Helpful ReplyGEFORCE GTX 1660 power connection
nails55
2019/11/13 10:23:45 (permalink)
 Hi all it's been awhile,  Just purchased a GTX 1660 card to install in my older system. The problem i have is my psu only has two 6 pin pci express power cables and the new card requires an 8 pin cable. Is there an adapter i can purchase that will make them compatible and does it make sense or should i just buy a new power supply?
 Thanks in advance.
ASUS ROG STRIX B560-A [motherboard]
EVGA RTX 3080 12G-P5 4868-KL [graphics]
INTEL I5-11400 2.6GHZ 12MB CACHE LGA1200 [processor]
CORSAIR DDR4 2X16GB 3600MHZ VENGEANCE PRO [memory]
SABRENT ROCKET 4 PLUS M.2 PCIe GEN4 X4 NVMe 1TB [Hard drive]
 EVGA 850 GQ 210-GQ-0850-V1 [power supply]
ANTEC DP502 FLUX DARK PHANTOM  [case]
SAMSUNG G9 ODYSSEY C49G97TSSN  [monitor]
WINDOWS 11 HOME 64 BIT [os]
bob16314
  • Ribbons : 761
Re: GEFORCE GTX 1660 power connection 2019/11/13 11:47:34 (permalink) ☄ Helpfulby nails55 2019/11/13 12:44:13
EVGA used to include a Dual 6-pin to 8-pin Adapter in the boxes up until the 10-series cards, then I guess they started cheapin' out.
Many places that sell PC parts/accessories have those adapters..Pick one up somewhere..But I can't imagine your Thermaltake Toughpower 850W not coming with an 8-pin PCIe power cable, look in the cable bag or box or whatever.
bob16314
  • Ribbons : 761
Re: GEFORCE GTX 1660 power connection 2019/11/13 12:49:23 (permalink)
There may be a 6+2 pin cable/connector that came with your PSU instead of a solid 8-pin connector..Just add the extra 2-pin part to the 6-pin part to make an 8-pin.
Re: GEFORCE GTX 1660 power connection 2019/11/13 13:01:31 (permalink)
+1 to what bob said.
nails55
Re: GEFORCE GTX 1660 power connection 2019/11/14 05:13:50 (permalink)
Thanks, ordered a cable from amazon.
post edited by nails55 - 2019/11/14 05:16:15
  • Ribbons : 123
Re: GEFORCE GTX 1660 power connection 2019/11/14 05:43:15 (permalink)
Which TT 850W TOUGHPOWER PSU ?
blubberduck86
Re: GEFORCE GTX 1660 power connection 2023/08/21 16:32:29 (permalink)
bob16314
OMG thank u!
I tried to use the 8 pin connector that came with my Corsair 750w PSU "CX750M" but for some reason it wouldnt allow my machine to boot up, then after reading your post i tried adding the extra 2 pin and voilla! lol now i can actually get a decent frame rate with Halo Infinite at 5880x1080p 60Hz...
