VistaHead
- Ribbons : 132
Re:790i Ultra SLI, C1 code, won't boot. help?
2009/11/11 15:08:20
It is rated at speed settings of 9-9-9-24 @ 2.0v running at 2000Mhz. If you are running the RAM slower than that, you can adjust your voltage and timings accordingly. As an example, I run the exact same RAM at 1700Mhz 8-8-8-22 @ 1.60v. I am not saying that you can or cannot run yours with the exact same settings, I am using it as an example of running your RAM lower than it's certified speed and undervolting it because of the lower speeds. Once you obtain 1800Mhz at 2.0v, I would decrease the voltage incrementally until it became unstable, and then go up one to the stable voltage setting.
Felyx
2009/11/11 22:10:47
I was running some tests on my memory today and ran into a rather disturbing issue. I had one stick of the Patriot RAM in the first black channel slot and was using memtest86+ 4.0 and got to about 30 errors in the first minute of testing before it locked up. (Oddly I was able to boot up into windows with it not bluescreening me). Then I tested the same RAM in the first gray channel, then the 2nd black channel. Memtest passed all tests on each of those slots. So, what I've got here is a motherboard issue after all it seems. I was testing at the settings VistaHead recommended, except I turned down the FSB and MEM Mhz to 1600, tRAS at 22, memory voltage at 1.9, SPP voltage 1.4, MCP voltage 1.6. Now that I know I've got an issue with the motherboard, what is the procedure to RMA it? Assuming that's possible. I bought it on 11/25/08...
VistaHead
- Ribbons : 132
2009/11/12 03:17:48
Felyx
2009/11/13 06:20:56
With the memtest from that link I'm running into a situation where one of the sticks is passing and the other is not, so I'm sending them back for replacement. Will update once I get new ones.
VistaHead
- Ribbons : 132
2009/11/13 06:25:00
Test the stick that failed in the first gray slot.
Stray_Bullet
- Ribbons : 8
2009/11/13 06:28:37
Yeah might be a bad DIMM slot & not the memory...
My Machine: *Antec 1200 Case *EVGA 790i FTW|SZ16|nForce 15.58 *Q9650 @ 4.275 GHz Linked/Sync @ 1900 MHz *Prolimatech Megahalems CPU Cooler *Patriot 2x2GB PVS34G2000LLKN 8-8-8-23-2t|8-40-12-17-23-7.8uS-110 (black slots) *BFG 1000 Watt PSU *3x GTX 275|Forceware 270.61 *On-board Sound card|5.1 Surround *2 WD VelociRaptors|RAID 0 * 7 x64 790i BIOS Template| Critical Damage Incorporated
VistaHead
- Ribbons : 132
2009/11/13 06:32:43
Stray_Bullet Yeah might be a bad DIMM slot & not the memory... That's what I'm starting to think, especially after reading his comments in post # 32. If the failed stick passes in a different slot, then it probably is the board.
bicycledr4376
2009/11/16 06:36:43
i am having a C1 issue also, but mine is more of a RANDOM issue, so its a bit harder to pin down. i have 6 gig (3 2gig modules) of corsair xms3 (cm3x2g1333c9) if i need to do a restart or if i turn my pc on after only being off for a little while, i get the C1 error at boot. no post. i have to turn off the psu and unplug it and drain residual puwer from the mobo before i can post. sometimes i have to do it 2-3 times, so you can see how aggrevating this can get. this has been an on going issue from the day i built this. here is some of the tech support file from the nvidia cp: and just an fyi: i have fiddled with the ram voltage up to 1.7 volts to no avail Number of Processors = 2 ========== CPUID Info ========== Processor 0: Brand = Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz Family = 6 Model = 15 Stepping = 2 L1 Instr Cache Size = 32768 L1 Data Cache Size = 32768 L2 Cache Size = 2097152 L3 Cache Size = 0 ========== CPUID Info ========== Processor 1: Brand = Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz Family = 6 Model = 15 Stepping = 2 L1 Instr Cache Size = 32768 L1 Data Cache Size = 32768 L2 Cache Size = 2097152 L3 Cache Size = 0 ========== Operating System Information ========== Windows 7 Ultimate 64 bit Microsoft , Build 7100 ========== Motherboard Information ========== Motherboard Vendor: NVIDIA Motherboard Version: 2.0 Motherboard Model: C73M55XECRB ========== DirectX version Information ========== DirectX 10.0 (6.1.7100.0) ========== Driver Version Information ========== Nforce Driver Package version Not reported Audio Driver Not reported Graphics Driver 191.07 (8.16.11.9107) Ethernet Driver Not reported