Felyx
Hello. I have been using my 790i Ultra SLI board for about a year without any game-stopping issues. It's always been a bit grumpy about the memory I had put in it(OCZ Gold 4GB (2 x 2GB) DDR3 1600 (PC3 12800) Dual Channel Memory Model OCZ3G16004GK). But most of the time it did boot up at 1600 speed (they were in the black channels). Today I updated my drivers for my graphics card to 195.39, restarted, and tried the new dragon origins game on full detail, so I imagine it got a workout, but there's nothing unusual about running high-end games on my machine. Later in the day I restarted my computer again and that's when I started having problems. Basically, whenever I try to boot up, I'm seeing the C1 error code on the motherboard and nothing on the monitor. It also beeps loudly. The motherboard manual says C1 is base memory detect, therefore my thought is that something has gone wrong with my RAM sticks. So I took them out, put them back in, put one stick in the first slot, switched the sticks around, and tried just about every combination. Always the C1 code. I don't have any other DDR3-using machines lying around, so I can't test whether it's for sure the memory or perhaps the motherboard somehow? I would be extremely grateful for any assistance with this, please. Do I need to get some new memory? If so, what are some recommended ones for this board? How can I be sure it's not the motherboard? Is there anything more I can describe that will be of help in shedding light on this? Motherboard: EVGA 790i Ultra SLI 132-CK-NF79 RAM: OCZ Gold 4GB (2 x 2GB) DDR3 1600 (PC3 12800) Dual Channel Memory Model OCZ3G16004GK CPU: Intel Core 2 Quad Q9550 Yorkfield 2.83GHz LGA 775 95W Quad-Core Processor Model BX80569Q9550 GFX: PALiT NE/960TSX0202 GeForce 9600GT SONIC 1GB 256-bit GDDR3 PCI Express 2.0 x16 Video Card Power: COOLMAX CUG-950B 950W OS: Vista 64
Stray_Bullet
- Ribbons : 8
Re:790i Ultra SLI, C1 code, won't boot. help?
2009/11/08 00:20:27
Did you go into the bios & set up your memory? OCZ's SPD in the memory by default sets it for 1.5v. If this is your memory... http://www.ocztechnology....pc3_12800_gold_edition You need to go into the BIOS & set your memory for 8-8-8-24-2T @ 1.9v Save then exit bios
My Machine: *Antec 1200 Case *EVGA 790i FTW|SZ16|nForce 15.58 *Q9650 @ 4.275 GHz Linked/Sync @ 1900 MHz *Prolimatech Megahalems CPU Cooler *Patriot 2x2GB PVS34G2000LLKN 8-8-8-23-2t|8-40-12-17-23-7.8uS-110 (black slots) *BFG 1000 Watt PSU *3x GTX 275|Forceware 270.61 *On-board Sound card|5.1 Surround *2 WD VelociRaptors|RAID 0 * 7 x64 790i BIOS Template| Critical Damage Incorporated
Felyx
2009/11/08 06:39:08
I had previously set my memory to correct timings and voltage, but right now I can't get into the BIOS to do anything or check the settings. It doesn't get to that point in bootup.
rlynn23
2009/11/08 07:01:19
Unplug your rig,turn power switch off,press power button to remove residual power,remove battery and move jumper pin and leave for fifteen to twenty minute's.Re-install battery,plug pc back in and try to boot into bios with only one stick of ram in the first dimm slot.If you get in then load safe default's except for ram voltage and timing's and try to boot into window's.Let me know what happen's.If you cannot boot then remove first stick of ram and try the next.I believe your ram may be the culprit.
Felyx
2009/11/08 11:41:51
I am still getting the C1 error code after following your instructions. The same thing happens. I tried with both sticks. I will order some new RAM online. What are some RAM that are known to work well with this board?
