hkuspc40
So I posted this in the software forum but got no response so I'll try over here... Is there a way to change the upper limit for cpu temperature in flow control? I don't need my fans at maximum when the processor is at 60c. An overclocked 9th gen processor is over 60c all the time... The "coolant temp" fan curve is useless... I don't even know why they bothered with that. Any help would be appreciated...
Re: Flow Control - Max Fan Speed at 60C
2019/02/21 15:30:35
Welcome to the Forums I'm not sure why your software settings are not working You could plug the fans in to the MB directly - use the MB / CPU Temp to control them What OS - with details ? Which version of the software ? We need & like Rig details
hkuspc40
2019/02/21 15:44:52
I thought about the motherboard route but that would require a splitter I'd need to pick up and tearing apart the top of my build (mini-ITX it's tight in there). The software is working fine, I believe, but I can't grab the upper limit "dot" on the fan curve at 60c. Flow Control Version 2.09 Windows 10 64bit i5-9600K 4.9Ghz @ 1.34v (lost the silicon lottery) Asus Z390i G.Skill Trident RGB 2x8 3200mhz @ cl14 970 Evo Plus 500GB CLC 240 w/ Noctua iPPC 3000 fans EVGA RTX 2080 Blower Seasonic Prime Ultra 750 WD Black 4TB Cougar Vortex RGB Case Fans NZXT H200i
hkuspc40
2019/02/21 15:58:01
Marked the dot with an arrow...
2019/02/21 16:02:16
mini-ITX - that makes it tight for sure Is the CLC Intake What other fans are in the case ? Blowing In or Out
hkuspc40
2019/02/21 16:15:19
Yes CLC is setup as intake with Cougar Fans and blower card setup as exhaust. See pic.
2019/02/21 17:20:22
hkuspc40
2019/02/21 17:30:46
Yeah that's where the image came from. The "custom fan curve" is locked at 60c to 100% fans. None of the points will allow me to set a fan speed lower than 100% past 60c.
2019/02/21 17:41:52
I'm running ver 2.08 on my AIO Folding Rig in my signature Did you try double clicking said marker ? You Must make all lower changes, from left to right --> (you can not go below the previous set point) (if I remember correctly - been months since I changed mine) Might want to try 2.08 I do not see the picture in Post #4
hkuspc40
2019/02/21 17:47:44
I've tried everything to no avail. Are you able to change the last set point in 2.08?
2019/02/21 17:49:44
I'll go check now Its in another room
2019/02/21 17:57:29
Dang ..... I can go to 100% before 60C ---> but not after 60C - On both the fan & pump My CPU is 45 -53 C & I never noticed this before
hkuspc40
2019/02/21 18:31:26
Rough :( My temps are fine at idle but under load I'm above 60c here and there. I hit 95c when running prime95 at 5.0ghz and, yeah, I needed 100% fans there lol.
hkuspc40
2019/02/21 18:33:26
I don't really understand why the decision was made to do that. I can see a minimum to prevent damaging the fans but you should be able to set the upper limits to whatever you want.
2019/02/21 18:41:57
Seems like a "Bug" more than a "Design Feature" I'll bring it up to the person that may be able to see if/when the next rev of the software - this can be addresses Wish I had better News
hkuspc40
2019/02/21 18:48:56
Really appreciate the feedback. It's a little surprising to me that no one noticed that... ;)
2019/02/21 18:51:35
PM has been set to EVGA Hope to hear back in the next several days - if this can be changed Plan B: splitter or Fan hub to MB Note: I see you photo now in post #4
Cordorb
2019/02/26 20:33:40
I would guess most of us just use the water temp curve and have pump at 90 or 100 percent can't you still get almost of what you want as a work around just using the water curve ? I don't think the early version of this software even had CPU temp ?
hkuspc40
2019/02/26 20:55:25
The coolant curve is literally pointless for two reasons. 1) There is a lot of lag from the temperature of the cpu to the temp of the coolant. Your cpu may be screaming at a 100c instantly but the coolant hasn't heated up yet. Thus your fans would still be sitting idle when you need to be cooling the coolant as quickly as possible. 2) The scale on the coolant curve doesn't make sense. The coolant temp changes by single degrees not 10 degrees. You'd never be able to set it accurately. If the scale were set at single digits it would be more useful but still pointless because of reason one. Perhaps the EVGA engineers disagree but I couldn't come up with a reason why (and I'm an engineer). Edit: My guess is this really didn't matter until the 9th gen Intel CPUs came out as previous generations of processors wouldn't get so hot. My 4790k overclocked wouldn't ever get over 65c. I can get this 9600k at 95c pretty easily and I'm using Noctua 3000 rpm fans on the radiator. Some reviews I've read haven't been able to keep the new 9th gens cool with AIOs (with an overclock). This is the same reason I replaced the stock fans with those beasts from Noctua. :)
post edited by hkuspc40 - 2019/02/26 21:03:01
coolmistry
- Ribbons : 45
2019/02/27 00:48:58
hkuspc40 So I posted this in the software forum but got no response so I'll try over here... Is there a way to change the upper limit for cpu temperature in flow control? I don't need my fans at maximum when the processor is at 60c. An overclocked 9th gen processor is over 60c all the time... The "coolant temp" fan curve is useless... I don't even know why they bothered with that. Any help would be appreciated...
