SirJelly
Hello, myself and two of my friends all ordered the 400-HY-5598-B1 kit this week and installed them last night. All three of us are experiencing the fan scraping on the shroud and making noise. One friend it is happening at all fan speeds, myself and the other it only happens when the fan is above 80%. We followed the install instructions to a T. Has anyone else experienced this and is there anything we can do to remedy it? Here is a video of what it sounds like, quite obnoxious. Edit: Forum strips out links for some reason so I guess you'll just have to take my word for it.
post edited by SirJelly - Saturday, July 22, 2017 4:49 PM
- Ribbons : 282
Re: Fan Hitting Shroud on 1080ti Hybrid Cooler Kit
Saturday, July 22, 2017 6:10 PM
Installing mine ATM, Will Post if I See the Same. Yep Mine is a well, bummer. Corrected Issue
post edited by bcavnaugh - Saturday, July 22, 2017 11:19 PM
Goobers
Sunday, July 23, 2017 1:37 AM
bcavnaugh Installing mine ATM, Will Post if I See the Same.
Was it because fan wasn't "level" with PCB? I would imagine that's the most likely cause as if it sits at an angle, it'll be tilted a touch closer to the card shroud.
- Ribbons : 282
Sunday, July 23, 2017 1:41 AM
Goobers
No.
MDeckerM
- Ribbons : 8
Sunday, July 23, 2017 1:50 AM
Hello, You can remove the card and place it fan side up on a wooden table or cardboard to avoid static discharge. Then, place light downward pressure onto the middle of the fan with your index finger and you should feel a bit of play. Press up and down on the center of the fan; this should re-align any bearings that may be causing this issue. If you continue to have the fan noise please let us know.
- Ribbons : 282
Sunday, July 23, 2017 2:01 AM
EVGATech_MDecker Hello, You can remove the card and place it fan side up on a wooden table or cardboard to avoid static discharge. Then, place light downward pressure onto the middle of the fan with your index finger and you should feel a bit of play. Press up and down on the center of the fan; this should re-align any bearings that may be causing this issue. If you continue to have the fan noise please let us know.
I got that tip from another Post that you have given us for guidance, thank you.
O ciN
Sunday, July 23, 2017 4:10 PM
I hope it goes well man, good luck fixing it!
lowrider4sd
Tuesday, July 25, 2017 8:22 PM
My fan is doing the same thing. I got it to clear a little then installed in computer and as soon as the clock went up on the gpu the fan was hitting again. It looks like the fan sits offset of the hole in the shroud. Now what?
- Ribbons : 282
Tuesday, July 25, 2017 8:29 PM
lowrider4sd My fan is doing the same thing. I got it to clear a little then installed in computer and as soon as the clock went up on the gpu the fan was hitting again. It looks like the fan sits offset of the hole in the shroud. Now what?
Read Post #5 above.
MonitorHunter
Tuesday, July 25, 2017 9:12 PM
I posted the same issue over on the other thread (see below). Replacement arrived today. I will take a hard look to ensure everything will work before closing it all up again. Perhaps there is just some poor QC going on with tolerances/ compatibility issues. Startup Startup XXXhttps://streamable.com/4vyly XXXPhoto link included.
lowrider4sd
Tuesday, July 25, 2017 11:04 PM
Tried pushing on the fan and its still hitting, like I said it's like the fan cutout isn't in the correct location
SystemsOgreLoad
Wednesday, July 26, 2017 0:42 PM
Could the screws be too tight on the shroud?
MonitorHunter
Wednesday, July 26, 2017 0:48 PM
SystemsOgreLoad Could the screws be too tight on the shroud?
Actually it's the opposite, got a new hybrid cooler kit today. The screws do not tighten close enough to the PCB and the fan "falls" when tipped upside down. I gracefully tried to tighten, very minimal effort, and one screw stripped the head off. I'll be returning that one. I'll post pictures in a couple minutes.
lowrider4sd
Wednesday, July 26, 2017 1:25 AM
MonitorHunter
Ya the screws they tell you to use have a collar on them that doesn't allow the fan heatsink to tighten to the pcb allowing it to sit cocked and I would imagine it would be able to move around since it isn't really secured. Even if you put the screws that don't have the collar in that location the fan will still rub on the shroud. I have tried to move the shroud away as far as possible and loosen the a hair to give clearance but it still sits close enough to rub. On the pump side of the fan there is plenty of room. I'm done messing with it for tonight, getting tired and don't wanna mess up my gpu.
MonitorHunter
Wednesday, July 26, 2017 2:50 AM
So the screws that hold the fan on are super loose. I let the GPU sit on the box (fan down), then lightly lifted by the PCB to simulate if it were placed into computer and the fan "hanging". This causes the fan to drop and likely fall into the shroud, as seen: XXXhttps://streamable.com/y7ni6 XXX (remove the XXX's) One of my screws for this area wouldn't actually fit into the hole. I took the fan assembly out separately and all other screws were able to be hand tightened into the holes. Likely a threading issue on 1 screw. Took a substitute from previous kit. Loose screws by fan:  Vs. a tight screw near the pump mount: Attempt made to tighten screw on near fan, very gracefully actually... I went ahead and reassembled, and left 2 screws out which pass through the PCB and mount to the shroud. 2 additional screws are supposed to go in the same spot through backplate. Final solution including backplate. It works, no fan hitting shroud. I still think my first shroud was also warped.
post edited by MonitorHunter - Wednesday, July 26, 2017 2:54 AM
lowrider4sd
Wednesday, July 26, 2017 10:42 AM
I was wondering if my shroud was warped also because if I squeezed the sides in a little it would clear the fan. Just looking at it didn't seem to be warped but I will look a little closer after work today. I might try taking the screws out like monitorhunter did to see if that helps.