Stray_Bullet
- Ribbons : 8
2009/11/08 12:32:38
That ram is fine... I had OCZ 1600 RAM first. Everyone was saying bad things about OCZ ram & I got my 1600 sticks stable @ 1800 easy. I will work with you with your ram do not spend anymore money on ram Listen when you press the power button on the comp, continuously press delete & you will get into the bios... Then set 8-8-8-23-2T 6-40-12-17-23-7.8uS-110 @ 1.9v If you overclock you can probably get 1800 easy with same timings @ 1.95v to your memory! Then when in bios fill out a bios template. get it here... http://forums.evga.com/tm.aspx?m=5276
Felyx
2009/11/08 15:15:38
I have put in one stick of RAM, powered it on, and repeatedly pressed delete, but the computer doesn't get to BIOS. All I have to go on is the motherboard error code. Nothing at all appears on the monitor. This isn't due to my graphics card, I switched it out and retested and got the same result. The OCZ RAM has worked in the past, so I'm not saying it's bad, but that I think the RAM has developed a hardware defect of some sort. Else the motherboard has failed in some way. So I'm still interested in what memory would be good?
VistaHead
- Ribbons : 132
2009/11/08 15:28:56
☄ Helpful
Felyx I have put in one stick of RAM, powered it on, and repeatedly pressed delete, but the computer doesn't get to BIOS. All I have to go on is the motherboard error code. Nothing at all appears on the monitor. This isn't due to my graphics card, I switched it out and retested and got the same result. The OCZ RAM has worked in the past, so I'm not saying it's bad, but that I think the RAM has developed a hardware defect of some sort. Else the motherboard has failed in some way. So I'm still interested in what memory would be good? The Patriot Viper series RAM work really well with the 790i series board (the 2000Mhz RAM part number is in my sig). Take a look at the Patriot Viper Series RAM on Newegg's site.
post edited by VistaHead - 2009/11/08 15:43:12
Stray_Bullet
- Ribbons : 8
2009/11/08 15:58:50
VistaHead
- Ribbons : 132
2009/11/08 16:08:05
Felyx
2009/11/08 16:10:17
That's cool. Thanks for the recommendation. I'm more concerned about stability than speed right at the moment, but after reading that they were designed to be compatible with 790i, I'm hooked. Plus, if it turns out that the motherboard is at fault, I'll have some nice sticks to put in a replacement.
VistaHead
- Ribbons : 132
2009/11/08 16:15:11
Have you tested your RAM with Memtest86? I don't see where you say that you have done so in your post. Test each stick individually in the first black slot (closest to the CPU) for 6 hours each. http://www.memtest86.com/
Felyx
2009/11/08 16:33:36
How can I test my RAM if I can't get to BIOS? I tested it with memtest when I originally got it a year ago and it was fine at that time, but I went ahead and made a memtest floppy boot disk, stuck it in, powered it on with one stick in the first black channel, and I run into the C1 error code as I've described earlier. I don't have any other DDR3 systems to test my memory with. I'll just see what happens when I plug the new RAM in once it gets here.
VistaHead
- Ribbons : 132
2009/11/08 16:39:29
Felyx How can I test my RAM if I can't get to BIOS? I tested it with memtest when I originally got it a year ago and it was fine at that time, but I went ahead and made a memtest floppy boot disk, stuck it in, powered it on with one stick in the first black channel, and I run into the C1 error code as I've described earlier. I don't have any other DDR3 systems to test my memory with. I'll just see what happens when I plug the new RAM in once it gets here. You can make the bootable CD and try that. I only ask because if your RAM has no errors, I am not convinced that your memory is why you are having the problem that you are having. If it was that long ago (a year ago) that you tested your memory, you may want to test it again.
Felyx
2009/11/08 17:01:14
Alright, I went ahead and made a bootable memtest CD and tried that. No change. As far as I can tell, it is hanging way before getting to the part of POST that checks for boot devices, but this is a guess because the monitor is not displaying anything.
