nephaliam
Hello everyone. I have an issue with my gtx 1080. Just build new pc and first time i turned it on fan on GCU is running at almost top rpm and i cant slow it down. Cant adjust anything thru precision X. Anybody know what might going on?
HelixBrightstar
Re: EVGA GTX 1080 founders edition fan is sppining at top speed and cant slow it down.
2016/10/06 20:55:50
Perhaps, try two things: Re-seat the card and Uninstall, then re-install the drivers. I hope this helps.
Be the change you want to see in others. CASE: IN WIN GRone White Steel ATX Full TowerMOBO: GIGABYTE G1 Gaming GA-Z170X-Gaming 7 CPU: i7-6700K at 4.6 GHz CPU Cooler: COOLER MASTER Hyper 212 EVO GPU: EVGA GeForce GTX 1070 FTW RAM: G. SKILL TridentZ Series 16 GB DDR4PSU: CORSAIR RM750X 750W 80 PLUS GOLD
nephaliam
2016/10/06 21:05:29
HelixBrightstar Perhaps, try two things: Re-seat the card and Uninstall, then re-install the drivers. I hope this helps.
Did, but still runs the same, toped out.
EVGA_HudsonH
2016/10/06 21:20:18
Hello and welcome to the forums! If you didn't already try, make sure that the PCI-E power connectors are in securely or just re-seat them. I would also recommend checking the fan head on the card itself, you should be able to wiggle this off and re-seat it. You can also try removing all monitoring software (Precision, Afterburner, Speedfan, HWMonitor, etc.) and see if the issue still persists afterwards. Also what are the temperatures on your card and what rpm are the fans spinning at?
i7 4790k | EVGA GTX 1070 | Z97 | 16GB 2133mhz | Kingston 120gb SSD & WD 1TB HD | Phanteks P400s 1080p 144hz 24in. & 1080p 24in. | 84Key Outemu Blue Switches | Zowie FK1 | HyperX Cloud | Samson Meteor
HelixBrightstar
2016/10/06 21:26:39
nephaliam
Have you checked to see if the Auto setting is on under the Fan Curve bar? Also, look to see what the fan curve setting is and that you have KBoost off as well.
nephaliam
2016/10/06 21:31:01
EVGATech_HudsonH Hello and welcome to the forums! If you didn't already try, make sure that the PCI-E power connectors are in securely or just re-seat them. I would also recommend checking the fan head on the card itself, you should be able to wiggle this off and re-seat it. You can also try removing all monitoring software (Precision, Afterburner, Speedfan, HWMonitor, etc.) and see if the issue still persists afterwards. Also what are the temperatures on your card and what rpm are the fans spinning at?
Checked the connector and re-seated it. Will try to check the fan head. I removed precision only cause its all i had. Temps are at around 20C and fan rpm is 5660 which is almost maxed out.
nephaliam
2016/10/06 21:37:43
HelixBrightstar
nephaliam
Auto setting is on and Kboost is off.
HelixBrightstar
2016/10/06 21:52:30
nephaliam
HelixBrightstar
nephaliam
What are your Fan Curve Settings? Below are the standard settings and my custom fan curve for reference.
post edited by HelixBrightstar - 2016/10/06 21:55:50
nephaliam
2016/10/06 22:08:40
HelixBrightstar
2016/10/06 22:12:10
It came through as a broken image icon. Click the "Open Full Version" and upload the screenshot and it will allow you to insert it directly into your reply.
HelixBrightstar
2016/10/06 22:15:15
Nevermind, I looked at the email notice and there was the link to the photo there. Your settings are on point, you may need to RMA your card I am sorry to say. :-(
nephaliam
2016/10/06 22:19:19
RIP... going to take a look at fan header tomorrow like it was suggested. Maybe it will help. But yeah its been stuck like that since i first booted the system up. Thank you for the help, i appreciate it.
post edited by nephaliam - 2016/10/06 22:21:55
HelixBrightstar
2016/10/06 22:27:49
nephaliam RIP... going to take a look at fan header tomorrow like it was suggested. Maybe it will help. But yeah its been stuck like that since i first booted the system up. Thank you for the help, i appreciate it.
You are very welcome. I wish we could have resolved it tonight. I am hoping that you have some luck tomorrow when you look at the fan headers.
Sean1976
2016/10/07 05:34:12
RMA it, sounds like a bad card.
Intel i5 8600k @5.3ghz with 1.450 Vcore Asus ROG Strix-E GamingZ370 deck Hyper 212 Evo Air After-Cooler Evga 1080 GTX Founder's Edition@ 1987mhz core/5400mhz memory G-Skill TridentX 3600mhz XMP4000mhz (2x8GB RGB) 1x Intel 540 series SSD 480GB 2x Intel 520 series SSD 240GB each(480GB) 2x Intel 535 series SSD 240GB each(480GB) Corsair HX850 Watt Gold Psu Antec Eleven Hundred v2 Carbon Fiber case w/ 9x 120mm fans BenQ XL2420TE 144hz 1ms Lightboost/MotionBlur/ Gaming panel(1080p)TN G15/G9 Logitech gear [URL=http://s1273.photobucket.com/user/SeanJ76/media/8600k%20new%20pics_zps2k125brl.jpg.html][/URL]
