kbhushan
Hi Guys, So I recently bought a new motherboard which happens to have an 8 pin and a 4 pin ATX CPU Power connectors. However my corsair RM650 has only one such 8 pin connector and NOT the additional 4 pin. I have paired it with an i7 6700K. So the question here is will it work if I use just the 8 pin connector? Thanks in advance.
Brain: Intel Core i7 6700K @ 4.6 GHzCooler: Corsair H100iMotherboard: MSI Enthusiast Z270 Gaming M7Memory: 2 x 8GB Corsair Vengeance LPX @2400 MHz GPU: EVGA GTX 1080 FTW2 @ 2114 MHzDisplay: ViewSonic VX2250 Full HDBoot Drive: Samsung 840 EVO 120GBMass Storage: 3 x 7200 RPM Mechanical Hard DrivesPSU: Corsair RM650 650WCase: Corsair Vengeance C70 Arctic WhiteOS: Windows 10 Pro
Valtrius Malleus
Re: 8 pin ATX connector and 4 pin ATX connector
2017/10/06 07:12:31
Yes but overclocking it might make it unstable. It might not. Depends on how much power it tries to draw.
kbhushan
2017/10/06 07:14:27
Valtrius Malleus Yes but overclocking it might make it unstable. It might not. Depends on how much power it tries to draw.
Thanks mate. Is there any alternative to this other than changing the power supply?
Valtrius Malleus
2017/10/06 07:23:44
You can buy a molex to 4 pin CPU adaptor but that might just be worse than leaving it out.
- Ribbons : 282
2017/10/06 07:32:48
You should use a PSU with Two EPS Connectors, most are 8-Pin that are made up of 2 4-Pin.
post edited by bcavnaugh - 2017/10/06 17:37:45
2017/10/06 12:01:32
Yes, it will work fine. Overclocking won't be a problem either... Note: A single 8-pin can support up to 288w alone.
2017/10/06 12:02:15
Moving thread to general hardware sub-section.
wmmills
- Ribbons : 40
2017/10/06 12:56:19
quadlatte
- Ribbons : 56
2017/10/06 14:28:25
it will be fine, unless you start getting crazy high clocks. my x58 with a 6 core xeon has just one 8 pin connected and is fine
kbhushan
2017/10/06 14:32:56
Sajin Moving thread to general hardware sub-section.
Thanks mate. Sorry I didn't notice I was posting it under Graphics Card Section.
kbhushan
2017/10/06 14:36:47
quadlatte it will be fine, unless you start getting crazy high clocks. my x58 with a 6 core xeon has just one 8 pin connected and is fine
Good to hear that. Because Corsair PSU costs are crazy high. Planning to OC my 6700k to 4.6. I hope the mobo can take it :D PS: I own a Z270 GAMING M7 from MSI and an EVGA GTX 1080 FTW2.
quadlatte
- Ribbons : 56
2017/10/06 14:38:59
kbhushan
you should be fine at 4.6, much higher then i would think about that second connector.
kbhushan
2017/10/06 14:42:03
quadlatte
kbhushan
Okay. I will get a new PSU later but don't know if the 6700K will be stable beyond 4.6 anyway.
NemesisChild
2017/10/06 15:03:34
kbhushan
All the more reason to get a EVGA PSU.
Intel i9 10850K@ 5.3GHz Corsair H115i Pro XT ASUS ROG Strix Z490-EG.Skill TridentZ@ 3600MHz 32GB CL14 EVGA RTX 3090 Ti FTW3 Ultra OS: WD Black SN850 1TB NVMe M.2 Storage: WD Blue SN550 2TB NVMe M.2 EVGA SuperNova 1200 P2 ASUS ROG Strix Helios GX601
kbhushan
2017/10/06 15:06:15
NemesisChild
kbhushan
Hmmm... Will give EVGA a try this time.
kbhushan
2017/10/06 16:00:15
NemesisChild
kbhushan
Is your 6700K stable at 4.8 GHz?
