1080TI FTW3 LED SYNC Not Possible
porche360
2018/12/17 11:19:15 (permalink)
I Just bought a 1080ti ftw3 with B450 Aorus Motherboard and in several ways i still can’t change the rgb color
i’ve tried to uninstall the XOC and re- installed. Another versions but nothing happens when I get into LED sync it’s seem to be It’s can’t find the vga
(There is no device to choose from ) Right now the color is stuck in Red Can someone please tell me how to fix this I really like to changes into white
Thanks you all for further details
post edited by porche360 - 2018/12/17 11:40:07
9 Replies Related Threads
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 13:52:06 (permalink)
    Are the appearance/thermal led menus also blacked out in the settings menu?
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 13:52:21 (permalink)
    Moving thread to evga software subsection.
    porche360
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 23:17:59 (permalink)
    Yes Those setting tabs also  black out too.
    post edited by porche360 - 2018/12/17 23:21:10
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 23:33:07 (permalink)
    Have you looked at this thread... https://forums.evga.com/F...cked-out-m2729670.aspx
    porche360
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 23:39:39 (permalink)
    Thanks but i already try this but again LED SYNC still not working or maybe i have to remove the card and unplug it and try to move it to new slot ?
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/17 23:41:14 (permalink)
    Yeah, wouldn't hurt to try it.
    porche360
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/18 00:34:17 (permalink)
    I just try to change my 1080ti to another slot but the result turnout the same the LED SYNC not showing VGA
    is there anyone had the same issues?
    EVGATech_AdamB
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/18 09:14:12 (permalink)
    LED Sync is really meant to be used in conjunction with the CLC cooler and a EVGA graphics card. If you are only changing the LED colors for the GPU, don't use LED sync, use the PXOC settings instead. If you click on the settings wheel icon in the lower right corner of the main PXOC window, you should see an appearance LED tab and from there you should be able to change the GPU lighting.
    Like our service? Please provide feedback for us at the link HERE
    porche360
    Re: 1080TI FTW3 LED SYNC Not Possible 2018/12/19 03:04:03 (permalink)
    EVGATech_AdamB
     Thank you but In my case PXOC Setting either the appearance LED and thermal LED won't showing up so i can't click into it what can i do next  to change these VGA lighting?
