Re: 5 beep Post Code, error code display is corrupted and can't be read
2024/08/07 06:11:28
New build or new problem? - Old build new problem. The system has been rock solid for 2 years.
OS? - Windows 10
What issue are you having with the PC, beside 5 Beeps? - The error code display on the board is corrupted and can't be read.
"Many motherboards will beep 1-2 times per USB device plugged in at boot; some will beep more based on functions of the device. These detection beeps may occur at the same time as the system’s POST beeps, sometimes making it a challenge to separate the POST beeps from the USB initialization."
No it's definitely 5 beeps and when I power it off and turn it back on it doesn't complete the boot and hangs. If I reset then it boots up successfully. In all cases I get 5 beeps. Previous to this was the normal 2 beep post code.
What devices are connected to USB ports on your Rig? Keyboard, mouse and headphones.
5 Beeps: This error is stating it cannot detect a keyboard. Keyboard functions ok. I can try another one. This can also indicate a video card is not detected. Video is fine but just in case I removed and reseated the card. I couldn't move it to to lower slot because it takes up 2 slots and won't fit. I don't have on board video or I would have tried that.
Have you tried running BIOS with default setting? No but I will try that. I did flash the BIOS with the latest update.
Have you tried the other BIOS positions? Same here, didn't try it but I will and report back my findings.
What do the LEDs indicate ... not the readout "POST Code" -- but, the individual LEDs (p 10 - 13 LEDs) Another good suggestion. I'll check it and let you know.
Thanks for all of the help!
