Ghost Town
I can't get the led to show as white. It's a light blue color. Is that just how it works? My corsair AIO cooler lights up white just fine.
post edited by Ghost Town - 2016/07/18 15:34:07
JonGan
Re: EVGA FTW 1070 LED Doesn't look white
2016/07/18 15:33:28
same 1080 ftw even when messing with the rgb setting still light blue,heck some of the colors are def off when messing with the rgb compared to my corsair h115i
Ghost Town
2016/07/18 15:34:47
Yeah same with my Jon. I Should have just got the 1070 =( I want white more than blue lol
JonGan
2016/07/18 15:35:46
yeah i wonder if evga is aware of this?i thought i was the only one going crazy but compared to my fans and corsair that's white you can tell the rgb is off
Ghost Town
2016/07/18 15:38:27
Well my fans led strips are off too. They are a weird purple white. And my corsair strafe doesn't really turn true white either. But I know an RGB can be a solid white because my corsair AIO cooler does it
Ghost Town
2016/07/18 15:43:47
Could be the hue.. I can't get it to 0
EhCanadian
2016/07/18 18:17:14
☄ Helpfulby Ghost Town 2016/07/18 18:27:44
Ghost Town Yeah same with my Jon. I Should have just got the 1070 =( I want white more than blue lol
Oh dear. I was primarily going to set it to white myself. I hope its like my g502 where If I set it to a slightly pinkish red white on screen it shows up as a more true white.
Systom
2016/07/18 18:24:24
Is it even possible to get RGB to be White? I get a light blue.
CPU & GPU: AMD Ryzen 9 5900X / Nvidia RTX 3080 FE (Both EK Water Blocks)MB & PSU: ROG Crosshair VIII Formula X570 / EVGA T2 Titanium 1000wSSD & RAM: Samsung 980 Pro 1TB & Western Digital Black SN850 1TB / G.Skill Trident Z Neo C14 3600MHz 4x8GB (32GB) Case & Fans: Lian Li O11 Dynamic / x9 EK-Vardar X3MRads: Black Ice Nemesis 360GTX 360mm x 54mm / Magicool 360S G2 Ultra 360mm x 45mm
Ghost Town
2016/07/18 18:28:12
EhCanadian
Apparently that's exactly what you have to do. Cheers mate!
Ghost Town
2016/07/18 18:35:57
I got as close to white as I could. hue 237 sat 228 lum184 red 252 green 139 blue 148
JonGan
2016/07/18 18:49:14
thanks just used that ghost it and worked,what about the corsair cooler that's more white anyway to match it up with the gpu now?lol
ericc191
- Ribbons : 6
2016/07/18 18:49:32
☄ Helpfulby Ghost Town 2016/07/18 18:52:48
If they only had a 4th led (white) paired with the rgb.
HeatwareOS: W10 64 CPU: Intel Core i9-9900K @5GHz 1.28v Cooling: Corsair H100i RGB Mobo: Asus Z390i Gaming RAM: G.Skill TridentZ Royal 16GB 3200MHz SSD: Intel 660P 1TB | Samsung 850 EVO 1TB M.2 GPU: EVGA GTX 2080 Ti (Custom Hybrid) 2150MHz PSU: Corsair HX1000i Case: White Caselabs(RIP) Mercury S3 Display: Alienware AW3418DW 21:9 120Hz GSync Mouse: Logitech G403 Wireless Keyboard: Max Keyboard Blackbird Audio: Infinity IL10 paired to SA-50 amp
Ghost Town
2016/07/18 18:52:27
JonGan thanks just used that ghost it and worked,what about the corsair cooler that's more white anyway to match it up with the gpu now?lol
I just started playing with the settings but I'm at 113 R 123 G 190 B For the cooler
Ghost Town
2016/07/18 18:53:38
It's still off. If you get closer - let me know!
EhCanadian
2016/07/18 19:38:19
Ghost Town
EhCanadian
Glad I could help. Maybe They could even update the firmware after re calibrating it so that the colours are more representive of their on screen settings. Hell, I bet it could be done in a software update. Wonder if this idea is worthy of sharing.
