Clicking noise when fans start/stop? (EVGA 1080 GTX FTW)
chatserv
Sunday, August 21, 2016 1:38 AM (permalink)
Has anyone noticed a clicking noise when the fans kick on or off?
The first unit I got didn't have this issue, the 2nd one that I got the RMA for is doing it.
LCD Monitor: ASUS 144Hz 24"
CPU: Intel i5-6600k
Graphics card: Asus Rog 1080 GTX
CPU Case: Corsair Mastercase Maker 5
CPU Cooler: H100i V2
Motherboard model: Asus Maximus Hero VIII
Operating system: Microsoft Windows 10 PRO
RAM: Corsair Vengeance LED 32GB 3200 MHz
SSD: Samsung 850 EVO 500GB / OCZ 120GB / CRUCIAL 250GB
PSU: Corsair HXi 1000
17 Replies Related Threads
    • Ribbons : 115
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 1:46 AM (permalink)
    Check the fan for any broke off part, and check to see if it's loose.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    chatserv
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 3:02 AM (permalink)
    I did check the fans, thats one of the first things I checked, I spinned the fans manually and no noise, no broken parts, just when it starts or stops it makes a loud clicking sound.
    CPU: Intel i5-6600k
    MikeBGeyer
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 11:49 AM (permalink)
    A lot of people were reporting a wire that was rubbing against the fans. I know you said you looked but you might wanna double check.
    chatserv
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 9:40 PM (permalink)
    I haven't opened the card, and honestly I think it would not be a good idea to open the card and risking damaging any components...
    CPU: Intel i5-6600k
    Erica647
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 10:20 PM (permalink)
    I notice a really faint noise when the fans start up but I don't hear anything at all when they're running (except when they're closer to 100%)... it reminds me of mechanical hard drive noise.  I'm on my 2nd card now as I had to send the first one back for coil whine so I definitely understand about not wanting to take the card apart.  I tried to find information about removing the fan shroud but I don't see instructions anywhere.  Does anyone have a link so we can see how involved that would be?
    chatserv
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 11:01 PM (permalink)
    Erica647
    Any coil whine on  your replacement card?
    CPU: Intel i5-6600k
    Erica647
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Sunday, August 21, 2016 11:24 PM (permalink)
    No coil whine at all on the replacement card that I can hear... so much better than the first one.
    chatserv
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 1:22 AM (permalink)
    My first card had lots of coil whine, the 2nd card had more coil whine. The first card had the sticker falling off (EVGA LOGO)....thats the reason I RMA.
    I hope this card resolves all my issues, if it doesn't then I might end up switching brands...Iv'e tried 4 different brand PSUs..all had coil whine.
    CPU: Intel i5-6600k
    hapkiman
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 3:21 AM (permalink)
    A "clicking noise" is definitely different than coil whine [obviously], so you have to have something hitting one of the fans as it spins.  The most likely culprit is a wire.  It's really not a big deal at all to open the card and check.  It's an easy fix.  Could also be a sticker or a piece of plastic.
    Intel Core i9-9900k, Corsair H115i Platinum RGB, 32GB (2x16GB) Corsair Dominator Platinum RGB DDR4 @3466MHz, EVGA RTX 2080Ti XC2 Ultra, MSI MEG Z390 ACE, Samsung 970 Pro 512GB, Samsung 860 EVO 1TB, WDHDD 2TB, Dell P2715Q 4K/UHD @60Hz, Samsung T27A300 1080p @60Hz, Windows 10 Pro, Fractal Design Define R6 with x3 Corsair 140mm ML fans, SeaSonicXP2 860w, Corsair K70 RGB MK2, SteelSeries Rival 600, Bose Companion 2 Series III speakers.
    Veijari
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 3:59 PM (permalink)
    chatserv
    Like this?
    http://forums.evga.com/Ev...nd-issue-m2530538.aspx
    hapkiman
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 4:29 PM (permalink)
    Sorry, I misunderstood your post. So you hear a click when the fans start? Not a constant click from something hitting the fans? I listened closely and my FTW 1080 is dead silent when the fans start. Not sure what you have going on there.
    Erica647
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 6:01 PM (permalink)
    hapkiman
    Yes for me it's only when the fans start... then I no longer hear it.
    matthewfarmery
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, August 22, 2016 6:16 PM (permalink)
    do you hear the clicking sound when the fans stop? what happens when you manually spin the fans yourself? do you hear a clicking sound then? I also think it could be a wire.
    Erica647
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Tuesday, August 23, 2016 1:39 PM (permalink)
    matthewfarmery
    I don't hear the clicking noise when the fans stop or if I manually spin the fins myself.  I removed the card to check the wires and noticed that the fan wires are held down by a metal clip and the wires were flat up against the heatsink.  I opened a support ticket and received the following response, "You can try removing the card and placing it fan side up on a flat non conductive surface like wood or cardboard. then place pressure onto the center of the fan. You will feel it move in by about 1/8 of an inch. This should realign the bearings inside the fan housing and stop the "clicking" noise. "  I tried this and it did seem to help but I'm uncertain if this is going to be a permanent solution.  I'll post again if anything changes.
    GenRommel
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Tuesday, September 13, 2016 4:01 AM (permalink)
    I was having this exact problem, fans made clicking noise when running, but not when manually spinning them, no wires in the way. Was about to try to RMA, but decided to try pushing on it first, so far it's solved. Now to see if it stays that way...
    Edit: This was a 970, but their coolers are basically the same.
    csaris
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, December 10, 2018 2:13 PM (permalink)
    Received mine today, a 2080ti black edition and does the same.
    This is totally unacceptable and will definitely return the card for a refund.
    EVGA must respond and release a bios that stops the auto stop fan.
    GGTV-Jon
    • Ribbons : 19
    Re: Clicking noise when fans start/stop? (EVGA 1080 GTX FTW) Monday, December 10, 2018 5:23 PM (permalink)
    csaris
    Holy thread resurrection!! This thing hasen't seen the light of day in 2 years
    This is the Pascal / 10xx series section, go check the 20xx series section as your noise is a different issue
