mahubbert1
Wednesday, August 23, 2017 2:52 PM
current list of parts .. pcpartpicker DOT com/list/zBr96X --- corsair DOT com/en-us/hxi-series-hx1000i-high-performance-atx-power-supply-1000-watt-80-plus-platinum-certified-psu current power supply I have 2 1080ti FTW3 hybrid's on order. I knew ahead of time that there is going to be no room to overclock and I am fine with that. Unfortunately, after I started reading I am now worried that my current PSU will not be strong enough even without an overclock. Was wondering if someone smarter than me could give me some advice here on two things: - will everything run/be fine so long as I do not OC?
- one of the things I came across trying to research on my own was a discussion of using 2 seperate PCI power cables from the PSU to the GPU, I didn't even realize this was a thing. --> for my SLI setup the example would be 4 separate cables from the PSU to the GPUs with each 8pin slot power slot on the GPU getting its own line to the PSU.. is that actually necessary or does that have to do with the quality of power supply and the amperage etc etc.
post edited by mahubbert1 - Wednesday, August 23, 2017 3:46 PM
Re: 1080ti Power Draw and PSU Compatibility
Wednesday, August 23, 2017 2:57 PM
Don't see your parts list.
mahubbert1
Wednesday, August 23, 2017 3:44 PM
Sajin Don't see your parts list.
Maybe you have to post so much before the boards will let you post links or it could be a problem on my end. Should at least be posting them now without a direct link, have to add the period yourself. :( current list of parts .. pcpartpicker DOT com/list/zBr96X --- corsair DOT com/en-us/hxi-series-hx1000i-high-performance-atx-power-supply-1000-watt-80-plus-platinum-certified-psu current power supply
post edited by mahubbert1 - Wednesday, August 23, 2017 3:49 PM
ShaneRobs
Wednesday, August 23, 2017 4:01 PM
☄ Helpfulby mahubbert1 Wednesday, August 23, 2017 4:41 PM
Looked at your parts list and your psu should have no problem with your setup with no overclock your drawing a little over 700 watts of power and your using a platinum psu so i think your good.
- Ribbons : 123
Wednesday, August 23, 2017 4:08 PM
MY Rig i7-5930 with Corsair AIO - currently Not OC 2- EVGA 1080Ti FTW3 Hybrid ---> working very hard Folding (80-90% GPU loads) 60% fan on card 1 additional 140mm fan Pulling 710 Watts as measured on a " Kill A Watt" meter
Wednesday, August 23, 2017 4:12 PM
1. Yes. 2. It isn't required.
bob16314
- Ribbons : 761
Wednesday, August 23, 2017 4:39 PM
☼ Best Answerby mahubbert1 Wednesday, August 23, 2017 4:41 PM
Welcome to the forums..You can use the Outervision Power Supply Calculator to estimate your system wattage need..You should be more than good with a Corsair HX1000i and have headroom for some overclocking too, but see what the calculator says..The calculator will adjust for overclocking if you enter the info. Using one 8-pin PCIe cable (at the PSU end) that splits off into 2 connectors (at the graphics card end) should work fine.