IDE Driver 11.1.0.33 nTune 6.05.13 ========== Processor, Bus, and Memory Speed Information ========== CPU Speed = 2133.833 CPU Multiplier = 8.000 FSB Frequency = 267 Memory Frequency = 1335.000 PCIE Frequency = 5000 tRas = 24 tRcd = 9 tRp = 9 tRc = 34 tWr = 12 tRrd = 5 tRwt = 15 tWtr = 16 tWrwr = 6 tRdrd = 8 tFAW = 26 ========== GeForce Information ========== GPU 1: GeForce GTX 280 GPU 1 Video BIOS version: 62.00.0e.00.0f GPU 2: GeForce GTX 275 GPU 2 Video BIOS version: 62.00.60.00.03 ========== GPU's Core and Memory Speed Information ========== GPU Core Speed = 615 GPU Memory Speed = 1107 GPU Shader Clock Speed = 1350 GPU Core Speed = 633 GPU Memory Speed = 1134 GPU Shader Clock Speed = 1404 ========== System Voltage Information ========== CPU Voltage = 1.160 v nForce MCP Voltage = 1.500 v nForce SPP = 1.300 v Memory Voltage = 1.500 v FSB CPU <-> SPP Voltage = 1.200 v CPU Core0 GTL Vref boost = 0.000 v CPU Core1 GTL Vref boost = 0.000 v ========== Processor and System's Temperature Information ========== CPU Temperature = 41 C System Temperature = 29 C GPU 0 Temperature = 50 C GPU 1 Temperature = 41 C ========== Memory SPD Information ========== Memory Dimm 0 (0x50) Memory type: DDR3 SDRAM Error correction: NONE Voltage interface level: HSTL (1.5V) Data width: 64 bits Number of physical banks: 2 (double sided) Number of logical banks: 8 Number of row addresses: 14 14 Number of col addresses: 10 10 Bank density: 1024 1024 MB Primary RAM Width: 8 8 bits Error checking RAM Width: 0 0 bits Self-refresh: No CAS 7.0: Min row precharge time (tRP): 13.500 ns Min row active delay (tRRD): 7.500 ns Min RAS to CAS delay (tRCD): 13.500 ns Int Wr to Rd Cmd Dly (tWTR) 7.500 ns Int Rd to Pchg Cmd Dly (tRTP) 7.500 ns Min Act/Auto-Rfrsh Time (tRC) 50.625 ns UDIMM (module width = 133.35mm) Manufacturer's JEDEC ID code: 0000009e 00000002 Module manufacturing location: 1 (manufacture dependant) Module part number: CM3X2G1333C9 Module revision code: 0 (manufacture dependant) Module manufacturing date: Not reported Module serial number: 00000000 SPD revision: 1.1 Memory Dimm 1 (0x51) Memory type: DDR3 SDRAM Error correction: NONE Voltage interface level: HSTL (1.5V) Data width: 64 bits Number of physical banks: 2 (double sided) Number of logical banks: 8 Number of row addresses: 14 14 Number of col addresses: 10 10 Bank density: 1024 1024 MB Primary RAM Width: 8 8 bits Error checking RAM Width: 0 0 bits Self-refresh: No CAS 7.0: Min row precharge time (tRP): 13.500 ns Min row active delay (tRRD): 7.500 ns Min RAS to CAS delay (tRCD): 13.500 ns Int Wr to Rd Cmd Dly (tWTR) 7.500 ns Int Rd to Pchg Cmd Dly (tRTP) 7.500 ns Min Act/Auto-Rfrsh Time (tRC) 50.625 ns UDIMM (module width = 133.35mm) Manufacturer's JEDEC ID code: 0000009e 00000002 Module manufacturing location: 1 (manufacture dependant) Module part number: CM3X2G1333C9 Module revision code: 0 (manufacture dependant) Module manufacturing date: Not reported Module serial number: 00000000 SPD revision: 1.1 Memory Dimm 2 (0x52) Memory type: DDR3 SDRAM Error correction: NONE Voltage interface level: HSTL (1.5V) Data width: 64 bits Number of physical banks: 2 (double sided) Number of logical banks: 8 Number of row addresses: 14 14 Number of col addresses: 10 10 Bank density: 1024 1024 MB Primary RAM Width: 8 8 bits Error checking RAM Width: 0 0 bits Self-refresh: No CAS 7.0: Min row precharge time (tRP): 13.500 ns Min row active delay (tRRD): 7.500 ns Min RAS to CAS delay (tRCD): 13.500 ns Int Wr to Rd Cmd Dly (tWTR) 7.500 ns Int Rd to Pchg Cmd Dly (tRTP) 7.500 ns Min Act/Auto-Rfrsh Time (tRC) 50.625 ns UDIMM (module width = 133.35mm) Manufacturer's JEDEC ID code: 0000009e 00000002 Module manufacturing location: 1 (manufacture dependant) Module part number: CM3X2G1333C9 Module revision code: 0 (manufacture dependant) Module manufacturing date: Not reported Module serial number: 00000000 SPD revision: 1.1
Coolermaster HAF-X EVGA 4 way sli E762 Intel Core i7 950 @ 4.0 ghz OCZ Vertex 2 180 gb SSD 2x 150 gb WD raptor drives in RAID-0 Windows 7 ultimate 64 bit Coolermaster v10 hybrid tec 12 gig Corsair Dominator ram @ 1600 (3 x4gb kit) 3x evga gtx 470 superclocked in sli soundblaster fatality champion titanium series
bicycledr4376
2009/11/16 06:43:08
sorry, forgot to post that i have done memtest and all checked out fine. all 3 modules seem to have no problems.
