wodkdwhdrufwk
Hi all. I installed hybrid kit on 3090 ftw3 ultra. It works well, but the problem occured. icx sensor works not well, it only shows GPU core temperature on Precision X1. Also, there is no LED icon on the Precision X1, which there has been before I installed the hybrid kit. Someone might say that I have to change the BIOS for the hybrid, but I have already changed so Precision X1 recognize the card as 3090 ftw3 hybrid well. I need your help guys.
Re: 3090 ftw3 ultra hybrid kit, icx sensor not working, plus led is not controllable.
2020/12/28 16:43:36
I’d suggest putting everything back to stock to see if that will resolve your issues.
wodkdwhdrufwk
2020/12/28 16:56:23
Sajin I’d suggest putting everything back to stock to see if that will resolve your issues.
Dear Sajin, Thanks for the suggesting, but I am so frustrated..if I have to decompose the hybrid kit and make it back to ftw3 airflow version.. That is kind of a nightmare.. Arghhhhhhhhhhhhhhhhhhhhhhh! Thanks anyway, If I cannot find any solution on forum by this weekend, I have to consider the way.. So sad.
wodkdwhdrufwk
2021/01/01 18:45:55
hello sajin, I tried to covert back to stock cooler but still same issue happend, also impossible to reflash back to default bios(normal ftw3 ultra).
I reattached the hybrid kit and using now. And I find some interesting thing. (*important thing* I set the led lighting as purple before I firstly convert to hybrid kit)
hybrid ftw3 mod - led lighting of front, skyblue color, but evga mark on back plate is purple as I set before.
stock cooler mod(back) a both led lighting is purple.
Can you verify what is the problem with above things?
2021/01/01 21:30:15
bmgjet
- Ribbons : 9
2021/01/01 21:45:00
The sub device id is wrong on that bios. PX1 has a check to make sure its 3842 or it rejects ICX commands. That bios has a ID of 10DE You can fix it by changing the Library.dll file with this one. https://mega.nz/file/uehFCapK#dIEjcfwo0FmoUjvna7HTJ8B402kDEL-Nia0aywZqd7sIts usually located at C:\Program Files\EVGA\Precision X1\Library\Library.dll if your not using a steam installed version.
2021/01/01 21:59:30
If you want to flash back to the original vbios simply download the vbios here, and use nvflash to flash it back using the -6 command.
bmgjet
- Ribbons : 9
2021/01/01 22:13:50
And he will need to disable flash protection first with "nvflash --protectoff " Or here is a update.exe patched with the bios that Sajin linked.
wodkdwhdrufwk
2021/01/03 02:25:16
bmgjet The sub device id is wrong on that bios. PX1 has a check to make sure its 3842 or it rejects ICX commands. That bios has a ID of 10DE You can fix it by changing the Library.dll file with this one.
Dear Mr. bmgjet, Thank you for your help, but there is still no led icon on X1 Precision, also icx sensor do not detect the temp of MEM and VRM. X1 Precision detect the GPU as '10DE 2204 39883842' I also followed the guide that Sajin wrote on above, nothing changed. God it is nightmare..
post edited by wodkdwhdrufwk - 2021/01/03 02:39:35
wodkdwhdrufwk
2021/01/03 02:27:24
Sajin Have you tried this...
Sajin, thank you for your help, but it is not worked. Holy.. Do I have to format the computer and re-install all the things? For your information, I attached the picture. Front led color, sky blue. Backplate led color, purple, which I set before I install hybrid kit. .. Why??????
post edited by wodkdwhdrufwk - 2021/01/03 02:37:56
2021/01/03 14:26:40
I doubt a reformat is going to help with your issue as it appears no firmware is loaded to your card. I would suggest contacting evga support for help.
