https://www.techpowerup.com/302189/alphacool-announces-new-core-water-block-for-geforce-rtx-4090-reference-and-founders-designs The Core product line takes shape with the new coolers in the usual high quality, excellent performance and functional design language. The heart of the copper cooler is an assembly of connector terminal and cooler, which is milled from one piece of copper. The fine workmanship combined with the hard and resistant chrome plating of the entire copper cooler meet the highest quality standards. The brass G1/4" threads integrated on both sides, also chrome-plated, stand out visually striking from the terminal and are one of the key points of the new design language that will be present in all products of the Core series.
The aluminium backplate matched to the design together with the terminal forms a single unit. It convinces with clear and homogeneous optics on the back of the cooler. The individually controllable lighting consists of digitally addressable RGB LEDs and enables the even and colorful illumination of the entire cooler.
The technical advancement is also evident in the water supply to the jet plate and in the optimization of the jet plate itself. In cooperation with board partners, this was completely redesigned on the basis of many simulations and practical tests. The fin thickness and spacing were reduced, the cooling surface was increased and the water flow to the main components with the highest heat dissipation was optimized.
The new Alphacool Core water coolers will be available for more high-end graphics cards from AMD and Nvidia in the future. The coolers for Nvidia Geforce RTX 4090 Reference Design and Founders Edition graphics cards are now available for pre-order in the Alphacool Online Shop.
Features:
- Optimized fin structure enables excellent water flow as well as enlargement of the cooling area
- Modified jet plate ensures optimal distribution of water over the cooling fins
- Visually calm & sleek design with digital aRGB illumination
- Chrome plated copper radiator
Compatibility Core Geforce RTX 4090 Reference Design:
- Nvidia Geforce RTX 4090 Reference Design
- INNO3D GeForce RTX 4090 X3 OC
- INNO3D GeForce RTX 4090 iCHILL X3
- INNO3D GeForce RTX 4090 iCHILL Frostbite
- INNO3D GeForce RTX 4090 iCHILL Black
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan
- PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan
- KFA2 GeForce RTX 4090 SG (1-Click OC)
Compatibility Core Geforce RTX 4090 Founders Edition:
- Nvidia Geforce RTX 4090 Founders Edition
Webshop listing here. Good looking water blocks with very good RGB.
