Cooler Master Launches The NR200P MAX SFF Solution | TechPowerUp Cooler Master today launches the NR200P MAX, the first iteration of its new MAX line of building platforms. The NR200P MAX's extraordinarily optimized ecosystem provides small form factor enthusiasts a fail-proof jump start on their builds through fine-tuned components and thoughtful design. MAX products serve as a physical culmination of Cooler Master's years of mechanical, thermal, and power delivery expertise, aiming to break industrial limits and perfect technological achievements. Case, thermal and power solutions come pre-customized with never seen before product features, calibrated to work together in exquisite harmony.
The First of Cooler Master's MAX Series - Max out your PC performance with Cooler Master's new MAX Series, complete with custom thermal and power delivery solutions. Tailor-made to provide versatile hardware compatibility, as well as providing ample clearance for the largest, widest graphics cards on the market, MAX delivers ready-to-go building platforms for high-performance systems.
Cooler Master's Expertise At Its Finest - NR200P MAX is a masterpiece integrating Cooler Master's expertise in the thermal, power delivery and mechanical design, designed for unstoppable performance and capable of satisfying the most power-hungry systems.
SFF Building Refined - Get a head start in building your SFF PC! Taking up only 18 liters of volume, the NR200P MAX takes the difficulty and hassle of cable management out of small form factor PC building.
Luxurious, Out-of-the-Box Solution - A time efficient, ready-made solution for PC enthusiasts who place utmost value on their PC performance. NR200P MAX saves users from hours upon hours of tedious research with guaranteed hardware
SFF, Built to Spec
Decked out in Slate Grey for a stealthy modern look, the NR200P MAX serves to be the most user-friendly yet versatile SFF build on the market. Although bearing similarities to the best-selling NR200(P) at a glance, the NR200P MAX boasts an exclusive case layout, top-mounted, 280 mm AIO water solution, as well as an 80 Plus Gold verified 850-watt PSU, all pre-installed and pre-routed out of the box. Liquid cooling and electrical cables have been modified to custom lengths for a polished look and effortless, time-efficient build.
Its unique, synergized design allows professionals and SFF entry level builders alike to unlock the full potential of any Mini-ITX motherboard, GPU, and RAM installed, completely eliminating the complex process of researching product compatibility to achieve minimal footprint.
Pricing
The Cooler Master NR200P MAX will be available soon for 349.99 USD.
I really find it hard to justify a 350 dollar price tag on this small form factor case.
