Sup3rFly1788
Hi All, All of a sudden my card is spiking like crazy on the Max Power Temp. Nothing has changed in the computer. Card is a week old. Any help would be appreciated. It's going from 30 - to 99 all the time. Thanks.
post edited by Sup3rFly1788 - 2017/04/04 02:24:38
Splash87
Re: EVGA 1080 SC 2 Max Power Temp Spiking 99
2017/04/04 01:43:47
Looking at your picture, the fans are not spinning.
Have you tryed forcing the fans to spin at like, lets say 50% to start with?
Also personally, as I don't overclock because the cards performance is good as it is, I would say chsnge the priority to temperature and drop that to 70-75C
Sup3rFly1788
2017/04/04 01:44:57
They start spinning once it hits over 45 degrees. That was captured just as it changed back down to 30.
Splash87
2017/04/04 01:46:22
Try changing the priority to temperature and drop It a few degrees. Than boot something and get some load on the GPU, see if that changes anything.
post edited by Splash87 - 2017/04/04 01:53:12
Sup3rFly1788
2017/04/04 01:46:58
Surely PWR 5 shouldn't be like that!!!!
Sup3rFly1788
2017/04/04 01:49:27
Splash87 Try changing the priority to temperature and drop It a few degrees. Than boot something and grt some losd on the GPU, see if that changes anything.
Sadly makes no difference.
Splash87
2017/04/04 01:53:58
That is really weird, I doubt many of us can assist you on this one, I fear an RMA..
arestavo
- Ribbons : 77
2017/04/04 06:05:52
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2017/04/04 06:50:55
Yeah, that is strange that it is spiking like that.
I agree with arestavo that it could be a bad sensor.
2017/04/04 12:12:35
It could also be a software bug. Does the power fan kick on at all when it reads 99-103c?
Sup3rFly1788
2017/04/04 12:55:38
Have contacted support and raised a ticket, just waiting on a reply.
The fan turns on for either a second or a few seconds then shuts back off. The sensor jumps from anywhere in the 30's straight to 80, then the highest I saw it was 110. Uninstalled the drivers, didn't help sadly. Re-seated the card as well.
It has to be a faulty sensor, feeling the card there is no heat near where that sensor should be. If it's reading 100+ I would expect some sort of heat there.
2017/04/04 13:15:29
Sup3rFly1788 The fan turns on for either a second or a few seconds then shuts back off.
Definitely a faulty sensor then.
Sup3rFly1788
2017/04/04 21:41:46
Hi All, Just an update - I contacted support this morning and have placed an RMA, just awaiting on approval.
demon09
2017/04/05 00:30:04
Sup3rFly1788 Hi All, Just an update - I contacted support this morning and have placed an RMA, just awaiting on approval.
you could see if support will do an cross ship rma for you then you won't be out of a gpu in the mean time. as long as you can handle a pending charge on you're credit card
Sup3rFly1788
2017/04/05 01:20:08
Hi All, So I've come home to remove the card awaiting RMA approval and found the below sitting above the sensor (This was not there last night after re-seating the card). Looks like a thermal bad may have melted, plus some plastic? I have called support and explained what I have found. I have an AIO Corsair Cooler, but there is 0 leaks in the tube and would imagine it would be everywhere as you can see from the picture there is nothing, not even a spill or drop on the tubing either. My CPU temps are fine and cooler is acting normal so there is definitely no leaks from that otherwise I'd have fans going nuts and liquid spraying everywhere. Support mentioned that there shouldn't be as much as I explained. There's around 2ml of liquid and looks green, but when touched it's a clear oil liquid. I'm not sure what else to do now? This post is more for a reference and documentation for RMA team, if they ever look at this.
Sup3rFly1788
2017/04/05 02:50:22
Hi All, I would like to apologise to everyone and EVGA. After searching and searching and ripping everything out of the PC i found some more green liquid around the AIO. (see below - can see it around the base of the cooler and dried on the tubing) Looks like my cooler leaked all over the card (3 weeks old :( ) I will now be contacting Corsair to see what they will do. Thank you everyone and EVGA Support.
trawetSluaP
2017/04/05 06:54:48
Good luck. Hopefully Corsai will sort you out.
