Re: Cable solution for a 2080 FTW Hybrid on a H510 case
2019/09/30 16:06:47
Or you can use 2 fans for push-pull configuration and best airflow, but it is better to have similar fans.
There is 8 screws to mount fan and radiator: long one to mount fan (that actually already holding stock fan) and short one to mount radiator to case.
But you can mount radiator to case through fan with long screws (for pull configuration) and you can actually mount fan with sort screws. Or you can leave stock fan, mount 2nd fan with short screws and mount fan in case with fan screws.
As for tubes - you can try to push CPU tubes up instead down. Also you can try to point gpu tubes down like this one:
And yes, you
can should try rotate radiator to get best layout.
post edited by DeadlyMercury - 2019/09/30 16:15:23
"An original idea. That can't be too hard. The library must be full of them."
Stephen Fry