I got same problem as my one!! I have change the PMW fans which is much better but....have a look my post #19 as no one say why about the fan full speed at 60'c.... It have been over years...
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
Cordorb
2019/03/02 14:43:44
You still have the thermal mass of the system and the water and pumps to handle start up CPU heat. so there is conduction and radiation cooling then convection with the fans kicking in. MY first engineering job was to run 1000 amp at 600 volt into a set of hockey puck size SILICON CONTROLLED RECTIFIER and air cool the system. Thermodynamics was not covered in my engineering classes :-( so a few $500 parts did bite the dust.
Raiff
2019/05/15 23:13:48
Hello Cool GTX and hi everyone, are there any news regarding the 60°C lock issue ? It's really uncool not to be free to choose the fan curve up to, let's say 80°C. Please help. Thanks.
Exigeous
2019/06/22 06:50:04
Add another to the list who's pretty frustrated, err pissed about this. I've had this cooler for a while but just started playing around with overclocking my 8086k and can run 5.0 on all cores really stable - but as soon as it ramps up the fans turn into leaf blowers - setting a hard 60C is really absurd. I suppose at this point there's nothing we can do - I'm going to re-route the two radiator fans to my motherboard CPU plug, I just have to get a splitter to do it (cables aren't long enough). Really (Deleted for Foul Language) as I'd like to use, you know, what I paid for!?!
post edited by XrayMan - 2019/07/08 20:58:28
CaptainApollo13
2019/08/17 11:39:34
I just wanted to add my support to OP, this is an issue that should not even exist and EVGA needs to fix. It should be a simple fix, and there is no reason for them to lock the top of the curve at 60C, no damage can be done until way after that. 90C is a good max.
MSI Z370 Gaming Carbon Intel 8086K with CLC 120 Cooler 16GB Corsair Vengeance RGB EVGA GTX 1080 Ti Black Edition Western Digital Black 500GB M.2 NVME Samsung EVO 500GB SSD Corsair 460X RGB Tower Rosewill HIVE 750w PSU Windows 10 Pro
Exigeous
2019/08/20 16:38:14
Just to add another .02 to this - I added 2 more fans to my radiator, in push/pull config - delided and applied liquid metal to my 8086k and at 5.0Ghz on all cores I'm running at around 50C - under full load, so that's one way to fix the leaf blower! I'm now actually running at 5.3Ghz (seems I got really lucky and got a great chip) at about 70-72C but even still with all 4 fans it's not really loud at all - I did wire the fans directly to the motherboard though so I could control them separately. Just some thoughts.
couped
2019/08/23 18:24:07
Can't change the top most fan speed either. Is there a fix on the way for this?
hkuspc40
2019/08/27 16:28:34
Yeah it's been 9 months (ish). I've given up on an update. Won't be buying anything from EVGA again.
petecis
2019/10/18 18:05:07
I've been able to use Cheat Engine 7.0 and edit the values in the graph to allow the upper most user defined value to be 70C instead of 60C. Unfortunately, I don't have very much experience with cheat engine so I haven't yet been able to make a script or even a code offset to be able to quickly redo this every time the computer starts up. I have to manually edit it. I might go poking around the Cheat Engine Forums to see if there's anyone around who can help out. I dont have a lot of time lately to play around with stuff like this, but I bet there's someone with experience who could do this in a flash. With a fan curve the way I want it, the computer is nice and quiet again. No sudden jumps when a CPU core goes to 60C for a second!
coolmistry
- Ribbons : 45
2019/10/19 02:56:27
petecis I've been able to use Cheat Engine 7.0 and edit the values in the graph to allow the upper most user defined value to be 70C instead of 60C. Unfortunately, I don't have very much experience with cheat engine so I haven't yet been able to make a script or even a code offset to be able to quickly redo this every time the computer starts up. I have to manually edit it. I might go poking around the Cheat Engine Forums to see if there's anyone around who can help out. I dont have a lot of time lately to play around with stuff like this, but I bet there's someone with experience who could do this in a flash. With a fan curve the way I want it, the computer is nice and quiet again. No sudden jumps when a CPU core goes to 60C for a second!
Oh damn good try pal . Everyone got the same problem with fans went loud reach at 60c!! I have change very silent quiet fan which is much better of course left on Auto fans in my CLC software
petecis
2019/10/19 18:57:25
I'll definitely post an update here if I get any farther and am able to make something that everyone can use.
