AnsweredDo I need to power the 4pin CPU Connector to activate Turbo
Kozanator
2018/02/05 13:55:00 (permalink)
Hi,
I just bought the EVGA Z370 Classified K motherboard and I have the Intel Core i7-8700k CPU.
Do you need to use the 4pin CPU connector in addition to the 8pin CPU connector on the motherboard in order to have the i7-8700k operate in Turbo mode? Or does that just happen automatically when it's needed?
- Duncan
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/05 15:08:10 (permalink)
Kozanator
Nope.
Kozanator
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/05 15:58:23 (permalink)
oh, I thought Turbo Mode was like overclocking. Therefor requiring the extra 4pin cpu connector.
So, are your saying that without the extra 4pin cpu power connector, my processor (Core i7-8700k) will still be able to use its turbo mode maxing out at 4.7Ghz
Why would I ever want to use the extra 4pin cpu power connector?
Duncan
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/05 16:01:48 (permalink) ☼ Best Answerby Kozanator 2018/02/06 14:41:22
Kozanator
Duncan
First question: Yes.
Second question: Extreme overclocking.
Kozanator
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/05 16:05:42 (permalink)
Thank you very much for your clear answers.
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/05 16:08:43 (permalink)
No problem.
mouacyk
Re: Do I need to power the 4pin CPU Connector to activate Turbo 2018/02/07 11:16:22 (permalink)
I did not have to use the additional 4-pin CPU connector to achieve 5GHz on my 8700K.  Likely won't need that unless you do extreme overclocking with liquid nitrogen.
i9-9900K@5.2GHz@1.304v / 2x16GB-3900C15-2T-1.45v / Z370 Micro / RTX3080 / SS-X850W-G / 480mm Custom H20 + Raystorm Pro / XB271HU
