oneofusjustin
just installed my evga gtx1080ti and i cant get it into 144hz tried everything, never had this issue before. since this thing doesn't have dual link DVI I am using the DVI to display port adapter that came in the box with the card. Please don't tell me EVGA cheaped out on the adapter and it is only standard dvi i will honestly start crying.
Xantac
Re: GTX 1080ti wont go to 144hz in monitor settings, help?
2017/03/31 15:07:34
What inputs does your monitor have?
- Rig 1: Rampage5/w 6850K g.skill 3200 cas15 16gb, High-speed PC HPTX Bench w/ GTX 980
- Rig 2: RIVE/3930k /w Koolance mobo/cpu blocks/16gb 2133 c9, EVGA 1080 Ti Sli EK Nickel Blocks & a 78MH/s Eth
- Rig 3: asus rog crosshair vii hero (wi-fi)/2600x, g.skill 3200 cas15 16gb, gt 730
- Acer Predator Monitor
- Xantac's Heatware
oneofusjustin
2017/03/31 15:08:52
BenQ XL2411Z hdmi, vga, dvi-d
Zenaa
2017/03/31 15:11:52
I read someplace the adapter will only go to 60hz I think you need to use the display port for 144hz my ti fe is runnung at 165hz on a asus rog not sure if hdmi goes to 144hz, it might
- Ribbons : 135
2017/03/31 15:12:01
oneofusjustin just installed my evga gtx1080ti and i cant get it into 144hz tried everything, never had this issue before. since this thing doesn't have dual link DVI I am using the DVI to display port adapter that came in the box with the card. Please don't tell me EVGA cheaped out on the adapter and it is only standard dvi i will honestly start crying.
You are correct. You must use an ACTIVE adapter to get 144hz. EVGA isn't going to put a $40 dollar adapter in there...
2017/03/31 15:14:58
oneofusjustin
2017/03/31 15:15:08
why not, they are overcharging $40 bucks for the hybrid cooler LOL sorry couldn't resist, seen you white knighting in the other threads.
oneofusjustin
2017/03/31 15:17:54
Zenaa
2017/03/31 15:19:06
wow that amazon link says $90 for a adapter for that much i would just buy another monitor with a DP for gaming and use the old one for the net or whatever
2017/03/31 15:19:53
- Ribbons : 135
2017/03/31 15:20:52
oneofusjustin
I was being generous....they are more than double that...$80-$90. DVI is a declining interface. But I could use the other guys argument and ask why you're complaining if you can afford $700 dollars for the 1080 Ti bauble...
Hillguy
- Ribbons : 10
2017/03/31 15:28:51
eVGA RTX 3090 Kingpin Hydrocopper | eVGA X299 Dark | Intel i9 10980XE | Heatkiller IV CPU Block | 32 GB GSkill Trident Z 3200 | 500GB Samsung 860 Evo | Dual Corsair AX1200i PSU's | Dual Koolance RP-1000 Pumps | Dual Koolance EHX-1320 4x120mm Rads | W10 | Asus PB278Q | Acer 20" | Razer Death Stalker | Razer Death Adder | Thermaltake Armor+
oneofusjustin
2017/03/31 15:31:49
Hillguy Looks like someone did not do their homework
thanks for the INFO, RIP me. insane that the most popular brand of monitors for one of the most popular online games (csgo) is not supported by an nvidia card. Return incoming.
Hillguy
- Ribbons : 10
2017/03/31 15:39:20
Glad to help , no need to cry , you'll only get a headache
rla1999
2017/03/31 16:00:14
I have read on different forums a lot of people having this issue. Not sure why the proper adapter was not added so all monitors still worked. I don't have the issue now but had the same benq monitor mentioned. Its a great gaming monitor and not that old. It's terrible you ll now have to get an adapter if you decide to keep it.
Chassis: Cooler Master HAF X (Blue Edition) CPU: I7 5930K MB: Gigabyte X99 Gaming G1 RAM: 64GB's Corsair Vengeance LPX DDR4 2666MHz GPU: GTX 1080 TI FE PSU: 1000W Rosewill Extreme SSD: 480GB Kingston HyperX SATA III 6GB/s HDD: 2TB Seagate Barracuda + 4TB Western Digital MONITOR: Acer Predator XB271HU OS: Windows 10, Version 1607 [/
- Ribbons : 135
2017/03/31 16:11:55
rla1999 I have read on different forums a lot of people having this issue. Not sure why the proper adapter was not added so all monitors still worked. I don't have the issue now but had the same benq monitor mentioned. Its a great gaming monitor and not that old. It's terrible you ll now have to get an adapter if you decide to keep it.
