Re: water cooling: 400-HY-5598-B1 (closed loop water block for 1080 ti)
2018/09/09 10:54:20
I believe the real reason for placing the Rad above the pump is due to insuring that if there is any air in the closed loop, it stays in the Rad - not the pump (where it would kill it). So IMO "above" the block/pump really is accomplished by the RAD hose connections (or some part of the Rad) being - above the pump (a place for any air bubbles to reside)
So otherwise - you've got two choices ...
- void the warranty from the beginning and test your skills at eliminating ALL the air from the (previously) closed system . . . and, yes, it can be done - it's just not overly easy . . . then place the Rad down below, or . . .
- if you're going to lose sleep worrying about a leak (keeping in mind - you already did an upgrade to your system ... so why would you expect to not do the same over the next two years ?) - then mount the dang thing on the outside of your case (above the pump) ... can also be done with a little ingenuity !
. . . then, for some - there is always the option to use a 'reverse' form factor case (Motherboard mounted upside-down) ... which moves the expensive GPU to the top of the case, and you can usually mount a 120 Rad on the back of the case with not much below it.
I understand your concern - the risk is always there . . . it's just what keeps you up at night . . . for many - they struggle with the 'mixed metal' thing - Copper + Aluminum . . . but why do we never hear these kinds of issues with AIOs - most of which are exactly that ???
[BTW - it's electronics and electrolytes that don't mix . . . I used to make Underwater lights for Cave Diving - primarily fresh water springs ... lights still worked fine even if the case completely leaked !!!!! ]
Cheers
Remember - "No matter where you go . . . there you are"
