to install a hybrid right?) and ultimately, just play your games. 3-5fps aren't going to revolutionize your game play experience.
post edited by yoitsmegabe - Saturday, May 13, 2017 1:06 AM
talkischeap
Saturday, May 13, 2017 1:43 AM
GTXJackBauer
Just noticed a good example after going afk after starting a game. I just snipped my current performance and it looks great and legit and what we all want. Except its my rig running Mass Effect Andromeda in a window. Its just an example of me showing my card at its peak when it's not really what happens.
cyberdimensions
Saturday, May 13, 2017 8:57 AM
Here's my setup: I am getting similar temps as the OP and I am not surprised. I am using the fans on the Hybrids as an exhaust because I really don't want to dump all the hot air they produce into my case. Just putting my hand over the PC when it's running at load makes you realized how much hot air would be dumped into the computer. I rather put up with temps just below 60 C than turning the inside of my PC into a sauna. I am also running a ML120 on each Hybrid kit which is plugged into a Silverstone PWM hub which in turn gets it's power from the PSU directly. Both fans are plugged into this hub and are spinning at 1600 to 1800 rpm. Putting them on full blast is just too loud and to me this is the best compromise. My room temp is usually around 78 to 82 Fahrenheit or around 26C. Once the computer is at operating temperature, Corsair link shows around 43C for most of the temp sensors on the motherboard, so since this is the air going through the radiators, it's not surprising that I am getting the temps I am getting. Sure beats 85C and having 2 jet engines in my PC. :-)
i7 6850K @ 4.2 Ghz @ 1.27 V Asus X99 Deluxe II motherboard 2 x EVGA 1080 Ti in SLI with Nvidia HB Bridge and Hybrid kit using 4 ML120 fans 64 GB G.Skill Trident Z DDR4 3200 Ram Corsair H115i Water cooler with 4 Corsair ML140 fans Corsair 750 D Airflow edition case with 1 ML140, 1 Cryorig 140, 1 ML120 fan Samsung 950 Pro 512 GB M.2 SSD 3 x Samsung Evo 850 500 GB SSD in Raid 0 Western Digital Black 2 TB HDD Western Digital Black 640 GB HDD Corsair HX1200i PSU Acer Predator XB271HU IPS Gsync 144/165 Hz Windows 10 Pro
TRClark911
Saturday, May 13, 2017 1:45 PM
I spent the same except I didn't buy any fans and my card is running normally. Idle temps around 19-20C (ambient temps pretty much 19C year round I'm in PNW) and load temps are 38-45C. Max temp I've seen period is 49C on a stress test. 2063-2076mhz stable... going for 2100 whenever I get time to play around with the voltage curve. GTXJackBauer Install it the way its suppose to be installed and don't go plugging the pump else where. Leave it the way it is if you've installed it right. Just make sure there's no air pockets lodged in the pump that can lessen the flow or make loud pump noises.
Yep... I installed it the way it was supposed to be. I removed the stock case fan from the rear to install the rad... intake from the front (not worried about a 1 or 2 degree increase inside the case, Jayz2Cents said it's OK LOL plus my ambient temps are amazing) and exhaust via the top fan and the rear GPU fan/rad. Absolutely no thermal issues to speak of anywhere. 7700k idles around 25C and load temps are 65-75C. cyberdimensions I am using the fans on the Hybrids as an exhaust because I really don't want to dump all the hot air they produce into my case. Just putting my hand over the PC when it's running at load makes you realized how much hot air would be dumped into the computer. I rather put up with temps just below 60 C than turning the inside of my PC into a sauna.
Wow... people really use the hybrid fans as intakes? All I had to do was put my hand behind the computer when the GPU was at load to know that I made the correct choice with my setup.
post edited by TRClark911 - Saturday, May 13, 2017 2:11 PM
- Ribbons : 282
Saturday, May 13, 2017 5:08 PM
cyberdimensions Here's my setup:
I would put an intake fan on the Bottom of your case. Maybe you can change your Rear Fan as Intake to bring in cool are for the GPU Radiators at the top of your case. Or Turn your GPU Fans as Intake and allow the Rear Fan Pull out the Hot Air.
post edited by bcavnaugh - Saturday, May 13, 2017 5:16 PM
cyberdimensions
Saturday, May 13, 2017 5:52 PM
bcavnaugh I would put an intake fan on the Bottom of your case. Maybe you can change your Rear Fan as Intake to bring in cool are for the GPU Radiators at the top of your case. Or Turn your GPU Fans as Intake and allow the Rear Fan Pull out the Hot Air.
The two ML120's that are now on the Hybrid radiators used to be at the bottom. I had to remove one of them because I move the CPU radiator to the front. I removed the second one because I used it on the second Hybrid radiator. I am definitely getting another one to put down there. I honestly don't think that the one 140 in the back could keep up with the heat those two hybrid radiators put out. My CPU would be drenched in hot air. I am just going to add the one ML120 in the floor of the case again to get more cool air into the case and see what that does. Thanks for the suggestion though!
