mamaloney02
Hi all: Currently my set up is as follows: EVGA 3080FTW3 Ultra connected to Aorus Master Z490 MB. I currently have an Ultra High Speed HDMIs running from the GPU ---> TV (Samsung Q90R port 4 to get 4K 120Hz) ---> (from Q90R port 3 to get ARC) Denon AVR receiver (5.1 setup). Currently the sound only comes from the two front speakers, and when I go to control panel to configure the surround sound settings, I only get the "Stereo" audio option. Additionally, my TV will only pick up a "PCM" audio source. Is anyone aware of a way to get the surround sound option on the PC with my current set up how it is? I know I can always run an optical cable directly to the surround sound, but I'd rather not as you lose may Dolby and DTS sound features. I've tried many of the online guides, but the option seems to never pop up. All responses are appreciated!
post edited by mamaloney02 - Tuesday, August 03, 2021 2:30 PM
aka_STEVE_b
EGC Admin
- Ribbons : 69
Re: 3080 not outputting Surround Sound?
Tuesday, August 03, 2021 2:29 PM
an obvious question...did you install the sound drivers from the nvidia video/ audio driver installation package...?
mamaloney02
Tuesday, August 03, 2021 2:35 PM
I installed all the most recent audio drivers from my MOBO manufacturer last night. I wasn't aware there were audio drivers for NVIDIA. The only drivers I believe I have installed to date are the Game Ready Drivers provided by Nvidia (I'd prefer to keep GRD as my primary use for the PC is gaming). Not sure if the audio driver is inclusive in that or not. When going to the Nvidia website, I don't see audio specific drivers, would you be able to direct me to where I can find these or how I can verify I have the latest audio driver installed?
aka_STEVE_b
EGC Admin
- Ribbons : 69
Tuesday, August 03, 2021 2:46 PM
aka_STEVE_b
EGC Admin
- Ribbons : 69
Tuesday, August 03, 2021 2:52 PM
mamaloney02
Tuesday, August 03, 2021 2:58 PM
Your assistance and the links are greatly appreciated. I haven't run into these yet in my research, so I'll check if any resolve my issue once I get home this evening. I'll come back to this thread if they do not resolve the issue.
rmorse27
- Ribbons : 19
Tuesday, August 03, 2021 3:14 PM
your sound is coming from the HDMI cable so you need the audio driver for your video card from nvidia.
Intel i9 14900kf-Asus Z790 Rog Strix-E Wifi-Corsair 64GB @6400 DDR5-EVGA 3080TI FTW HC-EVGA G6 1000 PWS-Samsung Pro 2TB 4.0-Thermaletake Case-Corsair Pump/Res Combo http://www.heatware.com/eval.php?id=66896
Ciddharthas
Tuesday, August 03, 2021 4:03 PM
It's worth noting that for some really, really stupid reason, most of the time the sound output from TV's, whether it's hdmi or optical, is only capable of outputting stereo sound regardless of what was input into it. I don't know why the industry does it this way, and it's possible that that's not true for your tv, as pretty much every tech critic who knows about this calls it out for how stupid it is, so hopefully the manufacturers have begun to change it.
post edited by Ciddharthas - Tuesday, August 03, 2021 4:38 PM
CPU: i7 10700k @ 5.0 GHz with 360mm Corsair H150i Elite LCD cooler MB: MSI Z490 Meg Ace RAM: 64gb Corsair Dominator Platinum RGB @ 3466 MHz GPU: 3080 Ti FTW3 Ultra Hybrid Power Supply: Corsair HX1000i (1000 Watts) Primary Monitor: LG CX48 (4k OLED) Keyboard: Corsair K95 Platinum RGB Mouse: Corsair Scimitar Elite RGB Headset: Arctis Pro Wireless Mic: Elgato Wave 3 VR: Occulus Quest 2
Kbird666
Tuesday, August 03, 2021 4:11 PM
mamaloney02 I installed all the most recent audio drivers from my MOBO manufacturer last night. I wasn't aware there were audio drivers for NVIDIA. The only drivers I believe I have installed to date are the Game Ready Drivers provided by Nvidia (I'd prefer to keep GRD as my primary use for the PC is gaming). Not sure if the audio driver is inclusive in that or not. When going to the Nvidia website, I don't see audio specific drivers, would you be able to direct me to where I can find these or how I can verify I have the latest audio driver installed?
The Nvidia HD Audio is automatically installed with the GR or ST Drivers ..unless you uncheck it during a custom Install. It should be seen under Sound Controllers , probably along with the Realtek HD driver from the Mobo. KB
GByte Z590 Aorus Elite AX MB + 11700K 32GB Kingston Fury DDR4 @3200mhz EVGA Nvidia RTX 3080Ti EVGA G6 850watt P.S. (3) 32" BenQ BL3200PT Monitors (CAD-WS) .
Clovis559
Tuesday, August 03, 2021 6:37 PM
What model is your Receiver. I have a slightly older receiver Yamaha RX-740 I believe, and it does not support ARC 5.1, Only 2.1. I have to place the computer as HDMI 1 on receiver TV as HDMI 2 on receiver And out put video from Receiver to TV to get both to work with Surround. But then my receiver does not support HDR :( I had an adapter that worked for some time, but failed about 2 months in. In the end I need a new receiver.
weldon8914
Tuesday, August 03, 2021 11:14 PM
I have a Denon X3400H. My setup is HDMI out of the video card into the Denon, then another HDMI out of the Denon into the ARC HDMI of the 4K TV. I get 4K60,HDR,5.1 this way.
Clovis559
Wednesday, August 04, 2021 4:10 AM
I would imagine that setup your good. When you go to configure speakers in sound options it only shows stereo? I forget how to get there I’m not home and I only have a mac with me but I can write it up in the morn. This screen:  This would not be it, be good to note but on my Yamaha if I used any of their mixing formats like surround 7.1 it would give me funky problems where it would only come out the front speakers. I had to set mine to straight 7.1. I don’t know what the equivalent on Denon would be.
post edited by Clovis559 - Wednesday, August 04, 2021 4:23 AM
jdrednation
Monday, March 06, 2023 1:55 AM
Wanted to drop by and say that I'm having this issue myself. I just built a new PC and purchased an RTX 3080 FTW3 on the aftermarket, and I'm only getting the option for Stereo in speaker configuration. My old GTX 970 would output 5.1 just fine to my LG OLED C9 w/ eARC. Quite confused here! I tried deleting the Nvidia HD Audio driver and reinstalling, but it made no impact.
jdrednation
Monday, March 06, 2023 2:20 AM
I was just able to fix this issue for myself. On my LG OLED C9, I had to go to the TV's Sound settings, then changed 'Digital Sound Out' from 'Auto' to 'Pass through'. I find it interesting that Auto wouldn't work, but I'll take the fix.