Because the 'proper' adapter costs a significant fraction, ~10-15%, of the end item cost to end user...to everyone who purchased, not just the few who need it. So either the seller eats the cost or they pass that cost on to the consumer. If it was your standard $5 dollar dongle, I agree.
oneofusjustin
2017/03/31 16:17:26
i agree i don't expect them to ad in an adapter at that price, however i highly doubt that's anywhere near the actual production price of the adapter. I think the main issue is killing of dvi-d, sort of pulled an apple here and killed it off to early, this monitor isnt even a year old. However, my 8 year old ultrasharps have display port so i guess the blame goes to benQ here, i knew there was no DVI on the card, but i also never in my wildest dreams imagined a monitor i bought last year wouldn't have display port!
rla1999
2017/03/31 16:28:54
you make a valid point. But I wonder the true number of users who actually will have this issue. Based on what I have seen in forums, it seems to be growing as the 1080 TI s are purchased. Granted, they should have checked the specs before buying but still, the number is growing.
rla1999
2017/03/31 16:37:16
oneofusjustin
You can add this to your "lessons learned" bucket and move on. Right now, I would get the adapter since playing at higher than 60 FPS and closer to 144 is a big difference. Not many people get to buy a $699 GPU so enjoy it.
somethingc00l
EGC Admin
- Ribbons : 11
2017/03/31 16:45:15
howdy2u2
- Ribbons : 6
2017/03/31 17:00:15
somethingc00l
EGC Admin
- Ribbons : 11
2017/03/31 17:38:46
howdy2u2 Refurbished maybe?
Probably, but beside the point. They were trying to make it seem like the 1080ti getting rid of the DVI port was too early as a year ago year monitors came out that require DVI-D. I'm just pointing out that is not true, I don't know of any recently released high refresh rate monitors that require DVI-D. The industry has moved on to DP, and thus EVGA not including a dual link DVI adapter makes perfect sense.
Nereus
Captain Goodvibes
- Ribbons : 58
2017/03/31 22:05:34
Sounds like a good excuse to sell your monitor and buy a new one with DisplayPort. ;) Kind of surprised BenQ didn't put a DisplayPort on that monitor though.
oneofusjustin
2017/03/31 22:08:58
Nereus Sounds like a good excuse to sell your monitor and buy a new one with DisplayPort. ;) Kind of surprised BenQ didn't put a DisplayPort on that monitor though.
https://www.newegg.com/Product/Product.aspx?Item=0JC-0004-00551 got this in the cart now... looking for a reason not to pull the trigger.. but I'm getting itchy...
demon09
2017/03/31 22:11:27
Sorry if this has been answered allready. but a non active display adapter like the one sent with all 1080ti Fe's will only run up to 60hz. Should have pre ordered the SC black if you wanted dvi d dual without an active adapter
post edited by demon09 - 2017/03/31 22:15:53
hasler74
2017/03/31 23:33:01
Have you tried the hdmi. I am not sure what version you monitor has but that should run it to at least 120.
warrior10
2017/04/01 00:39:08
rla1999
For once in 10+ years, i also did not do my Homework lol. I can't whine or complain about that fact because i always have looked at the Specs for Anything for such a long long time, and is very rare for me to forget my place in the history of new Gpu's like this. When i heard about this from my Tech friend, as i couldn't believe my stupidity, and thought i had just forgotten' about something that would have been right in front of me. But when he started looking at my new Gpu and couldn't do 144htz anymore, he was confused to. Well, now i need to find a nice New G-sync Cheap 1440p monitor that will work for a long time with good specs. ;/
My new https://www.gigabyte.com/...70-Gaming-K7-rev-10#kfHAF-X Coolermaster: 4 Fans New Rig:Ryzen 1700 CPU-H100i Liquid arctic Cooled. 16gigs Corsair Vengeance DDR4-2400 180Ti Hybrid Blu-ray drive SCSI CDRW-RW drive SCSI Black WD Black caviar 2-1TB's and 1 500gig WD Blue 1 TB 1 Sand disk SSD 240 for OS Corsair PSU 1020 SWTOR Mouse and Headset Razer CHROMA Keyboard Dell 1444p G-Sync Monitor @144htz to 160htz
rla1999
2017/04/01 04:54:45
rla1999
2017/04/01 05:02:33
warrior10
rla1999
More and more people will come out to complain as you as they get their 1080 TIs since this is not something people tend to look for. when i heard an adapter was included I immediately thought ok. it makes sense to get rid of that DVI port. I am in my 40s now so I am more careful when buying things but in my 20s and 30s, i would not hesitate to make big purchases without checking all the specs and fine print.
warrior10
2017/04/02 05:45:18
What the hell, i never complained about it. Next times READ the Post before commenting, or just don't would be better. I said i can't whine because i didn't do my homework on the Ti. I got a New monitor, but even if i hadn't you best be more careful about what and how you say things. You are the one who was whining and complaining.