GTXJackBauer
- Ribbons : 48
Saturday, May 13, 2017 6:40 PM
TRClark911 Jayz2Cents said it's OK LOL
If I hear another Jayz2Cents comment, I'm going to explode. He's a great marketer, that's about it. I think there are others that know more about what they talk about than Jay. For example, Linus. I've caught Jay in the past spew misinformation about custom water cooling. The guy's really good at marketing and gets his mods done by others, only to end up putting it all together himself. Something I would do. lol He's probably a nice guy that gets a lot of free stuff is all I probably see. Most people new in the scene won't know that and think he's the almighty PC god guru.
timmyboy04
Saturday, May 13, 2017 7:34 PM
Can we stay on track here please...For the OP's sake. OP: If you're positive your TIM application is good and everything is mounted well, I would just suggest playing with your fan curves until you find a sweet spot. IT TAKES TIME. I have found 60-80% max on the fan curve is the sweet spot at high load. after that it's diminishing returns and WAY too loud. If you are still unsatisfied, contact EVGA customer service and tell them. They will help you out, I'm sure. It is possible you also have air trapped in the loop or an issue with the pump. Unlikely but I've seen it. Good luck! Also, your temps don't actually sound that bad imo. You might get a replacement and they will be identical. If there's no throttling with the fan at <80%, that's normal operation.
post edited by timmyboy04 - Saturday, May 13, 2017 7:45 PM
cyberdimensions
Saturday, May 13, 2017 7:47 PM
Ok so I just did some extended testing using Rise of the Tomb Raider at 1440p completely maxed out, even using SSAA 4x. I put +350 on the memory and +150 on the Core (I can benchmark at +165 and +400) but I just wanted to keep it reasonable with Power and Temp at the max settings. After a half hour of game play the temp sensor on the motherboard were all at around 50C, the cpu was in the 45 to 55C range with the fans (4 ML140 in push pull) spinning at a lazy 800 rpm, both cards maxed out at 63C and averaged 1949 Mhz throughout gameplay. The ML120s on the cards were at 1800 rpm, and the cards fans were at 40%. So as far as fan speeds goes, that was pretty conservative and nice and quiet. I am not getting temps in the mid 40s, but I really wasn't expecting it either, especially since my computer sits in an area that is anything but optimal for airflow. All in all, I am pretty happy. Just goes to show, your temps vary big time, you can't just pick a number out of a forum and expect to get the same thing, there's just too many variables.
- Ribbons : 282
Saturday, May 13, 2017 7:54 PM
timmyboy04 Can we stay on track here please...For the OP's sake. OP: If you're positive your TIM application is good and everything is mounted well, I would just suggest playing with your fan curves until you find a sweet spot. IT TAKES TIME. I have found 60-80% max on the fan curve is the sweet spot at high load. after that it's diminishing returns and WAY too loud. If you are still unsatisfied, contact EVGA customer service and tell them. They will help you out, I'm sure. It is possible you also have air trapped in the loop or an issue with the pump. Unlikely but I've seen it. Good luck! Also, your temps don't actually sound that bad imo. You might get a replacement and they will be identical. If there's no throttling with the fan at <80%, that's normal operation.
True, I am still waiting for an Image from Germs666 of his Rig to see how it is laid out.
TRClark911
Saturday, May 13, 2017 8:44 PM
GTXJackBauer
Heh... well I don't think he's a PC god. In fact, I've probably watched less than 5 of his videos total. The one I did watch (after being told by like 8 different people that having my CPU rad at the front blowing air into the case was a bad idea despite the fact I saw at least 25 different rigs with said setup LOL) had him running tests with the various different setups to check for thermals... ... and the rad blowing air into the case with ambient temps a lot warmer than mine literally increased his temps by 1C vs the other config. That's all I was pointing out. I've seen a few of Linus videos as well. Useful information no doubt but I'm definitely not one of those "OMG I gotta see what Jay says!" people.
talkischeap
Sunday, May 14, 2017 0:47 PM
cyberdimensions Ok so I just did some extended testing using Rise of the Tomb Raider at 1440p completely maxed out, even using SSAA 4x. I put +350 on the memory and +150 on the Core (I can benchmark at +165 and +400) but I just wanted to keep it reasonable with Power and Temp at the max settings. After a half hour of game play the temp sensor on the motherboard were all at around 50C, the cpu was in the 45 to 55C range with the fans (4 ML140 in push pull) spinning at a lazy 800 rpm, both cards maxed out at 63C and averaged 1949 Mhz throughout gameplay. The ML120s on the cards were at 1800 rpm, and the cards fans were at 40%. So as far as fan speeds goes, that was pretty conservative and nice and quiet. I am not getting temps in the mid 40s, but I really wasn't expecting it either, especially since my computer sits in an area that is anything but optimal for airflow. All in all, I am pretty happy. Just goes to show, your temps vary big time, you can't just pick a number out of a forum and expect to get the same thing, there's just too many variables.
