Hi,
I am running a EVGA GTX 780 Ti SC acx 2.0 card. In the last week or so I've been seeing artifacts while playing FFXIV so before I assume it's the card or the game I figured I would try to run some tests. I don't know much about video cards but I downloaded Precision X and OC Scanner to run the tests and help monitor temps etc.. What I'm finding when I run the various particle and other tests is that my card temperature will reach 80c or higher and my fans will still be setting at the idle speed of 38%. I always assumed the fans would ramp up as the temperature rose. I know I can set the fans faster but for noises levels I would prefer, if possible, for the fans to ramp up when the temps go up.
Does anyone know if this is a setting or a problem with my card? I'm not 100% it's the heat issue but if the fans don't change from the idle speed I could see that being a problem in a graphic heavy game like FFXIV.
Thanks
