GALAX Announces GPU Overclocking Products - Power Board and LN2 Memory Radiator
  • Ribbons : 84
2017/08/16 22:59:38 (permalink)
https://www.techpowerup.com/236200/galax-announces-gpu-overclocking-products-power-board-and-ln2-memory-radiator
If you are into LN2 overclocking then Galax has some interesting items for you. These items will allow you to take overclocking to a whole new level (supporting a temperature range of +1083°C to -268°C).
3 Replies Related Threads
    Hoggle
    Re: GALAX Announces GPU Overclocking Products - Power Board and LN2 Memory Radiator 2017/08/16 23:45:09 (permalink)
    Isn't 1083c the point that copper starts to melt also on the cold size that is pretty close to absolute zero which would be -273F. Pretty extreme but not sure I trust a product that lists it's highest thresh hold being the exact point that it would melt.
    • Ribbons : 270
    Re: GALAX Announces GPU Overclocking Products - Power Board and LN2 Memory Radiator 2017/08/17 00:52:19 (permalink)
    Hoggle
    Well, yeah, it is just a fancy container with no moving parts which will remain as a container until its material limits. Such bad advertising.
    PietroBR
    • Ribbons : 7
    Re: GALAX Announces GPU Overclocking Products - Power Board and LN2 Memory Radiator 2017/08/17 05:13:54 (permalink)
    Noob question.
    Does DDR memory really need LN2 for extreme overclock (example, for overclocking a CPU, not the memory itself)?
    Case: Asus Z370-G Box / MB: Asus Z370-G / CPU: Intel I7 8700K / Mem.: 16GB (2x8) 3000Mhz Corsair Dominator Platinum DDR4 / GPU: GTX 1080TI FTW3 / A.I.O. W.C: EVGA CLC280 / PSU: EVGA SuperNOVA G3 750W
