Helpful Reply2080 TI XC Ultra fan clicking noise
Page: << < ..1112 Showing page 12 of 12
jernic
Re: 2080 TI XC Ultra fan clicking noise Sunday, April 05, 2020 6:03 PM (permalink)
I get a clicking sound even when the fans are not spinning (RTX 2070 Super - no overclocking) but louder when they are spinning. I reduced from 144 to 120 Hz on monitor but no change per poster suggestion i read.  Sounds like maybe a fan bearing sound but why when the fans are idle and then louder when spinning ? My temps are good but I wonder whether this is a harbinger of future issues when warranty may be expired. Cannot see that any wires are the culprit.
Jabbrony
Re: 2080 TI XC Ultra fan clicking noise Saturday, April 25, 2020 8:31 AM (permalink)
I have same card got it b stock from evga. Has loud coil whine under load
Flonkam
Re: 2080 TI XC Ultra fan clicking noise Tuesday, April 28, 2020 8:40 AM (permalink)
Jabbrony
Even at framerates of say, 120 or lower?
yasincakmak
Re: 2080 TI XC Ultra fan clicking noise Tuesday, April 28, 2020 5:23 PM (permalink)
My 2080ti FTW3 Ultra also has the annoying clicking sound. Can someone gimme fan curve please, Im new with that things but its drive me crazy. Look at icx right fan picture on gpuz;
edit Cool GTX fixed photo
post edited by Cool GTX - Tuesday, April 28, 2020 6:53 PM
  • Ribbons : 123
Re: 2080 TI XC Ultra fan clicking noise Tuesday, April 28, 2020 6:52 PM (permalink)
yasincakmak
released from filter
Which BIOS position is your card set to ?
simple fan curve:  Base (slowest) 30% then set curve @ Temp in C +10 = RPM%
so 30C = 40% fan ... 40C = 50% fan ... 60C = 70% ....
gvkts
Re: 2080 TI XC Ultra fan clicking noise Tuesday, April 28, 2020 11:36 PM (permalink)
I posted a fan curve and a description for the 2060 (in the 2060 KO noise thread). It might be useful here as well as an alternative to look at. The picture seems to be filtered and not visible whether attached or linked to. Is there some rule on which pictures are released and which are not? It is just a screenshot of the fan curve.
yasincakmak
Re: 2080 TI XC Ultra fan clicking noise Wednesday, April 29, 2020 11:46 AM (permalink)
yasincakmak
Okay thank u, I just use now default custom curve from that program and all fans are turning 1350rpm all the time on idle. My idle temp is 34C right now. What about gpu2 ? My gpu1 is 64C in game but gpu2 is 71C. Is that okay for 30 min farcry5 game? (Sorry english not well
SLK2355
Re: 2080 TI XC Ultra fan clicking noise Friday, May 01, 2020 5:10 PM (permalink)
Listen to this 2080 AMP Maxx I had. It makes all the Evga models appear silent. Listen towards the end especially @ 1:05
Kazegin
Re: 2080 TI XC Ultra fan clicking noise Tuesday, August 25, 2020 4:32 PM (permalink)
So after a year of use, i too am now getting the clicking noise. And only has been getting worse. In the beginning the clicks were barely noticeable, then after time louder and more consistent. So i did some of the following steps, blow a can of air on GPU to ensure dust wasn't the culprit, check outside wiring. But still the noise was going on...saw these forums and noticed a lot of us are getting the wire issue. So today i took the shroud out and saw the fan wire was a bit popping out. Took some tools and tried to push the wire more flat since they were twisting on he heatsink fin making it pop out towards the fan blade more. And slightly bent the 2nd and 3rd heatsink fin to give more room for me to pull the fan wires back towards the end of the card where they are plugged in. Attached are the pics and 2 videos of the "tinking" and "pinging" noise. Videos were before i took shroud off. Will do another video when i go home and reinstall the GPU and pray i dont have to RMA it, or return to microcenter.
/watch?v=GbjYCFm0FRs
/watch?v=NuDMBXoVxHY
Just add the youtube before the links above and you will see when the fans start/stop the clicking.
post edited by Kazegin - Tuesday, August 25, 2020 6:09 PM
asdf2345
Re: 2080 TI XC Ultra fan clicking noise Saturday, November 12, 2022 11:41 AM (permalink)
I have a 2080 Ti Black, and it sounds like it has this issue. Should I try RMAing it?
  • Ribbons : 86
Re: 2080 TI XC Ultra fan clicking noise Saturday, November 12, 2022 11:55 AM (permalink)
asdf2345
If you are within warranty then you can make an RMA.
