EVGA Hybrid Kit 2080 Ti fan and buzzing noise
Vince77700
2019/08/02 00:19:37 (permalink)
Hello everybody,
I have an EVGA 2080 TI Black Edition graphic card and I just install the EVGA Hybrid Kit yesterday.
I then powered on my computer and it makes an annoying buzzing sound.
Then I launched a video game to test temperature (67 degrees quite high for me), and the graphic card fan runs at 4200RPM everytime even if I set a quiet profile in X1.
Is this normal that on the pump there is no thermal paste ?
Does anybody encountered these issues ?
Thank you
post edited by Vince77700 - 2019/08/02 00:23:15
3 Replies Related Threads
    Re: EVGA Hybrid Kit 2080 Ti fan and buzzing noise 2019/08/02 01:25:23 (permalink)
    There should have been thermal paste on the pump.
    • Ribbons : 123
    Re: EVGA Hybrid Kit 2080 Ti fan and buzzing noise 2019/08/02 05:31:54 (permalink)
    the heat sink / pump should have had a "dry paste" already applied to it under a protective cover
    Vince77700
    Re: EVGA Hybrid Kit 2080 Ti fan and buzzing noise 2019/08/02 05:55:37 (permalink)
    Indeed like my corsair AIO but there was nothing.
    So I will dismount the card tonight and apply thermal paste on the GPU, but I still don't know why the VRM fan is running at 100%... here is a video of the loud sound h t t p s ://youtu.be/ywPFrD6Zszc
    In attachment, my config
    How many thermal pads should have the graphic card ?
    post edited by Vince77700 - 2019/08/02 06:15:07
