- Ribbons : 271
![](//www.evga.com/community/modsRigs/images/sm_mods_off.gif)
Re: Gigabyte confirms that next-gen GPUs will require a new 16-pin power cable or an adapt
2022/02/22 12:22:38
Michapolys
ty_ger07 The minimum required amperage rating per working pin of a 6-pin plug is less than the minimum required amperage rating per working pin of a 8-pin plug. Each have the same number of pins which do actual work, but the minimum quality requirement of the 8-pin plug is higher. In order to meet a 450 watt rating for the adapter, it must use three 8-pin plugs. It's a matter of standards. I don't know what is causing confusion.
No. Just no. On both 6-pin and 8-pin pcie plugs each pin is specified for 75 watts minimum each.
That's funny. Can you provide a source? You are also the only one stating that the hypothetical adapter has a 450 watt rating.
There are news articles every day with manufacturers announcing these adapters with a 450 to 500 watt rating. The problem is that instead of just answering any questions thrown at you, you use conversation derailing tactics by using a combination of deflection, projection and world salad with some catchy keywords thrown into the mix.
I am answering you. Most questions at least. The question of why 3 instead of 4 or 2 was just insane. It doesn't need to be answered. Serious questions only.
- Ribbons : 123
2022/02/22 12:40:19
Amphenol ICC(excerpt) Amphenol ICC introduces the Gen 5, Minitek ® Pwr PCIe ® connector system. This new introduction CEM 5.0 PCI Express ® 12VHPWR auxiliary hybrid connector and cable assembly support the 600W GPU cards. The 12VHPWR connector is not designed to mate with legacy PCI Express ® 2x3 and 2x4 12V Auxiliary Power connectors. The 12VHPWR connector power pins have a 3.00mm pitch, while the contacts in a legacy 2x3 and 2x4 connector lie on a larger 4.20mm pitch. New PCIe ® Connector System (CEM5) is designed for power applications with current rating upto 9.5A/pin (12 pins energized) and the 4 signal pins supporting signal transmission. - Rated current up to 9.5A per contact with all 12 power contacts and 4 Signal contacts
- Fully isolated terminals
- Positive locking on housing with low thumb latch operation
- Low level contact resistance: 6mΩ max.
Amphonal Applicable wire size (spec Power wire 16 AWG) PCIe 5.0 Is Ready For Prime Time | Tom's Hardware (excerpt, found under --> Minitek Pwr CEM-5 PCIe Connector System (Image credit: Amphenol ICC) Each power contact is rated for 9.2A, delivering up to 55.2A of continuous power via a 12V rail. Theoretically, the 12VHPWR power connector is good for up to 662.4W. However, it officially supports up to 600W. Amphenol ICC (via Olrak) has already listed the 12VHPWR power connector, which the brand has dubbed as the "Minitek Pwr CEM-5 PCIe Connector System." The company specified 9.5A per power contact, which is slightly higher than Igor's information. Amphenol ICC confirmed that the connector is designed for 600W graphics cards.
![](https://folding.extremeoverclocking.com/sigs/sigimage.php?u=706786&c1=#FF008000&c2=FFFFFF&c3=00000&c4=00000) When someone does not use reason to reach their conclusion in the first place; you can't use reason to convince them otherwise!
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2022/02/22 19:41:21
Cool GTX Amphenol ICC (excerpt)
Spoiler
close
So how does a three 8 pin connection feed into a 16 pin connection? It clearly states it “is not designed to mate with legacy PCIe connectors” so the entire question still stands. Why is gigabyte saying 24 connectors will be required? Will a PCB connection be involved to transfer from three 8 pin connections to a mini 16? Will these new PSU’s only be able to utilize a single pci 5 connection due to incompatibility with old cables, or will the PSU manufacturers just try to hide the fact they are only using the dual 8 pin connections like NVidia already does? These are the answers I would like to see in schematics, because currently it states the old 8 pin connection are not compatible with the new connection, and that limits using older PSU’s with new GPU’s
post edited by the_Scarlet_one - 2022/02/22 19:45:34
2022/02/22 20:45:26
Watch the personal attacks guys. Thanks.
kram36
The Destroyer
- Ribbons : 72
2022/02/23 01:08:20
Miguell well.. with the price power of electricity rising every year...
No kidding and people want electric vehicles. The price of electricity is going to be bonkers, heck my house is already at $0.1629431078249269/kWh last time I checked.
Gamer-Monk
2022/02/23 05:39:29
The way I look at it is the 12-PIN needs 850W or higher power supply. 750W and under = 2 x 8-PIN 850W and over = 3 x 8-PIN Using 2 x 8-PIN from a 850W should be OK still 850W. Using 2 x 8-PIN + pigtail (2 + 1) is still 750W.
- Ribbons : 86
2022/02/23 05:59:00
Gamer-Monk The way I look at it is the 12-PIN needs 850W or higher power supply. 750W and under = 2 x 8-PIN 850W and over = 3 x 8-PIN Using 2 x 8-PIN from a 850W should be OK still 850W. Using 2 x 8-PIN + pigtail (2 + 1) is still 750W.
Glad I'm using a 1000 watt PSU
Michapolys
2022/02/23 09:04:58
My guess is that PSU manufacturers will start releasing dedicated modular cables with 12vhpwr outputs that plug to the 8-pin inputs of the PSUs.
Most modern modular PSUs seem to use hcs terminals for their modular cables, at least on the PSU, so you could just use cables with two 8-pin connectors to one 12vhpwr connector.
Then there are the transient response requirements. Just because the cables work without overheating does not mean that the PSU can handle these GPUs without shutting down or frying GPUs. Personally I expect to see in-cable capacitors on at least some of the dual 8-pin to 12vhpwr cables. We shall see... eventually.
Nereus
Captain Goodvibes
- Ribbons : 58
2022/02/23 10:12:18
kram36 No kidding and people want electric vehicles. The price of electricity is going to be bonkers, heck my house is already at $0.1629431078249269/kWh last time I checked.
Just checked ours.. $0.164603/kWh + a list of surcharges every month. Last month was the highest power bill we've ever had for this time of year.
the_Scarlet_one
- Ribbons : 79
2022/02/23 10:24:04
$0.120900 currently where I am.
- Ribbons : 123
2022/02/23 13:34:47
the_Scarlet_one
Spoiler
close
It appears to me that the adapter (cant find any details) will be limited to 450W ..... this is a standard load for (3) 8-pin PCIe power cables The only way to get the 600W from that 12-pin ... those 4 signal wires - require that signal to boost the power from the PSU .... there is no mention if the GPU will also be limited to 450W without signal on those 4 "magic wires" (excerpt OP link) "In order to comply with the 600W specs, the cable needs to have 12 wires for the current and 4 data paths for the signal. The data connectors ensure that the connection has been established and the card actually requires more than 450W of power. In case those data signals are not present, the power supply will feed up to 450W of power."
bill1024
- Ribbons : 65
2022/02/24 12:09:03
Electric went up to 0.22KWH + 0.09 cent delivery charge. Was 0.06KWH + 0.06 cent delivery charge about 6 months ago. I love NY. Not so much any more.
kram36
The Destroyer
- Ribbons : 72
2022/02/24 12:30:39
bill1024 Electric went up to 0.22KWH + 0.09 cent delivery charge. Was 0.06KWH + 0.06 cent delivery charge about 6 months ago. I love NY. Not so much any more.
Yikes! You should post this info here. https://forums.evga.com/Inflation-m3531013.aspx