- Ribbons : 282
Wednesday, July 26, 2017 5:22 PM
lowrider4sd I was wondering if my shroud was warped also because if I squeezed the sides in a little it would clear the fan. Just looking at it didn't seem to be warped but I will look a little closer after work today. I might try taking the screws out like monitorhunter did to see if that helps.
Did you do what is Posted in #5 Above. Yes Remove the Shroud and realign it and make sure your should is UNDER the Back Mount Slot Plate.
post edited by bcavnaugh - Wednesday, July 26, 2017 5:29 PM
- Ribbons : 282
wmmills
- Ribbons : 40
Wednesday, July 26, 2017 5:41 PM
MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW  New EVGA product? Register it NOW with this link: http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII Help Our Vets From K-2! [link=https://strongholdfreedom
MonitorHunter
Wednesday, July 26, 2017 5:51 PM
bcavnaugh In Both Images you used the Wrong Screw! quote]
I assure you this was the screw in the correctly labeled part # bag based upon the instructions.
wmmills
MonitorHunter
I posted the same issue over on the other thread (see below). Replacement arrived today. I will take a hard look to ensure everything will work before closing it all up again. Perhaps there is just some poor QC going on with tolerances/ compatibility issues. Startup Startup XXXhttps://streamable.com/4vylyXXX Photo link included.
Well, this set of pictures you can see that the screw in each picture holding the fan leg down is different. I would think out of the two the top one must be the correct screw cause the 2nd one the fan blade is hitting the side.
I'm not sure if the screws holding the fan to the heatsink are different. Can check again when I get back tonight. The third picture is an entirely different screw location. This screw goes through the PCB and mounts to the pump. One of the included screws did not have threading on it.
post edited by MonitorHunter - Wednesday, July 26, 2017 6:48 PM
- Ribbons : 282
Wednesday, July 26, 2017 5:55 PM
Yes, you have posted this no need to keep posting the images, and did EVGA not correct this with you! You have had your issue resolved in this Thread https://forums.evga.com/FindPost/2697201 by EVGATech_JosephL as far as I can see.
post edited by bcavnaugh - Wednesday, July 26, 2017 6:33 PM
SystemsOgreLoad
Wednesday, July 26, 2017 6:10 PM
bcavnaugh Yes, you have posted this no need to keep posting the images, and did EVGA not correct this with you! Shave a little off the Shroud.
Wouldn't shaving off a bit void the warranty?
- Ribbons : 282
Wednesday, July 26, 2017 6:12 PM
Deleted
SystemsOgreLoad
Wednesday, July 26, 2017 6:14 PM
SystemsOgreLoad
It is only a Year.
Oh okay. That's a pretty short warranty. Honestly with a liquid cooler, I'd rather just send it in if I was OP
- Ribbons : 282
Wednesday, July 26, 2017 6:25 PM
SystemsOgreLoad
SystemsOgreLoad
bcavnaugh Yes, you have posted this no need to keep posting the images, and did EVGA not correct this with you! You have had your issue resolved in this Thread https://forums.evga.com/FindPost/2697201 by EVGATech_JosephL as far as I can see. Deleted
Deleted
Well the OP SirJelly Has not posted wheatear or not his is ok now or if he/she has done what is Posted in Post #5 Above.
post edited by bcavnaugh - Wednesday, July 26, 2017 6:39 PM
SystemsOgreLoad
Wednesday, July 26, 2017 6:27 PM
SystemsOgreLoad
SystemsOgreLoad
It is only a Year.
Well the OP SirJelly Has not posted wheatear or not his is ok now or if he as done what is Posted in Post #5 Above.
yeah that's true. Hopefully it means they got it figured out
- Ribbons : 282
Wednesday, July 26, 2017 6:28 PM
SystemsOgreLoad
SystemsOgreLoad
SystemsOgreLoad
Deleted
Yes, a lot of members never post back say they are or are not fix or they are still having the same issue.
post edited by bcavnaugh - Wednesday, July 26, 2017 6:38 PM
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Wednesday, July 26, 2017 6:32 PM
The fan hits on mine and I will be sending it back. You can believe I am not going to "shave a bit off" and ruin the warranty, just to later risk the pump going bad and not being able to warranty at all. "It's just a year" is not an appropriate response for that part.
- Ribbons : 282
Scarlet-Tech The fan hits on mine and I will be sending it back. You can believe I am not going to "shave a bit off" and ruin the warranty, just to later risk the pump going bad and not being able to warranty at all. "It's just a year" is not an appropriate response for that part.
Deleted that Info. Did you complete what is Posted in #5 above? Mine Fan looks like they are off Centered by 1/16 of an inch but after doing what is posted in #5 above it is not hitting any of the sides of the Shield.
post edited by bcavnaugh - Wednesday, July 26, 2017 7:08 PM
MonitorHunter
Wednesday, July 26, 2017 6:56 PM
bcavnaugh Yes, you have posted this no need to keep posting the images, and did EVGA not correct this with you! You have had your issue resolved in this Thread by as far as I can see.
I cross-posted here initially to let the other users reporting issues I had similar results with my Hybrid. Please go back and read, other than my inital post in this thread all subsequent comments and pictures related to the replacement kit sent by monitorhunter Actually it's the opposite, got a new hybrid cooler kit today. The screws do not tighten close enough to the PCB and the fan "falls" when tipped upside down. I gracefully tried to tighten, very minimal effort, and one screw stripped the head off. I'll be returning that one. I'll post pictures in a couple minutes.
post edited by MonitorHunter - Wednesday, July 26, 2017 6:58 PM