Yep.. first day i got mine my room temp was 60 F that night and my temps maxed at 50C. Today it was 76F in my office after playing Mass Effect for 1.5 hours and the card hit 63C. Big jump just due to ambient temps. FE cooler would have throttled like a you know what just to keep below 80C
- Ribbons : 135
Sunday, May 14, 2017 1:08 AM
I understand where you're coming from and I considered that...However I had a compromise that seems to work out. Originally, I had my H100i V2 as intake on the top of the case. So what I did was flip that to exhaust, then have the Hybrid as intake at the top rear of the case. So basically that warm air just gets sucked right out via the CPU cooler. So, along with the two 140mm intake fans... Net result maybe at degree or two higher on the CPU (which never gets past 50C or so anyway unless using IBT) and a cooler GPU which is going to have the most impact gaming. Either way, it's a preference and dependent upon your case layout fans...etc etc.../
post edited by HeavyHemi - Sunday, May 14, 2017 1:15 AM
Germs666
Monday, May 15, 2017 2:16 PM
http://imgur.com/IYnyoYI Using a Corsair 400C with 5 fans in front as intake. 2 Top fans are set to exhaust. Hybrid card is using 2 ML120's in push/pull as exhaust. I might try switching them to intake if I have time.
post edited by Germs666 - Monday, May 15, 2017 2:23 PM
Notwist
Monday, May 15, 2017 2:21 PM
What's wrong with 60C temps? That sounds fantastic assuming that's under load.
Germs666
Monday, May 15, 2017 2:39 PM
Notwist What's wrong with 60C temps? That sounds fantastic assuming that's under load.
I think 55C is the max I can go before my card throttles below 2000mhz. Trying to keep my card below that temp since I see others under 50C.
Notwist
Monday, May 15, 2017 2:43 PM
I am fairly certain the throttling point for 1080 ti is far above 60C, considering 1080 was around 80C. Also: you see others under 50C because either: a) they are posting their temps after having their system on for only 5 minutes, which is going to result in abnormally low temps since the liquid in the CLC hasn't really heated up yet. or b) their fan speed is stupidly high and they don't care about the noise because they play with headphones or whatever I tried a 1080 Hybrid FTW last generation because I valued silence under load, and ran an F12 iPPC fan (24V) at about 40%, which equated to about 1000RPM or so. Once I got it so that stock overclock (out of the box on FTW series) held at 65C after 40 minutes or ultra settings Unigen Heaven, I called it a day.
post edited by Notwist - Monday, May 15, 2017 2:48 PM
nycalex80
Monday, May 15, 2017 2:46 PM
Germs666
your card throttles at 55c? My overclock: 149core and 350 memory. Good for around 2050 clocks on stock fan, my hybrid was topping out at 52 degrees. i swapped to a nb eloop and temps are topping at 70 degrees, but even at 70 my card is not throttling at all. throttling usually starts around 82~84 degrees if i'm not mistaken. that is around the temp that my 1080ti FE stock was getting throttled.
Main Gaming Rig: Be Quiet! Dark Base Pro 900 orange edition Asus ROG maximus viii hero I7 6700k @ 4.5 1.26v NZXT Kraken X62 cpu cooler 32gb Gskill trident Z Evga supernova P2 1000w Evga GTX 1080 TI + evga hybrid kit. 2025 OC. 500 gb samsung 960 Pro nvme ssd 500gb samsung 850evo x 2 in raid 0 Hitachi X300 6tb HDD WD black 2tb absolutelly ZERO cable management (i'm too lazy)
Germs666
Monday, May 15, 2017 6:44 PM
http://imgur.com/SXXlXnN The max voltage drops as the card heats up. I'm guessing that's boost 3.0. So If I can stay in around 55C instead of 60C I'd be above 2000 mhz.
- Ribbons : 135
Monday, May 15, 2017 7:26 PM
Notwist I am fairly certain the throttling point for 1080 ti is far above 60C, considering 1080 was around 80C. Also: you see others under 50C because either: a) they are posting their temps after having their system on for only 5 minutes, which is going to result in abnormally low temps since the liquid in the CLC hasn't really heated up yet. or b) their fan speed is stupidly high and they don't care about the noise because they play with headphones or whatever I tried a 1080 Hybrid FTW last generation because I valued silence under load, and ran an F12 iPPC fan (24V) at about 40%, which equated to about 1000RPM or so. Once I got it so that stock overclock (out of the box on FTW series) held at 65C after 40 minutes or ultra settings Unigen Heaven, I called it a day.
Or, we're just reporting our temps. I played BF1 for about 2 hours last night at 4K. After Burner had my peak GPU temp at 49C. This is with a +130 on the core +350 on the memory and +66% voltage. This was with a single 120mm fan as I listed running at 95% (about 1300 RPM) and is inaudible above the noise of my WD RE blacks. So, I disagree with your characterization that we're rubes running stupidly high fans speeds... wearing headphones... and being dishonest about load temps.
