Hot!AMD's Strix Point Successor Codenamed "Sound Wave"?
  • Ribbons : 85
2024/03/03 23:40:52 (permalink)
https://www.techpowerup.com/319894/amds-strix-point-successor-codenamed-sound-wave
Some of the earliest signs are emerging that AMD's mobile processor or desktop APU silicon that succeeds "Strix Point" being codenamed "Sound Wave." AMD tends to come up with quirky internal codenames for upcoming projects, mostly to zero in on the source of leaks, so "Sound Wave" as a codename is subject to change with time. While the upcoming 4 nm "Strix Point" and "Strix Halo" chips implement the "Zen 5" CPU microarchitecture and RDNA 3+ graphics architecture, besides XDNA 2 based NPU with a generational tripling in AI TOPS; Wccftech believes that "Sound Wave" could be an AMD processor of comparable class to "Strix Point," which implements the "Zen 6" CPU microarchitecture, which AMD has planned for a 2025-26 timeframe.
Perhaps the most interesting aspect of this leak is the foundry node, with the original source over at Korean tech blog Gamma0burst referencing 3 nm. This is the final node family from TSMC to implement FinFET transistors before the foundry transitions to nanosheets with N2. It's likely that AMD chooses one of the more advanced variants of TSMC's 3 nm nodes, such as the N3P or N3X, because 2025-26 will see rival Intel get close to introducing the Intel 20A foundry node for mass-production. Not much else is known about "Sound Wave" besides the "Zen 6" CPU cores at this point.
The information seems logical enough to probably be true.
0 Replies Related Threads
