z97 stinger 111-HR-E972 spdif-out audio problem
agentz4
2020/01/07 13:25:33 (permalink)
The spdif-out port I was using for my headphone connection randomly stopped working. I checked several other audio cables to no avail. However i determined the audio cables to not be the issue as my headphones were still working from the pc case built in audio port. I installed the evga soundblaster drivers and peculiarly the audio could be heard without issue when configuring settings from within the program; but when the windows sound output is set to spdif-out i get nothing. Everything looks correct from the device manager. I don't know how else I should continue to diagnosis this issue. Any suggestions?
3 Replies Related Threads
    coolmistry
    • Ribbons : 35
    Re: z97 stinger 111-HR-E972 spdif-out audio problem 2020/01/09 09:55:00 (permalink)
    Hello and Welcome to the Forum
    Can you tell us what is exactly of your motherboard is?
    Either
    EVGA Z97 Stinger WiFi Part Number:  111-HR-E973-KR
    Or
    EVGA Z97 Stinger Core3D Part Number: 111-HR-E972-KR
    If it is EVGA Z97 Stinger Core3D here latest Version for Core3D here >Creative Sound Blaster Recon3Di Drivers Version 6.0.101.1059
    Try install latest Version and see how it go!
    You need detail put down your full PC spec and What Windows OS are you using? For us member can help you know what is your Full PC spec
    Windows 10 Home 64bits v1909
    i7 8086k @ 5275MHz delidded || EVGA Z370 Classifieds K || 2 x EVGA GTX 1080 Classified  || 16 gb Dominator Platinum DDR3 3200mhz XMP || 500gb Samsung 970 EVO plus NVMe || 256gb Samsung 970 EVO NVMe M.2 (3 x SSD and 1xHHD) || Killer Wireless AC1550 || EVGA CLC 280 Cooler || EVGA Supernova 1000w G2 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse || EVGA DG 77 case || Acer Predator Z35 35" 160Hz G-Sync v2 Pro || Logitech Z906 5.1 system sounds  SPDIF || Kaspersky Internet Security
    agentz4
    Re: z97 stinger 111-HR-E972 spdif-out audio problem 2020/01/10 15:36:53 (permalink)
    EVGA Z97 Stinger Core3D 111-HR-E972-KR
    Intel Core i5 4690k
    16GB Corsair Vengeance DDR3 1600
    EVGA GTX 1060 6GB
    Samsung SSD 860 EVO 1TB
    Windows 10 64-bit
    coolmistry
    • Ribbons : 35
    Re: z97 stinger 111-HR-E972 spdif-out audio problem 2020/01/10 15:54:39 (permalink)
    Have you install > Creative Sound Blaster Recon3Di Drivers Version 6.0.101.1059 yet? Hope this solve!!
