Re: 3090 FTW3 Ultra 8Pin Cable #3 drawing much higher than others
2021/03/03 12:42:50
DavesMan
The 3090 FTW3 Ultra I also have draws over 80 Watts with 500 W XOC BIOS which is more the specs.
68 watts is the 12v PCI-E slot limit per PCI-E certification specification limits. You are 17.6% over the maximum limit and 60% over what you claim another card operates at. You may want to consider whether it is wise to operate that way, or if you should revert to the stock BIOS.
Take it from the guy that owns multiple 30xx cards and has a ton of hands on experience. Oh wait...he's just regurgitating information he's read again.
For someone that does not own one of these cards, you sure do spend a lot of time here. Interesting to say the least.
Thermaltake Level 20HT
AMD Ryzen 9 5950X 16 Core
Thermaltake Pacific MX1 Plus Water Block
Gigabyte Aorus Master X570
32 GB G.SKILL Trident Z Royal Series DDR4 3600
2x Samsung 980 Pro 1TB NVMe
1x Seagate Firecuda 520 2TB NVMe
TEAMGROUP T-Force Delta MAX RGB SSD 1TB
EVGA RTX 3090 FTW3 ULTRA w/EKWB
Dual Thermaltake PR22-D5 Pumps
Dual Thermaltake Pacific CL360 64mm Rads
EVGA SuperNOVA 1200 P2, 80+ PLATINUM 1200W
MSI OPTIX MPG341CQR