Case: Phanteks Enthoo Elite CPU: i9-7900X Motherboard: Rampage VI Extreme RAM: Corsair Dominator Platinum 32GB 3200 MHz GPU: RTX 2080 FE Storage: 960 Pro 512GB, 2 x 840 Evo 250GB PSU: EVGA SuperNOVA 1200 P2 Monitor: HP Omen 27i, MX27AW Custom Watercooling LoopAquaero 6 XT
GTXJackBauer
- Ribbons : 48
2017/04/05 07:12:50
That's really unfortunate. At first I thought, that must be a ton of heat but questioned if you were running any type of liquid cooling above it as you later posted you did. Hope it all works out for you and keep us updated.
- Ribbons : 123
2017/04/05 07:22:13
Please keep us posted on the outcome and Corsair's customer service
demon09
2017/04/05 07:37:41
Ah this is a nightmare of mine to have my Corsair aio leak:X
max883
2017/04/05 08:03:00
Sup3rfly1788 You are a true and onest person. Admiting it came from the aio water cooler driping on the card and showing photos of it. U should do a RMA and get a new card in return. Onesty pays.
demon09
2017/04/05 08:04:07
max883 Sup3rfly1788 You are a true and onest person. Admiting it came from the aio water cooler driping on the card and showing photos of it. U should do a RMA and get a new card in return. Onesty pays.
only way he can get a new card is if Corsair pays now
GTXJackBauer
- Ribbons : 48
2017/04/05 08:34:52
Worst case scenario, he gets billed for the repairs if its repairable by EVGA.
Sup3rFly1788
2017/04/05 15:18:18
Hey All, Contacted Corsair Support, waiting on the ticket to be assigned to a technical engineer. Fingers crossed tomorrow I will have some more news and hopefully it's good news. max883 Sup3rfly1788 You are a true and onest person. Admiting it came from the aio water cooler driping on the card and showing photos of it. U should do a RMA and get a new card in return. Onesty pays. Thank you! Really appreciate the kind words mate. I don't expect EVGA to replace a card that has been damaged by another manufactures faulty part. demon09 Ah this is a nightmare of mine to have my Corsair aio leak:X I wish it was just a nightmare of mine haha! GTXJackBauer Worst case scenario, he gets billed for the repairs if its repairable by EVGA. Very true. I'm assuming I will have to send the damaged card to Corsair first so the can inspect it themselves and see where it goes from there I guess. I will update you all when I hear something from Corsair :)
moopig123
2017/04/05 20:22:00
Did you buy the GTX1080 SC2 with a credit card? Many years ago certain UK credit card companies used to advertise that they gave several months accidental damage cover for purchases made with their cards. It's a long shot, but it might be worth checking the small print to see if your card company does that.
the_Scarlet_one
- Ribbons : 79
2017/04/05 21:15:04
Wow! I am sorry to hear the cooler leaked. Wishing you the best all around that everything gets taken care of.
Sup3rFly1788
2017/04/06 02:12:40
Hi All, Thanks for the support everyone. Appreciate it. Sadly it just gets worse, after removed left over cables from the cooler and finding my stock CPU cooler, booted PC up and all of a sudden USB Device errors. Device manager was going nuts. Then I remebered I disconnected the coolers USB connection...guess what?! Green coolant all inside the bottom 2 USB connectors. Mobo won't even post now.  Can see the residue around the bottom.
GTXJackBauer
- Ribbons : 48
2017/04/06 04:24:08
Inspect all your gear, particular in the leak zone if you will and sent all that to Corsair. They should compensate you np. I've dealt with their CS in the past along with EVGA's during a nasty MB blowout that took a few things with it and all was taken care of by both parties.
Bobmitch
- Ribbons : 49
2017/04/06 06:12:50
Been reading this for the past few days...I am keeping my fingers crossed for you that it all works in your favor!
MSI MAG X670-E Tomahawk; Ryzen 7 7800X3D; Asus TUF RTX 4070 TI OC; Seasonic Vertex GX-1000 PSU; 32 GB Corsair Vengeance DDR5-6000 CL30 RGB; Corsair iCue Link H150i LCD 360MM AIO; 2-Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z; Lian Li Lancool III; Corsair K70 RGB Pro MX Speed Silver Keyboard; Razer Viper 8K Mouse Heatware: https://www.heatware.com/u/72402 Affiliate code: 1L2RV0BNQ6 Associate Code: UD82LJP3Y1FIQPR