Ghost Town
2016/07/18 19:44:34
EhCanadian
Ghost Town
EhCanadian
sounds nice - but it might be a limitation due to the led's within the card. Be super amazing if they could make the card pure white through a software update though!
Ghost Town
2016/07/18 20:35:25
I got it more white - its just a bit dingy. hue 13 sat 240 lum 167 green 150 red 255 blue 100
AngryAce
2016/07/19 03:26:52
Ghost Town I got it more white - its just a bit dingy. hue 13 sat 240 lum 167 green 150 red 255 blue 100
Very nice.... I was bummed it wasn't white myself as I have the new SLI bridge and that is WHITE.... wasn't matching.... I will try these settings!
onmybikedrunk
2016/07/19 21:48:34
I found an good white shown as more a peach-orange color in EVGA Precision OC. This isn't EVGA's fault, just the LED controller. A lot of LED controllers do this... Check it out, I'm really happy with my new white. And IMO, if this is the worst issue with these cards, then that's saying something... Hue: 12 Sat: 192 Lum: 137 Red: 233 Green: 111 Blue: 58 Hope this helps someone...
post edited by onmybikedrunk - 2016/07/19 21:50:44
EhCanadian
2016/07/20 14:33:11
Ghost Town
EhCanadian
Ghost Town
EhCanadian
Well the fact that ive managed to get mine to look white myself lends credence to the idea that its more a calibration problem than a physical problem with the card.
EhCanadian
2016/07/20 14:36:54
onmybikedrunk I found an good white shown as more a peach-orange color in EVGA Precision OC. This isn't EVGA's fault, just the LED controller. A lot of LED controllers do this... Check it out, I'm really happy with my new white. And IMO, if this is the worst issue with these cards, then that's saying something... Hue: 12 Sat: 192 Lum: 137
For me, that ends up looking Orange This, visually is the best white I think I can get
sportfan1969
2016/07/23 15:12:11
EhCanadian
That matched my Corsair H115i Pump White perfectly Thanks!
- Ribbons : 270
2016/07/23 17:06:22
As you probably know, it's a RGB LED which means that you have to give it red, green, and blue in order to make "white". As you probably also know, there is never going to be a perfect white color created by a RGB LED. You would THINK that 255 red, 255 green, and 255 blue would create white and you would be correct in a perfect world. Unfortunately, as you have surely noticed, the LED is not a perfect thing and its color calibration is a bit off so that some colors are brighter than others and you need to play with the hue a bit until you get something close to white. All that being said, if everyone is noticing a similar amount of tweaking is necessary, perhaps EVGA will see that their initial assumptions are way off and can provide a better pre-adjusted calibration in their software.
AngryAce
2016/07/24 14:25:18
This is what looks white to my old eyes...... Hue 7 Sat 240 Lum 162 red 255 green 118 Blue 89
glimerman
2016/08/29 17:00:03
thank god for this page I had a 1080 sc card and it was awesome looking I took it back and got the ftw and man it looks bad thanks to this page I ran some settings and its white again thank you guys now it matches my build
Mthdraken
2016/10/07 08:28:44
I just wanted to thank everyone who tested and provided color settings. MVP. Thanks.
Smoov_Operator
2016/12/07 09:03:23
Ghost Town I got as close to white as I could. hue 237 sat 228 lum184 red 252 green 139 blue 148
This worked for me. Thank you.
DuRKe
2017/02/15 18:53:14
Thanks for all the numbers in this thread...I just got a card today and was able to find an acceptable match for my Corsair H-whatever cooler..I went with H237 S228 L184 from Ghost T (looks pink in the software but white on the card)
EVGA Affiliate Code: 4L5-TLY-XCOQ EVGA Z170 Classified K | 6700k | EVGA 1080 Ti FTW3 | EVGA 750 G3 | 12GB Corsair RAM | 950 pro m.2 | 850 Evo | H100iv2 | Win 7 64-bit | 378.78 | Precision XOC 6.1.0
