Answered3080 FTW3 Ultra LHR power limit and bios(xoc)
nezff
2021/09/01 09:22:50 (permalink)
Just got her installed and had a couple quick questions.  Im coming from a 20 series with two bios options, but honestly never used anything other than the normal vbios on all my cards, and never overclocked.  With that being said:
1.  I installed the 3080 FTW Ultra, updated firmware since PX1 asked me too, then clean install of drivers and everything went smooth.  After installing everything I noticed the power in precision was set down to like 30%? Very odd.  I moved the slider to 100, then to 105 where it is maxed out.  Im on the normal Vbios.  I guess my question is, why was it set so low and not default 100% and is it ok to raise it to 105 or above. I dont have the XOC bios yet.
2. Should I get the XOC bios if Im not overclocking? What do I gain in gaming performance etc.  1440p 27 inch monitor.  No 4K gaming.
Other than that, feel free to throw me any and all advice.
thanks in advance.
post edited by nezff - 2021/09/24 05:46:01
Use my Associates code at checkout and get up to 10% off! 95M1DJFALLX3K3L
i7 11700k * Asus ROG Strix z590a WiFi * EVGA 3080 FTW3 Ultra * 32GB Corsair 3200Mhz * Samsung 970 Pro 512GB & 970 Evo Plus 1TB M.2 * Samsung 860 Evo SSD 1TB & 2TB * Lian Li Dynamic white * Corsair QL fans x9 * Corsair H150i Pro XT * Corsair Rm1000x * Samsung G7 Faker 1440p 27"
  • Ribbons : 86
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 09:47:05 (permalink)
What a super build. Did you want me to move this to the mods rigs section of the forum?
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 09:50:11 (permalink)
the pics of the build?  sure.  I can attach more.  Those were just quick shots this morning after getting home from the firestation.
I wanted to get some help with those questions.
thanks
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 11:20:59 (permalink)
Also, forgot to ask, Is the XOC vbios for the 3080 FTW3 good for KR and KL cards?
thanks.
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 11:55:01 (permalink) ☼ Best Answerby nezff 2021/09/01 16:51:42
1. Setting itself to 30% was most likely a bug. Yes, it’s fine to use the higher values.
2. The xoc vbios will increase your max watts to 450 instead of 400. You’ll gain a little performance if you’re running into the power limit.
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 13:13:42 (permalink)
Thank you very much. Xoc vbios compatible with kr and kl?
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 13:17:12 (permalink) ☄ Helpfulby nezff 2021/09/01 16:51:56
nezff
Probably only compatible with kr. Ask evga tech support to confirm.
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 16:59:08 (permalink)
nezff
asked that question here, but no response yet. LINK
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 18:28:55 (permalink)
Asking in a thread may take awhile. You should call them via phone.
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 18:45:31 (permalink)
Lee got back with via PM.  He said there was a bios in that thread for the LHR cards? Im gonna go search.
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 18:51:12 (permalink)
So there is a vbios for kr & kl cards which shouldn’t be mixed it seems.
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 18:56:35 (permalink)
According to Lee yes.  But I definitely cant find it.
EVGATech_LeeM
Hi nezff,
No, they won't work properly.  If you look more closely at the page, there's a section specifically for 3080 LHR cards, which includes the XOC BIOS for the cards.
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 18:59:10 (permalink)
He is talking about this thread... https://forums.evga.com/E...S-Thread-m3407542.aspx
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/01 19:37:01 (permalink)
And here it is, the LHR XOC bios for the 3080 FTW3 Ultra
Flash to the XOC versions of the 3080 FTW3/FTW3 Ultra/HYBRID LHR cards:
good2joe
Re: 3080 FTW3 Ultra power limit and bios 2021/09/02 08:58:57 (permalink)
nezff
  •  (10G-P5-3897-KL) [XOC/ReBAR]
Thank you! 🙏
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/02 10:52:44 (permalink)
good2joe
nezff
Thank you! 🙏
You welcome
rjbarker
  • Ribbons : 21
Re: 3080 FTW3 Ultra power limit and bios 2021/09/02 20:12:58 (permalink)
^^^^ To be quite honest ...due to your Card being Air Cooled you will very likely run into thermal concerns long before you hit 450w power draw.
Give it a try, but dont think it will make much difference....
I9 12900K EK Velocity2 / ROG Z690 Apex/ 32G Dominator DDR5 6000/ Evga RTX 3080Ti FTW3  EK Vector / 980 Pro 512G / 980 Pro 1TB/ Samsung 860 Pro 500G/ WD 4TB Red / AX 1600i /  Corsair 900D & XSPC 480 * 360 * 240 Rads   XSPC Photon 170 Rez-Vario Pump Combo - Alienware 3440*1440p 120Hz/ W11
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/02 20:19:17 (permalink)
rjbarker
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/23 08:10:00 (permalink)
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/24 05:45:18 (permalink)
would it move the whole thread? Or just pictures. I can always send or post other pics of the rig for mod rigs.
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/09/24 05:48:30 (permalink)
nezff
Re: 3080 FTW3 Ultra power limit and bios 2021/11/14 05:18:09 (permalink)
Hate to dig up a old thread but had a similar issue where precision x1 would revert to 100% power after having it at 105% bug?
Software not saving my settings? I upgraded to latest version.
Re: 3080 FTW3 Ultra power limit and bios 2021/11/14 08:30:32 (permalink)
Yep, sounds like another bug.
#23
