V-L-D
Hi all, Problem here - after using system for 3-4 hours , some intensive loads it bluescreened with “irq less or no equal”. Reboot, post code 69 and caterr_led on. Reset - hangs on post code 24, caterr_led off. Cleared cmos - same. Reseated ram, cpu, checked cables - same. Reflashed bios - booted first time, got in to BIOS, nothing unusual. Saved default settings, reboot - post code 69, catter_led on … Z690 Dark, brand new 13900K, TG 7600 ram, 3090Ti, AX1600i. Any ideas ? :|
post edited by V-L-D - 2023/01/11 16:21:56
Re: Caterr_led on and post codes 69 / 24
2023/01/11 18:20:45
Make sure your cpu heatsink isn’t too tight. If that doesn’t help try running off a different bios by simply flipping the bios selector switch on your motherboard to a different position. If none of that helps try testing your cpu & ram in a different rig to confirm they’re good. If the cpu & ram works in another rig then you should rma your board.
Note: Make sure you’re running the latest bios version on all your bios chips as well.
V-L-D
2023/01/13 15:02:57
13900K dead, after one week of using it. Preordered 13900KS 😀
2023/01/13 19:50:42
V-L-D 13900K dead, after one week of using it. Preordered 13900KS 😀
Were you overclocking the cpu & memory?
V-L-D
2023/01/14 18:35:27
Yes, but nothing extreme - 5.7 all core avx -3, 1.34 min droop, 7800 ram, watercooled, 1.5/1.48 vdd vddq, 1.2sa, cpu delided, direct die cooled with liquid metal, no spills, smd’s well protected, core temps around 90c. Maybe some voltage spike, i was using memory hungry application that uses avx2 instruction set, it happened when i pressed close program button. Post code 69 and 24 relates to North Bridge DXE init, any idea whats that all about ?
post edited by V-L-D - 2023/01/14 18:46:30
V-L-D
2023/01/16 17:14:45
“Fun” continues - installed 13900kf, First boot - fine, reset cmos, booted windows, no issues. Powered down, powered up - no 1.8 cpu rail and vcore power. Cpu - dead, not detected, tested on other pc. Damn …
2023/01/16 20:07:14
Wow. You think its the mb or psu killing them?
V-L-D
2023/01/17 14:36:46
100% sure it is mobo, no 1.8 and vcore rail leds. Will be RMA’d.
2023/01/18 15:20:25
Let me know how the rma goes.
Mr. Fox
2023/01/19 17:41:48
I had that happen to me on a Z490 Apex. Asus refused to pay for the CPU their garbage motherboard destroyed. Fortunately, Intel covered it under warranty. Just a heads up... Intel will deny your warranty if you tell them the CPU or RAM was overclocker. It is an automatic denial now that their performance tuning warranty is no longer offered. They did that to me on a 12900K.
post edited by Mr. Fox - 2023/01/19 18:11:33
Wraith // EVGA Z690 Dark K|NGP|N | 13900K | MSI 4090 Suprim X | 32GB DDR5 | EVGA SuperNOVA 1600 P2 | HC-500A Chiller | MO-RA3 360 D5*3 || EVGA DG-86Banshee // ASUS Z690 Apex | 13900KF | ASROCK 6900 XT OC Formula | 32GB DDR5 | Corsair RM1200x SHIFT | XT45 1080 Nova D5*2 || Corsair 5000D Airflow Half-Breed // Precision 17 7720 | 7920HQ (BGA filth) | Quadro P5000 16GB (MXM) | 32GB DDR4 || Grade A Off-Lease Refurb
