Answered(Fixed)EVGA GTX 960 SSC Single Fan Problem
Ullrichs
2017/06/08 07:18:58 (permalink)
Hello all,
My problem is my graphics card's only one fan spins. Even if it's under load. I made the fans' load up to 100 with Afterburner but still only one fan spins. How can I solve this problem? Thanks already.
*My drivers are all up to date.
*I've never overclocked my GPU.
*I'm using Windows 10.
Edit: I fixed the problem with spinning the fan manually (with my hand) for one sec. Then I used the app to spin the fans. And both fans were spinning. The problem is fixed.
post edited by Ullrichs - 2017/06/08 07:39:42
quadlatte
  • Ribbons : 56
Re: (Fixed)EVGA GTX 960 SSC Single Fan Problem 2017/06/08 12:24:58 (permalink)
does it restart on its own now after a reboot?
                                             Heatware: http://heatware.com/eval.php?id=72498
Re: (Fixed)EVGA GTX 960 SSC Single Fan Problem 2017/06/08 13:15:39 (permalink) ☼ Best Answerby Ullrichs 2017/06/08 14:02:28
You shouldn't have to spin the fan by hand. Sounds like you're gonna need to rma the card.
Ullrichs
Re: (Fixed)EVGA GTX 960 SSC Single Fan Problem 2017/06/08 13:58:46 (permalink)
I did it just once. Now both fans work fine.
quadlatte
Yes, it does.
Re: (Fixed)EVGA GTX 960 SSC Single Fan Problem 2017/06/08 14:03:38 (permalink)
Ullrichs
Keep an eye on it. The problem will most likely continue to get worse.
Ullrichs
Re: (Fixed)EVGA GTX 960 SSC Single Fan Problem 2017/06/08 17:07:50 (permalink)
Okay. I will. But I don't have to do use my finger first to spin the fan. It spins when it's needed. I mean both of them work fine. But I will keep an eye on it like you said.