VistaHead
- Ribbons : 132
2009/11/16 07:34:57
bicycledr4376 sorry, forgot to post that i have done memtest and all checked out fine. all 3 modules seem to have no problems. First off, you should have started your own thread, and not hijacked this one. Having said that..... Is that triple channel or dual channel RAM? I have not looked it up, but if you are running 3 X 2GB, that tells me that it is probably triple channel. The 790i series board uses DDR3 dual channel memory. Can you run triple channel memory?..sort of...you will probably only be able to run two sticks (4GB) of the RAM, and the timings will not be what the manufacturer's specifications are...in other words, if you are able to get it to run and be stable, you are going to have to tweak the hell out of the board's memory settings.
bicycledr4376
2009/11/16 17:33:33
sorry 'bout that. i dont usually post in forums so im kinda new to how they work. didn't mean to step on any toes here.according to corsair, the ram i have is dual channel ddr-3 pc3-10666. tested latency; 9-9-9-24 @ 1.5 volts
VistaHead
- Ribbons : 132
2009/11/16 17:47:41
bicycledr4376 sorry 'bout that. i dont usually post in forums so im kinda new to how they work. didn't mean to step on any toes here.according to corsair, the ram i have is dual channel ddr-3 pc3-10666. tested latency; 9-9-9-24 @ 1.5 volts Please post the RAM part number or better yet a link to a vendor that lists the specs.
bicycledr4376
2009/11/16 18:09:13
VistaHead
- Ribbons : 132
2009/11/16 18:22:37
Is this the 6GB kit that you have in the below link? If so, it is triple channel...look under specifications. The link that you provided gave no specs, and it is for the 4GB set. In most cases 6GB of RAM sold as a set of 3 X 2GB is going to be triple channel memory. http://www.newegg.com/Pro...S+Series%29-_-20145220
post edited by VistaHead - 2009/11/16 18:25:36
bicycledr4376
2009/11/16 18:32:05
unfortunately for me, this is what i went by: "The TW3X4G1333C9 is a 4096MByte matched pair of DDR3 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards" now that i have successfully wasted your time, thank you for your patience and help, and i will be going back to my CAVE lol lesson learned! now, about that tweaking....
VistaHead
- Ribbons : 132
2009/11/16 18:36:33
Is that your RAM in the Newegg link? The confusion is that the 4GB set is dual channel, the 6GB set is triple channel. So, did you purchase a 4GB set and a 2GB set, or one 6GB set? After you get your new RAM start a new thread and fill out a BIOS template, list all of your hardware to include RAM and model/part number. You can come back to this thread and cut and paste the BIOS template I provided the OP here in the beginning of the thread.
bicycledr4376
2009/11/16 18:55:22
yes that is the ram in the newegg link. i purchased the ram from microcenter already, and now i need to figure out what to do with it. do i go spring for the dominator ram? or just deal for now and try to tweak this? right now i gotta deal so i gotta tweak. what is the difference anyway? is it the amount of sticks? speed? its all very confusing. again, thanks for your help and i will get that template done asap
johnsunk123
2010/01/10 13:48:43
I love these forums. just had a mobo error code C1, and read all these posts I could find. Then I removed my memory sticks (Corsair XMS 1600) two at 1Gig ea. and blew on them like we use to to our old game decks and cartridges, reinserted them and all is fine. EVGA thank you so much for these forums.
