Helpful Replymolex to 3 or 4 pin adapters for fan speed control?
thend005
Friday, March 04, 2011 3:09 AM (permalink)
Hey just wondering if there is a way to convert molex to 3 pin... i got a scythe kaze master pro 6 fan controller and 6 GT's at 5400 rpm to go in my new rig. Thing is, because the molex's plug right into the psu cords, even though it has a 3 pin adapter that goes to the fan controller, the fan controller can't actually do anything because it can't direct the flow of power away from the molex... am i screwed? PerformancePC only has a 72 hour return policy... I think i'm out 187 bucks...
the fan conroller works great for the regular corsair fans that only have a 3 pin adapter, but because the gentle typhoons have the 3 pin and a molex... i can't lower their speed and 5400 rpm is too high to use. any suggestions?
post edited by thend005 - Friday, March 04, 2011 4:12 AM
Asus Maximus IV Extreme Rev 3.0
i7 2600k batch# L038A660 5.0ghz @ 1.41v
2x EVGA GTX vanilla 580s SLI 900mhz/1800/2106 @ 1.1v
My Affiliate Code: RFD91AUNI3
thend005
Re:need some assistance please. Friday, March 04, 2011 3:18 AM (permalink)
not sure there is any way around this... kinda ticks me off.
post edited by thend005 - Friday, March 04, 2011 4:13 AM
bucyrus5000
  • Ribbons : 8
Re:need some assistance please. Friday, March 04, 2011 3:21 AM (permalink)
really wish I could help you.
Rant about what Grinds Your Gears HERE
Need help finding places to shop for computer goods? Find stores HERE and review them.
thend005
Re:need some assistance please. Friday, March 04, 2011 4:19 AM (permalink)
nick1551
  • Ribbons : 24
Re:need some assistance please. Friday, March 04, 2011 4:28 AM (permalink) ☄ Helpful
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=608
post edited by nick1551 - Friday, March 04, 2011 4:30 AM
Heatware      Evga 8800GT 512mb Fan Speed BIOS
i7-920 @4.0 - Evga X58 Micro - 2x4gb Gskill - Evga GTX 970 SC+ @1450mhz
Crucial MX200 250GB - Corsair HX620 - CM690
OPO -- RR 7.1
LeEco Le S3
daveyd007
Re:need some assistance please. Friday, March 04, 2011 4:31 AM (permalink)
not supposed to use the molex and 3 pin from the fan connector if you're trying to regulate the power. Use just the three pin coming from the controller to individual fans.
The psu molex goes to the fan controller.
- SYSTEM SPECS-
ASUS Rampage Extreme III • Core I-7 980x @ 4.8Ghz w/ stock CPU cooler• 24Gb Patriot VIPER Extreme DDR3 2000Mhz • GTX 570 in 3-way SLi • TWO Intel X-25V SSD's in RAID-0 (c-drive)• Six Intel X-25M SSD's in RAID-0 (d-drive) • 10X BluRay by LG • CoolerMaster SilentPro GOLD 1200W • Antec Dark Fleet (DF-85) Full Tower Chasis • RAZER Lycosa Keyboard RZ03 • Logitech G-500 Laser mouse • BOSE Companion 5 - 5.1 Surround Sound •  UltraSlim 55" SAMSUNG L.E.D. Display 3DMARK VANTAGE SCORE - P 56,801 @ 4.76Ghz 800/2000 AIDA64 Cache & Memory Benchmark @ 4.8Ghz  Click here to see my overclocked car PC.
nick1551
  • Ribbons : 24
Re:need some assistance please. Friday, March 04, 2011 4:34 AM (permalink)
The GT's draw a high amperage so they have a molex power supply and a 3-pin rpm signal wire, they are different then a regular fan.
To OP:
That adapter should work but you might not get an rpm signal from the fan.  But you never know.
OPO -- RR 7.1
LeEco Le S3
moose517
  • Ribbons : 33
Re:need some assistance please. Friday, March 04, 2011 4:35 AM (permalink)
LOL thats not what he meant daveyd007, the fan uses molex for power but has a 3 pin for monitoring RPM only.  what nick linked is exactly what he wants, and i bookmarked that as well because i need some myself LOL.
daveyd007
Re:need some assistance please. Friday, March 04, 2011 4:36 AM (permalink)
http://www.ehow.com/how_5...ll-fan-controller.html
ok moose, i hear ya! my bad..lol
- SYSTEM SPECS-
thend005
Re:need some assistance please. Friday, March 04, 2011 4:40 AM (permalink)
ah so because i was plugging that yellow wire that has a 3 pin ending into the scythe fan controller, that is why i coudln't actually regulate the speeds... but if i buy that adapter for the molex, will that essentially let me monitor the speed without being able to see the from the yellow cord? its all confusing.
  • Ribbons : 115
Re:need some assistance please. Friday, March 04, 2011 4:45 AM (permalink)
A fan speed is regulated by the fan controller when you plug the fan to the fan controller.
            My Affiliate Code: 8WEQVXMCJL
 &nbsp
daveyd007
Re:need some assistance please. Friday, March 04, 2011 4:47 AM (permalink)
+1 ^^^
yellow is usually the tach signal on a three pin fan connector, red can be either +12VDC or +5VDC. Black of course is the ground wire.
Ignore the CVS connections and temp sensor info if your controller doesn't have it.
post edited by daveyd007 - Friday, March 04, 2011 5:01 AM
- SYSTEM SPECS-
nick1551
  • Ribbons : 24
Re:need some assistance please. Friday, March 04, 2011 8:37 AM (permalink) ☄ Helpful
thend005
Yes you will be able to adjust the speed, you just won't be able to see the rpm of the fan.
You might however be able to take the pin out of the rpm connector and lock it into the empty slot on the 3-pin side of the adapter, that would allow the controller to see the rpm output signal.  Another thing, these monster fans pull 1.14a and your controller is only rated for 1a per channel.  Not sure how long each channel will last, or if it will work at all.
OPO -- RR 7.1
LeEco Le S3
thend005
Re:need some assistance please. Friday, March 04, 2011 3:30 PM (permalink)
nick1551
i just ordered 6 of these from them, i wish they'd of told me i'd need them when i ordered my 6 gt's and the kaze from performance-pcs the other day, ah well.