VistaHead
- Ribbons : 132
2009/11/08 17:14:49
Felyx Alright, I went ahead and made a bootable memtest CD and tried that. No change. As far as I can tell, it is hanging way before getting to the part of POST that checks for boot devices, but this is a guess because the monitor is not displaying anything. When you power on your PC, what, if anything shows on your monitor? Does your screen stay black the entire process up to the C1 error code on the motherboard LED? I'm just asking to make sure.
Felyx
2009/11/08 17:26:51
Absolutely nothing shows on the monitor for the entire process.
VistaHead
- Ribbons : 132
2009/11/08 17:31:41
Felyx Absolutely nothing shows on the monitor for the entire process. That is what makes me question if it is indeed the memory. Can you try your card in another pc? Can you try the monitor on another pc (or laptop)? Have you double checked your DVI cable from the card to the board to ensure it is seated all the way in both? If the card has two DVI connections, have you tried the the other one?
post edited by VistaHead - 2009/11/08 17:34:16
Felyx
2009/11/08 17:41:50
I have another graphics card that I tried, with no change. I am nearly 100% certain it is not the monitor. Bad monitors don't make motherboards go beep in the night. And I have had no problems with my monitor.
VistaHead
- Ribbons : 132
2009/11/08 17:44:07
Let us know the outcome after you get the new RAM.
Felyx
2009/11/10 15:43:09
Awesome. With that new Patriot RAM I booted up into BIOS with no problem. Am now flashing to P08 and setting things up. It's hard to remember how I had everything. What settings do you recommend for a Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core (E0) Processor? And is there anything special I need to do to set up the Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 2000 (PC3 16000) Dual Channel RAM Model PVS34G2000LLKN? Thanks a lot for the help btw.
VistaHead
- Ribbons : 132
2009/11/11 05:26:50
Please fill out the below BIOS template completely. Please enter the numerical values for all settings that say "Auto" in your BIOS next to the work itself. BIOS Version: P0* **System ** CPU Freq, MHz: * GHZ FSB Reference Clock, MHz: **** CPU Multiplier: [*X] PCle x16-1 & 16-2, MHz: [100] PCle x16-3, MHz: [100] SPPc->MCP Ref Clock, MHz: [200] nForce SPP --> nForce MCP: [5X] nForce SPP c-- nForce MCP: [5X] **Spread Spectrum** CPU Spread Spectrum: [Disabled] HT Spread Spectrum: [Disabled] PCle Spread Spectrurn(SPP): [Disabled] PCle Spread Spectrurn(MCP): [Disabled] SATA Spread Spectrum: [Disabled] **FSB & Memorv Config** FSB - Memory Clock Mode: [unlinked] FSB - Memory Ratio: FSB (QDR), MHz: [****] Actual FSB (QDR), MHz: **** x MEM (DDR), MHz: **** Actual MEM (DDR), MHz: **** P1: [AUTO] P2: [AUTO] **Memory Timing Setting** Memory Timing Setting: [manual] tCL (CAS Latency): * tRCD: * tRP: * tRAS: * Command Per Clock: [*T] ** Advanced Memory Settings ** tRRD: [Auto] tRC: [Auto] tWR: [Auto] tWTR: [Auto] tFAW: [Auto] tREF: [Auto] tRFC: **System Voltages** CPU Core: [*] CPU FSB: [*] Memory: [*] nForce SPP: [*] nForce MCP: [*] GTLVREF Lane 0: [Auto] GTLVREF Lane 1: [Auto] GTLVREF Lane 2: [Auto] GTLVREF Lane 3: [Auto] **CPU Configuration** Limit CPUlD Maxval: Disabled Intel Speedstep: Disabled xPPM Mode: [Native] CPU Thermal Control: [Disabled] C1E Enhanced Halt State: [Disabled] Execute Disable Bit: [Enabled] Virtualization Technology: [Disabled] CPU Core 0: [Enabled] CPU Core 1: [Enabled] CPU Core 2: [Enabled] CPU Core 3: [Enabled]
