I just got the EVGA FTW3 1080 ti. Problem is, I have two pci-e power cables, each with one 8-pin (6+2) and a 6-pin connector. The 1080 ti requires two 8-pin connectors. Would a simple 6-pin to 8-pin adapter work or will I not get sufficient power to my video card? I would like to use the other power cables for a second video card if this is to work.
Intel Core i7 3770K
16GB DDR3 1600Mhz
EVGA 2080ti XC Ultra
Something seems wrong here...
