Re: Evga 750W G2 Power Supply Cable
2018/12/06 20:42:09
bob16314
You should get an AC power cable that's marked 18 AWG or lower..The lower the AWG number, the thicker the wires are in the cable..Do not get a cable with a higher AWG number that has thinner wires in the cable.
An 18 AWG cable is a little marginal if you are pushing that power supply hard - I've had one DIE on a machine that was pulling 700 watts at the wall 24/7 (luckily it didn't take the PS or machine with it).
18 AWG should be fine if you're not pushing the PS that hard on a continuous basis, but I'd go with at least a 16 AWG cable (which is what EVGA provides with the 850 G2 - I don't have any 750 G2 models to check) if you are going to be pushing the PS hard for extended periods.
Now that vorsholk has stopped his abuse, I'm returning to folding.
I no longer MOO due to abuses by certain "whales" in the Gridcoin community - so I now work the Distributed.net project directly again.