Felyx
2009/11/11 06:47:26
These settings let me boot into windows and do stuff without any obvious problems. But I ran memtest and got an error last night. I'd like to increase my memory speed a bit, but when I set the fsb/mem speed to 1800 it wouldn't boot. Not sure what settings to change for that. Thanks BIOS Version: P08 **System ** CPU Freq, MHz: 3612.5 GHZ FSB Reference Clock, MHz: 425 CPU Multiplier: 8X (8.5x) PCle x16-1 & 16-2, MHz: [100] PCle x16-3, MHz: [100] SPPc->MCP Ref Clock, MHz: [200] nForce SPP --> nForce MCP: [5X] nForce SPP c-- nForce MCP: [5X] **Spread Spectrum** CPU Spread Spectrum: [Disabled] HT Spread Spectrum: [Disabled] PCle Spread Spectrurn(SPP): [Disabled] PCle Spread Spectrurn(MCP): [Disabled] SATA Spread Spectrum: [Disabled] **FSB & Memorv Config** FSB - Memory Clock Mode: linked FSB - Memory Ratio: synced FSB (QDR), MHz: 1700 Actual FSB (QDR), MHz: 1700 x MEM (DDR), MHz: 1700 Actual MEM (DDR), MHz: 1700 P1: [AUTO] P2: [AUTO] **Memory Timing Setting** Memory Timing Setting: expert tCL (CAS Latency): 8 tRCD: 8 tRP: 8 tRAS: 20 Command Per Clock: 2T ** Advanced Memory Settings ** tRRD: [Auto] 7 tRC: [Auto] 52 tWR: [Auto] 12 tWTR: [Auto] 19 tFAW: [Auto] 40 tREF: [Auto] 7.7uS tRFC: [Auto] 94 **System Voltages** CPU Core: Auto 1.30v CPU FSB: 1.30v Memory: 1.80v nForce SPP: 1.40v nForce MCP: 1.55v GTLVREF Lane 0: [Auto] GTLVREF Lane 1: [Auto] GTLVREF Lane 2: [Auto] GTLVREF Lane 3: [Auto] **CPU Configuration** Limit CPUlD Maxval: Disabled Intel Speedstep: Disabled xPPM Mode: [Native] CPU Thermal Control: [Disabled] C1E Enhanced Halt State: [Disabled] Execute Disable Bit: [Enabled] Virtualization Technology: [Disabled] CPU Core 0: [Enabled] CPU Core 1: [Enabled] CPU Core 2: [Enabled] CPU Core 3: [Enabled]
VistaHead
- Ribbons : 132
2009/11/11 06:59:38
If you ran Memtest, and received an error, then you probably have a bad stick of RAM. Did you test each stick individually in the first black slot (the one closest to the CPU)? Try the below settings for 1700Mhz: P1: [AUTO] (ENABLED) P2: [AUTO] (ENABLED) tRAS: 20 (22) Execute Disable Bit: [Enabled] (DISABLED) What are the numerical values for the below settings in your BIOS? GTLVREF Lane 0: [Auto] GTLVREF Lane 1: [Auto] GTLVREF Lane 2: [Auto] GTLVREF Lane 3: [Auto]
rlynn23
2009/11/11 08:48:33
Stray_Bullet That ram is fine... I had OCZ 1600 RAM first. Everyone was saying bad things about OCZ ram & I got my 1600 sticks stable @ 1800 easy. I will work with you with your ram do not spend anymore money on ram Listen when you press the power button on the comp, continuously press delete & you will get into the bios... Then set 8-8-8-23-2T 6-40-12-17-23-7.8uS-110 @ 1.9v If you overclock you can probably get 1800 easy with same timings @ 1.95v to your memory! Then when in bios fill out a bios template. get it here... http://forums.evga.com/tm.aspx?m=5276 That ram suck's with this chipset.How can you tell him that the ram iis fine when he is having mad issue's that all seem ram related.I'm sure he needed some voltage adjustment's to become stable but that ram is crap!!
