Flow Control is randomly crashing, causing my CPU to overheat.
tcblack
2017/12/01 14:14:45 (permalink)
I've got a CLC280 sitting on my Ryzen 7 1700x under a full cpu load 24/7 trying to find a cure for cancer  (Help cure cancer here: ).
Randomly, EVGA flow control will crash - typically I don't notice it till the LED on my EVGA CLC280 changes color, since I have it set to temp color for the fluid.
Last night it crashed again, my fans on my radiator turned off and I came in this morning to find my CPU Tdie at 87C!!! That is not the artificially inflated Tctl.  This afternoon my Tdie hit 89C.
  • EVGA FLow Control v2.0.4.0
  • Firmware version 2.10.0.0
  • Windows 10/64bit
What can I do to stop this from crashing?  There are no logs telling me why.  Got a beta I can test? Please help me keep from burning my computer up, don't make me fork over money on a cooler with better software.
9 Replies Related Threads
    Phil2940
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/02 11:54:38 (permalink)
    return your clc280....
    better than burn your CPU
     your T° are not normaly   im at 55°C with I 4770k OC 4.3Ghz on burn
    Asus Z87 A
    I7 4770 OC 4.3ghz : reveal information :57 °C on Flow control , 53°C on Asus AI suite III on full a the same time on burn  ****
    Corsair LED Vengeance 16GB rated 1600
    EVGA AIO CPU Closed Loop Cooler CLC 120
    GTX1060  ICHILL  (60°C on full)
    IN WIN 805C
    2x 120mm Corsair fans front intake
    2x 120mm  Corsair on bottom intake
    1x 120mm In Win fans back side exhaust
    Windows 8.1  64
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/02 13:59:25 (permalink)
    Phil2940
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/02 22:41:17 (permalink)
    you re differents softwares are never function on custom for me:
    https://forums.evga.com/F...-m2715611.aspx#2716540
    it function only by default since 6 month
    Asus Z87 A
    IN WIN 805C
    Windows 8.1  64
    Phil2940
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/02 22:45:34 (permalink)
    tcblack:
    are you sure you have well instal the pump and there a good conexion pump/CPU..???
    Asus Z87 A
    IN WIN 805C
    Windows 8.1  64
    tcblack
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/05 06:49:21 (permalink)
    Phil, I guarantee that it is properly installed.  Until the software crashes, I can keep a fully loaded CPU below 40C at full throttle, at mid throttle I can keep it around 60C.  It is the software.  In fact I just realized it has crashed again on me.  Darned unstable.
    chrisdglong
    • Ribbons : 7
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/05 21:31:58 (permalink)
    Do you have to have the software running for the fan profiles to run? Wow, if that is the case I am sticking with Corsair.
    tcblack
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/06 08:11:47 (permalink)
    Chrisdglong,
    I don't think it is supposed to require the software to work - that is why mine is being RMA'd.  I'll post back here hopefully when the new one arrives and I get it set up.
    MSim
    • Ribbons : 38
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/06 14:06:26 (permalink)
    tcblack
    Chrisdglong,
    I don't use any software for my Corsair H100iv2 liquid cooler.
    Phil2940
    Re: Flow Control is randomly crashing, causing my CPU to overheat. 2017/12/07 08:58:35 (permalink)
    MSim
    tcblack
    Chrisdglong,
    welcome to EVGA FORUM
    Asus Z87 A
    IN WIN 805C
    Windows 8.1  64
