AnsweredDisplay Port doesn't work until after OS loads
JDauwalter
Re: Display Port doesn't work until after OS loads 2019/07/22 10:18:01 (permalink)
User423i
This problem is now fixed! Big thanks to Thomas Yiu at ASUS for finding it. It was a setting on the monitor - the "DisplayPort Deep Sleep" setting in the OSD has to be unchecked.
I'm surprised they didn't know about this sooner considering it's an Asus monitor...
#31
  • Ribbons : 122
Re: Display Port doesn't work until after OS loads 2019/07/22 10:33:20 (permalink)
JDauwalter
User423i
+1
sometimes its the simple stuff that trips you up
#32
blackforce
Re: Display Port doesn't work until after OS loads 2019/07/22 10:46:18 (permalink)
asus comes through again, thanks for the update.
#33
Haans249
Re: Display Port doesn't work until after OS loads 2020/02/29 13:03:41 (permalink)
The issue is most likely with the graphics card.
Nvidia released a tool to fix the displayport 1.3/1.4 compatibility issue.  I just ran it on my 1080 Ti and it fixed the issue 100% where no boot screen would show when booting with CSM disabled.
Search: Nvidia Graphics Firmware Update Tool for DisplayPort 1.3 and 1.4 Displays
#34
  • Ribbons : 135
Re: Display Port doesn't work until after OS loads 2020/02/29 14:59:35 (permalink)
Haans249
Wrong series, wrong fix. Nice necro.
#35
