I've used this software to create ground fx lighting on my case. I soldered directly to the 12v lines for LED's and wired them to two 12v light strips and have control over the led's via the software. It works wonderful. I would like for you to add a option if its not too much to ask. Strobe effect. I'd like to cycle between 0 and 100% and enable the slider to control the strobe speed. If this is possible it would look amazing. Attached are pictures of the software working. Strobe effect would just put it over the top for me.
I cant post the youtube video but its watch?v=9RZBR1BNvIo
Operating System Microsoft Windows 7 Ultimate
OS Service Pack Service Pack 1
Motherboard
CPU Type HexaCore Intel Core i7-4930K, 3600 MHz (36 x 100)
Motherboard Name Asus Rampage IV Gene (1 PCI-E x4, 3 PCI-E x16, 4 DDR3 DIMM, Audio, Gigabit LAN)
Motherboard Chipset Intel Patsburg X79, Intel Ivy Bridge-E
System Memory 32711 MB (DDR3-1333 DDR3 SDRAM)
DIMM-A1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
DIMM-B1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
DIMM-C1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
DIMM-D1: Corsair Vengeance CMZ32GX3M4X1866C10 8 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
BIOS Type AMI (08/29/2013)
Display
Video Adapter NVIDIA GeForce GTX 690 (2 GB)
3D Accelerator nVIDIA GeForce GTX 690
Monitor Asus VE248 [24" LCD] (D4LMQS010281)
Monitor Asus VE248 [24" LCD] (B8LMQS013597)
Monitor Asus VE248 [24" LCD] (B8LMQS013606)
Monitor Asus VE248 [24" LCD] (B8LMQS013607)
Storage
Disk Drive Samsung SSD 840 PRO Series ATA Device (SATA-III)
Disk Drive ST3000DM001-1CH166 ATA Device (3000 GB, 7200 RPM, SATA-III)
Optical Drive ATAPI iHAS124 W ATA Device (DVD+R9:8x, DVD-R9:8x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Temperatures
Motherboard 38 °C (100 °F)
CPU 24 °C (75 °F)
CPU Package 37 °C (99 °F)
CPU #1 / Core #1 30 °C (86 °F)
CPU #1 / Core #2 32 °C (90 °F)
CPU #1 / Core #3 27 °C (81 °F)
CPU #1 / Core #4 28 °C (82 °F)
CPU #1 / Core #5 31 °C (88 °F)
CPU #1 / Core #6 27 °C (81 °F)
PCH 43 °C (109 °F)
GPU1: GPU Diode 27 °C (81 °F)
GPU2: GPU Diode 26 °C (79 °F)
Samsung SSD 840 PRO Series 28 °C (82 °F)
ST3000DM001-1CH166 (Z1F2SF4Y) 31 °C (88 °F)
ST3000DM001-1CH166 (Z1F12G75) 31 °C (88 °F)
post edited by xboxexpert - 2013/11/05 07:58:10
