RICARDOVARELABARRALHi folks!I Recently bought a motherboard of MSI, Model: MSI MEG X299 CREATION.Will the EVGA SUPERNOVA G3 850W be compatible with the motherboard X299 MSI MEG CREATION?None of the models of EVGA appears in the compatibility list:Well. In the specs this motherboard specified that it must be connected wiht 3 units of 4+4 (8 pines) EPS for CPU supply.I have a PSU G3 850W, that, like most of the PSUS, have only 2 EPS/CPU connectors. In other models of other companies, the connectors to VGA/PCI are also compatible with the CPU/EPS, and the solution is buying a new (third) cable.Is that solution possible in the G3 850W ?Thank you in advance.
makina69good forum, I have a question ... recently and I made a rma of a power supply .. the question is if EVGA reviews the product that is sent to you before sending a new product?is that they have sent me a new source and I do not know if they have reviewed the one I sent ..
Sajinmakina69good forum, I have a question ... recently and I made a rma of a power supply .. the question is if EVGA reviews the product that is sent to you before sending a new product?is that they have sent me a new source and I do not know if they have reviewed the one I sent ..I'm sure they do.
makina69Sajinmakina69good forum, I have a question ... recently and I made a rma of a power supply .. the question is if EVGA reviews the product that is sent to you before sending a new product?is that they have sent me a new source and I do not know if they have reviewed the one I sent ..I'm sure they do.Yes of course ... I see it ... that's why it does not work ...
makina69if every time you do RMA and have to pay the shipping costs ..... it would be a real shame ...
sofiajerryy001I also use EVGA and it provides best power supply but from last few days, it shows an error and also occurs power supply problem so I really want a proper solution to get my power supply frequently without any error.
veganfanaticI have lots of cables and no power pig motherboard is going to maul my box
Sgt HoitWill an EVGA SuperNova 1300 G2 be enough power supply to run 2 EVGA GeForce RTX 2080 Ti K|NGP|N GAMING, 11G-P4-2589-KR GPUs?I just recently purchased a EVGA X299 Dark from these very forums, and am considering 2 of these cards to go along with it.
