Re: GTX 1080 TI FTW3 - max power consum 63% 170 watt and only power limit
2018/07/14 09:34:27
Did you run the crap out of the card to test it at least before mounting the hybrid kit? If so did you have this problem before?? Thinking you did and you didn't have this problem cause you score were much higher and normal before..
Most likely it's the classic problem of the kit and you'll now need to rma both the card and kit to evga. Let them know its another faulty hybrid kit issue that's well known.
Cant just rma the card as the next one will have similar issues once you install that same faulty hybrid cooler again.
Asus Z390 ROG Extreme XI MB
