Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X
twentyfourimages
2018/05/20 22:19:59 (permalink)
I just had this system built by AVADirect:
  • MasterCase Series MC500M Tempered Glass, No PSU, E-ATX, Black/Grey, Mid Tower Case
  • X399 GAMING PRO CARBON AC, AMD X399 Chipset, TR4, ATX Motherboard
  • Ryzen™ Threadripper 1950X 16-Core 3.4 - 4.0GHz Turbo, TR4, 180W TDP, Processor
  • GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X, Graphics Card
  • 32GB Kit (4 x 8GB) HyperX Fury DDR4 2666MHz, CL16, Black, DIMM Memory
  • 850 GQ, 80 PLUS Gold 850W, ECO Mode, Semi Modular, ATX Power Supply
  • Liqtech TR4 240, 240mm Radiator, 500W TDP, Liquid Cooling System
  • Arctic Silver 5, 12g, High-Density Polysynthetic, Silver Thermal Compound
  • 250GB 960 EVO 2280, 3200 / 1500 MB/s, V-NAND, PCIe 3.0 x4 NVMe, M.2 SSD
  • 2 x 500GB 860 EVO 7mm, 550 / 520 MB/s, V-NAND MLC, SATA 6Gb/s, 2.5-Inch SSD
  • 3 x 2TB Blue WD20EZRZ, 5400 RPM, SATA 6Gb/s, 64MB cache, 3.5-Inch HDD
  • WH16NS40, BD 16x / DVD 16x / CD 48x, Blu-ray Disc Burner, 5.25-Inch, Optical Drive
    I noticed the fan on my graphics card doesn't spin.
    Does this fan only spin under extreme loads?
  • #1
    5 Replies Related Threads
      _JoseR
      Re: Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X 2018/05/20 22:24:36 (permalink)
      Hi Twentyfourimages and welcome to the EVGA forums! The fan on the graphics card, while idling, will stay off until the temperature on the card exceeds 60C or you can manually turn it on with our Precision X OC software.
      twentyfourimages
      Re: Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X 2018/05/20 23:48:05 (permalink)
      Thank you.  So far the temperature hasn't gotten anywhere near that.
      thunder-93
      Re: Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X 2018/05/21 04:23:24 (permalink)
      In XOC, you can also select/set the aggressive fan profile, and it will turn on at lower temps. I also delinked the power fan from the radiator fan.
      v/r Thunder-93 (Affiliate Code: F8CE835X1W)
      i7-8700K / Asus ROG Strix Z370-E / EVGA 1080Ti FTW3 Hybrid / EVGA G3 750W / Thermaltake RGB 360 / TridentZ RGB 32GB DDR4-3200CL14 / 960 Evo / 970 Evo / 860 Evo / Firecuda SSHD / InWin 303C RGB
      • Ribbons : 84
      Re: Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X 2018/05/21 05:04:50 (permalink)
      twentyfourimages
      Does that include when the system is under full load? If so then you have an outstanding build.
      twentyfourimages
      Re: Fan Question - GeForce GTX 1080 Ti SC2 HYBRID GAMING, 1556 - 1670MHz, 11GB GDDR5X 2018/05/21 10:58:17 (permalink)
      Yes, I was running a benchmark 1080p and 4k max details and the fan didn't kick on.  Thought it was malfunctioning.  But the fan does work after I enabled it.  I guess I'll leave it in auto and trust the card knows when to turn it on.
      Just sitting idle, the GPU is 29c Power 34c Mem 32c.  (I think they all got close to 40 but didn't break 40 without that fan on).