VistaHead
- Ribbons : 132
2009/11/11 09:48:53
rlynn23 Stray_Bullet That ram is fine... I had OCZ 1600 RAM first. Everyone was saying bad things about OCZ ram & I got my 1600 sticks stable @ 1800 easy. I will work with you with your ram do not spend anymore money on ram Listen when you press the power button on the comp, continuously press delete & you will get into the bios... Then set 8-8-8-23-2T 6-40-12-17-23-7.8uS-110 @ 1.9v If you overclock you can probably get 1800 easy with same timings @ 1.95v to your memory! Then when in bios fill out a bios template. get it here... http://forums.evga.com/tm.aspx?m=5276 That ram suck's with this chipset.How can you tell him that the ram iis fine when he is having mad issue's that all seem ram related.I'm sure he needed some voltage adjustment's to become stable but that ram is crap!! Post deleted - I see that you are not talking about the Patriot RAM.
post edited by VistaHead - 2009/11/11 09:51:41
Stray_Bullet
- Ribbons : 8
2009/11/11 13:42:47
rlynn23 Stray_Bullet That ram is fine... I had OCZ 1600 RAM first. Everyone was saying bad things about OCZ ram & I got my 1600 sticks stable @ 1800 easy. I will work with you with your ram do not spend anymore money on ram Listen when you press the power button on the comp, continuously press delete & you will get into the bios... Then set 8-8-8-23-2T 6-40-12-17-23-7.8uS-110 @ 1.9v If you overclock you can probably get 1800 easy with same timings @ 1.95v to your memory! Then when in bios fill out a bios template. get it here... http://forums.evga.com/tm.aspx?m=5276 That ram suck's with this chipset.How can you tell him that the ram iis fine when he is having mad issue's that all seem ram related.I'm sure he needed some voltage adjustment's to become stable but that ram is crap!! LMFAO. I have OCZ 1600 RAM running on my server in my basement on a 790i ultra board @ 1800. I had them in this comp till I wanted to pass 1800 FSB stable. How is it crap? I mean it says his memory voltage should be 1.9 on the OCZ site, what you think overclocking them to 1700 is gonna do when he has less then recommended voltage. I am just trying to help the poster out with getting his comp right without having to spend more money... Geez Here ya go proof... http://www.ocztechnologyf...showthread.php?t=50310
post edited by Stray_Bullet - 2009/11/11 13:59:35
rlynn23
2009/11/11 14:34:39
Well KLYFAO and using OCZ ram when most forum member's wont even recomend running that garbage.Use what you like but dont give bad advice...
Felyx
2009/11/11 14:47:56
VistaHead If you ran Memtest, and received an error, then you probably have a bad stick of RAM. Did you test each stick individually in the first black slot (the one closest to the CPU)? Try the below settings for 1700Mhz: P1: [AUTO] (ENABLED) P2: [AUTO] (ENABLED) tRAS: 20 (22) Execute Disable Bit: [Enabled] (DISABLED) What are the numerical values for the below settings in your BIOS? GTLVREF Lane 0: [Auto] GTLVREF Lane 1: [Auto] GTLVREF Lane 2: [Auto] GTLVREF Lane 3: [Auto] As for the OCZ RAM comments, I don't have any issue with the OCZ RAM except that it apparently developed some sort of hardware failure and sometimes didn't boot up. Anyway, I'm done with them. I did run a quick memtest of each stick of the Patriot RAM in the first black slot, but it wasn't a long test, just enough to see that it could read all the addresses. I changed the settings as suggested, and will leave memtest running tonight to see if I get any error again. Once I'm satisfied I'm getting no errors, I'd like suggestions on what to increase to get to 1800 Mhz. I noticed on official site it says it's rated for 2.0 voltage, so perhaps I should set it to that? GTLVREF Lane 0: [Auto] -50mv GTLVREF Lane 1: [Auto] -50mv GTLVREF Lane 2: [Auto] +00mv GTLVREF Lane 3: [Auto] +00mv
rlynn23
2009/11/11 14:50:05
If it rated at 2.o volt's then yes run them at that.
