Re: Do case fans affect GPU power draw?
2019/11/18 07:44:48
Yes, if the GPU is getting warmer - OR - your MB/ CPU OC was near the edge
Nvidia Boost 3.0 (for 10 series cards) - is the reason
Boost will control the MHz of the card based on Load, Temp & Watts .... & will step down the MHz to control Temp & Watts ... this is Not throttling
It is possible your New fans introduced electrical noise to your system (?) maybe
Your Rig Specs ?
GPU - 1080 ti SC is model number ?
MB -Asus Z270i ---> is the BIOS latest version ?
CPU - OC ?
CPU Temps
RAM & Timings / running manual or XMP
PSU - Silverstone SX650G ---> Age of unit ? Using Stock cables that came with the unit only ?
OS - detailed please: Win 10 Edition ?, Version ? & Build ?
Case & # of fans blow In & # blow out @ what RPM %
Room Temp ?
Remove All OC to test the GPU .... Start OS with a "Clean Boot"
What Benchmark are you running ?
