EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors
mduvall9
2020/03/25 09:39:46 (permalink)
Hi all I'm trying to locate a proper powercable for my new card that I just ordered (see copied text box) my power supply is this and should handle it damn easy  i just cant find the proper cable that i should use for it
EVGA GeForce RTX 2060 XC ULTRA GAMING, 06G-P4-2166-RX, 6GB GDDR6, Dual HDB Fans
Item #: 06G-P4-2166-RX
9 Replies Related Threads
    • Ribbons : 123
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:01:26 (permalink)
    Welcome to the EVGA Forums
    What PSU do you have ?
    How old is your current PSU ?
    Ask the PSU Mfg if the cable you want to use is compatible
    WARNING:  Just because a Cable fits your PSU Does NOT mean it is compatible ... you could Let the magic Smoke out
    Every PSU (regardless of who made it) Has the Possibility to have "custom outputs" - pin-outs on the outside of the PSU, if it is Modular design.
    The PSU Mfg make a "custom cable" that moves the Power & grounds to the Correct Location on the Device End
    mduvall9
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:04:56 (permalink)
    ah the link got removed the psu is a EVGA Supernova NEX750G
    • Ribbons : 123
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:06:32 (permalink)
    mduvall9
    Limits on New accounts or low Post count --> find how to "work around" here:  Ultimate Self-Starter Thread For New Members
    Your Part Number of the NEX750 G ?     120-PG-0750-GR   ?
    EVGA SuperNOVA NEX750G 750 W Review | TechPowerUp
    Your PSU came with 4 PCIe cables ... red ones
    • Ribbons : 123
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:16:15 (permalink)
    Contact EVGA if you need to buy replacement cables to Get the Correct cable
    Contact Customer Service
    mduvall9
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:18:03 (permalink)
    alrighty and I realize that i should have them if i got the psu new, that component was there when i originally bought my pc off of a friend from college
    • Ribbons : 123
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 11:18:45 (permalink)
    mduvall9
    mduvall9
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 12:15:15 (permalink)
    i will give contact a shout and see what to get and the part number is 120-G1-0750
    • Ribbons : 123
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/25 15:25:06 (permalink)
    Give a shout & let use know what you end up doing
    There are also third party cable suppliers ... that may be able to make them
    sparetimepc
    • Ribbons : 27
    Re: EVGA GeForce RTX 2060 XC ULTRA GAMING power connectors 2020/03/26 08:11:31 (permalink)
    I believe you could probably use this set of cables for your power supply, https://www.evga.com/products/product.aspx?pn=100-CR-1600-B9&associatecode=5XTLDFI2DFXIPA7    Even though this is for the 1600 series it should be ok to use since the cable connections are the same and the modular plug is the same. Even the right color to match the originals.  I might be wrong though so evga should be able to confirm or not.
    post edited by sparetimepc - 2020/03/26 08:37:57
